hello nxp friends? my pc is not recognise otg in imx8mm
13660284951
hello:
besides:My pc is windows10 64bit。
Desp、I dail the start mode keyes into download mode before,and plug otg enter pc, found the otg had been recognised hid device not  USB download gadget ,what can i do?
gusarambula
Hello zhou wei,
Are you using the i.MX8M Mini EVK?
If so, please check that you are using the correct Type-C port and please double check the SW1101 switches.
https://www.nxp.com/docs/en/quick-reference-guide/8MMINIEVKQSG.PDF
Once recognized, even if shown as HID Device, it should be discoverable by the UUU tool so that you can download an image.
I hope this helps!
13660284951
I don't know why。
our board cancel typc2,only remain typc1 , from usb download,use uuu uboot.imx it ok,while run ./uuu-imx-android-flash.sh fail after the board reset,the fail usage is ufb timeout
