git.freescale.com is no longer, how do I fix my yocto build?
1,073 次查看
nathani
NXP in their infinite wisdom took git.freescale.com offline. My yocto pyro build is now broken. Worse still is it seems that the repositories that are "mirrored" on github now aren't true mirrors. The commit IDs are different. So I now need to bbappen 50+ recipes in order to get things working again.
Thanks NXP.....
标签 (1)
1 回复
1,012 次查看
Bio_TICFSL
Hello Nathan,
I just tested the git.freescale.com and everything seem to work fine, you should have problem with your proxy.
