gstreamer pipeline in a QT5 Window
1,336件の閲覧回数
richc128
My goal is to have a gstreamer pipeline and have one output of that go to a qt window. I'm using Yocto with the Dunfell release. I'm using a i.mx8m mini.
I see there some plugins that look promising, such as qt5glvideosink but I have no idea how to add them to my image.
Is QtGStreamer the best path or is there a better way to go about this?
ラベル(2)
1,307件の閲覧回数
joanxie
try to add "PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer" " and "IMAGE_INSTALL_append = "\
    qtmultimedia \
    qtmultimedia-plugins \
    qtmultimedia-examples \
    qtmultimedia-qmlplugins""
to the lcoal.conf, then build agian, you can find qmlvideo under /usr/share/qt5/
