h264 encoding to other bit rate
1,148 次查看
nxf65233
Hello everyone
SOC:iMX8MM
System: Yocto Linux
Encode the h264-encoded mp4 file into the h264 mp4 file of other bit rate
How should I use the gstreamer command?
1,142 次查看
AldoG
Please try with the following pipeline, just change the bitrate property to the desired bitrate (Kbps):
gst-launch-1.0 videotestsrc ! video/x-raw, format=I420, width=640, height=480 ! vpuenc_h264 bitrate=20000 ! filesink location=test.mp4
Aldo.
1,143 次查看
AldoG
Aldo.
