hard-float
hard-float
967 次查看
niklasmolin
Senior Contributor I
Hi.
I wonder if Yocto is supporting hard-floating for i.MX6?
Or do I need to include this part when I compile a specific application, node.Js in our case?
If so, how do I change the compile to use hard-float instead?
Niklas
标签 (2)
787 次查看
LeonardoSandova
Specialist I
It does support and by default it is HF. Check the DEFAULTTUNE variable in case you want to change it to SF.
Leo
