gplay hangs playing a video with audio
97,545件の閲覧回数
bearq
We are testing videos on the i.MX6DL with Linux version 3.14.52. If we play a video without audio, it play very well, but playing a video with audio, gplay will hangs up, but I can see first frame showed on the display. Some Info show below:
//==== command:   gst-launch-0.10 playbin uri=file:///harddisk/maiken1.mpg
export GST_DEBUG=filesrc:4
mx6qsabresd:/harddisk# gst-launch-0.10 playbin uri=file:///harddisk/maiken1.mpg
0:00:00.061378333   553  0x1518380 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:374:gst_file_src_set_location: filename : /harddisk/maiken1.mpg
0:00:00.061536333   553  0x1518380 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:375:gst_file_src_set_location: uri      : file:///harddisk/maiken1.mpg
0:00:00.065732000   553  0x1518380 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
0:00:00.065909667   553  0x1518380 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
(gst-launch-0.10:553): GStreamer-CRITICAL **: gst_debug_log_valist: assertion 'category != NULL' failed
0:00:00.087778000   553  0x1518380 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
0:00:00.087915000   553  0x1518380 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
Pipeline is PREROLLING ...
Aiur: 4.0.3
Core: BLN_MAD-MMLAYER_MPG2PARSER_04.04.40  build on Nov 11 2015 08:09:41
  mime: video/mpeg, mpegversion=(int)[1,2]; video/mpegts, systemstream=true; video/x-cdxa
  file: /usr/lib/imx-mm/parser/lib_mpg2_parser_arm11_elinux.so.3.1
Content Info:
        URI:
        Idx File:
              /home/root/.aiur/.harddisk.maiken1.mpg.aidx
        Seekable  : Yes
        Size(byte): 17670148
Mpeg2CreateParser:parser created successfully
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:00:31.272000000
        ReadMode  : File
        programs    : 1
        Track     : 2
Track 00 [video_000000] Enabled
        ppid: 0, ppid 0
        Duration: 0:00:31.240000000
        Language: und
        Mime:
              video/mpeg, systemstream=(boolean)false, parsed=(boolean)true, mpegversion=(int)
              2, width=(int)720, height=(int)576, framerate=(fraction)25/1, codec_data=(buffer
              )000001b32d02403309c423811011111212121313131314141414141515151515151616161616161
              6171717171717171718181818181818191a191a1a191b1b1b1a1b1c1c1c1c1e1e1e1f1f21000001b
              5148200010000000001b8001909c0
[INFO]  Product Info: i.MX6Q/D/S
vpudec versions :smileyhappy:
        plugin: 4.0.3
        wrapper: 1.0.62(VPUWRAPPER_ARM_LINUX Build on Feb 21 2016 01:52:14)
        vpulib: 5.4.32
        firmware: 3.1.1.46070
Track 01 [audio_000001] Enabled
        ppid: 0, ppid 1
        Duration: 0:00:31.272000000
        Language: und
        Mime:
              audio/mpeg, mpegversion=(int)1, framed=(boolean)true, channels=(int)2, rate=(int
              )48000, bitrate=(int)384
[INFO]  bitstreamMode 1, chromaInterleave 1, mapType 0, tiled2LinearEnable 0
MFW_GST_V4LSINK_PLUGIN 4.0.3 build on Feb 21 2016 02:58:35.
Beep: 4.0.3
Core: MP3 decoder Wrapper  build on Mar 21 2014 15:04:50
  mime: audio/mpeg, mpegversion = (int)1
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_MP3D_ARM_02.13.00_CORTEX-A8  build on Apr 10 2014 15:26:15.
set v4l rotate sucessfully
>>V4L_SINK: Actually buffer status:
        hardware buffer : 10
        software buffer : 0
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
full screen size:1920x1080
[V4L Update Display]: left=0, top=0, width=1920, height=1080
set v4l display crop sucessfully
New clock: GstAudioSinkClock
//==== ctrl+c
^CCaught interrupt -- handling interrupt.
Interrupt: Stopping pipeline ...
(gst-launch-0.10:553): GLib-CRITICAL **: Source ID 75 was not found when attempting to remove it
Execution ended after 134436192350 ns.
//==== ctrl+c
^C
//==== command:  gplay maiken1.mpg
gplay maiken1.mpg
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=maiken1.mpg
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]0:00:00.077219333   507   0xf0ce20 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:374:gst_file_src_set_location: filename : /harddisk/maiken1.mpg
0:00:00.077372666   507   0xf0ce20 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:375:gst_file_src_set_location: uri      : file:///harddisk/maiken1.mpg
0:00:00.079879333   507   0xf0ce20 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
0:00:00.080044333   507   0xf0ce20 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
(gplay:507): GStreamer-CRITICAL **: gst_debug_log_valist: assertion 'category != NULL' failed
0:00:00.105827000   507   0xf0ce20 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
0:00:00.105965666   507   0xf0ce20 INFO                 filesrc /home/ubuntu/yocto/build-fb/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/plugins/elements/gstfilesrc.c:969:gst_file_src_start:<source> opening file /harddisk/maiken1.mpg
Aiur: 4.0.3
Content Info:
        URI:
        Idx File:
        Seekable  : Yes
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : File
        programs    : 1
        Track     : 2
        ppid: 0, ppid 0
        Language: und
        Mime:
        plugin: 4.0.3
        vpulib: 5.4.32
        ppid: 0, ppid 1
        Language: und
        Mime:
FOUND GST_MESSAGE_TAG!
          codec: MPEG2
  language code: und
        bitrate: 4000000
container format: MPEG
    video codec: MPEG2
     frame rate: 25
  video bitrate: 4000000
    image width: 720
   image height: 576
          codec: MP3
  language code: und
        bitrate: 384
Beep: 4.0.3
    audio codec: MPEG 1 Audio, Layer 2
nominal bitrate: 384000
        has crc: FALSE
   channel mode: stereo
number of channels: 2
        bitrate: 384000
sampling frequency (Hz): 48000
    audio codec: MPEG-1 Layer 2
    image width: 720
   image height: 576
        software buffer : 0
minimum bitrate: 384000
maximum bitrate: 384000
fsl_player_play()
FSL_PLAYER_01.00_LINUX build on Feb 21 2016 02:59:27
        [h]display the operation Help
        [p]Play
        [s]Stop
        [e]Seek
        [a]Pause when playing, play when paused
        [v]Volume
        [m]Switch to mute or not
        [>]Play next file
        [<]Play previous file
        [r]Switch to repeated mode or not
        [f]Set full screen or not
        [z]resize the width and height
        [t]Rotate
        [c]Setting play rate
        [i]Display the metadata
        [x]eXit
get GST_MESSAGE_ELEMENT playbin2-stream-changed, uri=(string)file:///harddisk/maiken1.mpg;
[Playing  ][Vol=01][00:00:00/00:00:31][fps:0]
[Playing  ][Vol=01][00:00:00/00:00:31][fps:0]^C Aborted by signal[2] Interrupt...
FSL_PLAYER_UI_MSG_EXIT
Can any body give me some advise? Thanks.
7 返答(返信)
95,879件の閲覧回数
ambika
Hi Bear,
Whether the issue is solved??
Let me know the solution if solved, else whether u got any clues for the issue??
Hi all,
I'm also facing the same issue, below are test environment.
Processor : imx6q
BSP : Yocto
Kernel : 3.14.28
Movie player : gplay-1.0
Audio interface :S/PDIF
I have 2 movies with audio sample rate 44.1K and 48K, I'm playing movie using the below command line,
gplay-1.0 /movie_file
1. When with 48K movie, audio seems fine and video also coming.
2. But when in the case of 44.1K movie, only the 1st frame of the movie can be seen and audio is not coming.
Is anyone faced and solved the issue???
Any suggestions to solve the issue is appreciated.
Thanks in advance.
Ambika.
95,879件の閲覧回数
ambika
The problem was with selecting root clock for playing the movie. The root clock selecting as MLB clock input in failure case, where as other working audio/video was selecting tx_clk input from SPDIF0_CLK_ROOT.
The issue is solved on applying the below patch in dtsi file.
-                        <&clks IMX6QDL_CLK_IPG>,  <&clks IMX6QDL_CLK_MLB>,
+                       <&clks IMX6QDL_CLK_IPG>,  <&clks IMX6QDL_CLK_DUMMY>,
Ambika.
95,876件の閲覧回数
Hi bear
Linux version 3.14.52 provides only GStreamer 1.0 as
mentioned in attached Release Notes sect.6 Multimedia.
Please follow sect.7.3.1.3 Audio/Video file playback attached Linux Guide.
95,876件の閲覧回数
bearq
//==== I Can't hear some voice
  imx6qsabresd:/usr/local/drivers#  aplay -D plughw:0,0 /usr/share/sounds/alsa//Front_Center.wav
  Playing WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
//==== aplay -l
root@imx6qsabresd:/usr/local/drivers# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: imxspdif [imx-spdif], device 0: S/PDIF PCM snd-soc-dummy-dai-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
Do the diffrent of Stereo/Mono cause that problem?
Do the setting of ALSA cause that problem?
Can you give me some advise?
Best Regards
Bear
95,876件の閲覧回数
Hi Bear
what board are you using, could you try with Sabre board and Demo Images on :
Board Support Packages (29)
L3.14.52_1.1.0_MX6QDLSOLO (REV L3.14.52_1.1.0)
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
95,876件の閲覧回数
bearq
Hi Igor
     I use a custom board almost same with Sabre board. If my board run Linux version 3.0.35, the audios play very well.
     But I update Linux version to version 3.14.52, Problems about  audios occur :
(1). I use command:
     root@imx6qsabresd:/harddisk# aplay -D plughw:0,0       /usr/share/sounds/alsa/Front_Center.wav
     aplay will be stuck,It can never play to the ends. I need to press "ctrl+c" to stop it.
root@imx6qsabresd:/harddisk# aplay -vv -D plughw:0,0 /usr/share/sounds/alsa/Front_Center.wav
Plug PCM: Route conversion PCM (sformat=S16_LE)
  Transformation table:
    0 <- 0
    1 <- 0
Its setup is:
  stream       : PLAYBACK
  access       : RW_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 1
  rate         : 48000
  exact rate   : 48000 (48000/1)
  msbits       : 16
  buffer_size  : 16384
  period_size  : 4096
  period_time  : 85333
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 4096
  period_event : 0
  start_threshold  : 16384
  stop_threshold   : 16384
  silence_threshold: 0
  silence_size : 0
  boundary     : 1073741824
Slave: Hardware PCM card 0 'imx-spdif' device 0 subdevice 0
Its setup is:
  stream       : PLAYBACK
  access       : MMAP_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  msbits       : 16
  buffer_size  : 16384
  period_size  : 4096
  period_time  : 85333
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 4096
  period_event : 0
  silence_size : 0
  appl_ptr     : 0
  hw_ptr       : 0
##########              +                          | 46%
^C
It seems aplay have been play first frame.,but never play to second frame.
(2). I use command:
root@imx6qsabresd:/harddisk# aplay -vv -D plughw:0,0 audio8k16S.wav
aplay will play to the end,and i can hear some sound form the S/PDIF
Playing WAVE 'audio8k16S.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Stereo
Plug PCM: Rate conversion PCM (32000, sformat=S16_LE)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
  stream       : PLAYBACK
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 8000
  exact rate   : 8000 (8000/1)
  msbits       : 16
  buffer_size  : 4000
  period_size  : 1000
  period_time  : 125000
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 1000
  period_event : 0
  start_threshold  : 4000
  stop_threshold   : 4000
  silence_size : 0
  boundary     : 524288000
Its setup is:
  stream       : PLAYBACK
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 32000
  exact rate   : 32000 (32000/1)
  msbits       : 16
  buffer_size  : 16000
  period_size  : 4000
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 4000
  period_event : 0
  start_threshold  : 16000
  stop_threshold   : 16000
  silence_size : 0
  boundary     : 2097152000
  appl_ptr     : 0
  hw_ptr       : 0
##  +                                              | 07%
root@imx6qsabresd:/harddisk# aplay -l
  Subdevices: 1/1
root@imx6qsabresd:/harddisk# aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=imxspdif
    imx-spdif,
    Default Audio Device
Best Regards
Bear
95,876件の閲覧回数
bearq
Hi Igor
          Thanks for your reply. I test as "sect.7.3.1.3 Audio/Video file playback" say. But it didn't work.
          Actually, I have do some tests using aplay.
     //==== I Can hear some voice
     imx6qsabresd:/usr/local/drivers# aplay -D plughw:0,0 /harddisk/audio8k16S.w
     Playing WAVE '/harddisk/audio8k16S.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Stereo
