gstreamer-0.10 via webkit doesn't play video on i.mx6 (yocto master, webkit-5.1.1)
Search instead for
dmitryfedotov
gstreamer-0.10 via webkit doesn't play video, but via gst-launch, gplay, and player from qtmultimedia work correctly.
Output from simple browser from examples(GST_DEBUG=3 ./browser big_buck_bunny.webm) in attachment.
I guess the problem indicated in this strings:
aiurdemux gst-fsl-plugins-3.0.11/src/parser/aiur/src/aiurdemux.c:4095:aiurdemux_push_pad_buffer: Pad video push error type -2
aiurdemux gst-fsl-plugins-3.0.11/src/parser/aiur/src/aiurdemux.c:4095:aiurdemux_push_pad_buffer: Pad audio push error type -2
How can I fix this problem?
Original Attachment has been moved to: log.zip
dmitryfedotov
Solved.
If deleting gstreamer files from /usr/lib/pkg-config in sysroot directory(before qtwebkit configured) QTWebKit configured with use only QTMultimedia plugin and it work fine.
dmitryfedotov
Solved.
