Hi guys,
I have a problem when excute
"gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, format=(string)UYVY, width=720, height=576,framerate=25/1(or, 50/1), interlace-mode=(string)progressive' ! imxv4l2sink"
device shows always the log : it just looks like infinite loop, it doesn't work
"In MVC: mxc_v4l_ioctl
In MVC: mxc_v4l_do_ioctl c0485619
case VIDIOC_ENUMSTD
case VIDIOC_ENUMSTD
case VIDIOC_ENUMSTD
but, when I excute :
./mxc_v4l2_overlay.out -iw 720 -ih 576 -ow 640 -oh 480 -m 3 -di /dev/video0 -fg", it works !!!
I want to know why infinite Ioctl function is called and fix gst-launch problem.
Please let me know what I should check it.
My camera:
BT656, PAL, progressive
Hi guys,
I have more comment. when I used USB camera, there is no problem to preview and below is command used:
"gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=640,height=480' ! imxv4l2sink
Anybody know why my issue happens?
Hello yibhan,
The issue with
case VIDIOC_ENUMSTD
means that it haven´t found a camera or the video UYV is incorrect, the VIDIOC_ENUMSTD enumerated support video standard.
This does not happens when you have from usb because you change this line with xraw.
Hi Bio,
Your answer may be helpful for me, and I have more questions,
I have checked camera working with ./mxc_v4l2_overlay.out, and it worked and below comand is :
My question is if mxc_v4l2_overlay works and gstreamer dosen't work because of VIDIOC_ENUMSTD(?), where should I check in driver or other parts?
