g2d_blit_2d: fail with status -20
3,266 次查看
yongtang
Hi,FreeScale
     I meet a very strange question on blit image which with G2D_I420,I blit image with physical continued memory as below,if the source image with 576*360,blit success,but if with 480*300,blit failed,how can i fix this?
     int width = 480;
   int height = 300;
   int o_width = 320;
   int o_height = 240;
  g2d_buf* mpInputBuf = g2d_alloc(width * height * 3 / 2, 0);
  g2d_buf* mpOutputBuf = g2d_alloc(o_width * o_height * 4, 0);
   mInputSurface.planes[0] = mpInputBuf->buf_paddr;
   mInputSurface.planes[1] = mpInputBuf->buf_paddr+ a_width*height;
   mInputSurface.planes[2] = mInputSurface.planes[1] + a_width*height / 4;
   mInputSurface.left = 0;
   mInputSurface.top = 0;
   mInputSurface.right = width;
   mInputSurface.bottom = height;
   mInputSurface.stride = width;
   mInputSurface.width  = width;
   mInputSurface.height = height;
   mInputSurface.rot    = G2D_ROTATION_0;
   mInputSurface.format = G2D_I420;
   mInputSurface.blendfunc = G2D_ZERO;
   mInputSurface.global_alpha = 0;     //Global alpha value 0~255
   mInputSurface.clrcolor = 0;
   mOutputSurface.planes[0] = mpOutputBuf->buf_paddr;
   mOutputSurface.left = 0;
   mOutputSurface.top = 0;
   mOutputSurface.right = o_width;
   mOutputSurface.bottom = o_height;
   mOutputSurface.stride = o_width;
   mOutputSurface.width  = o_width;
   mOutputSurface.height = o_height;
   mOutputSurface.rot    = G2D_ROTATION_0;
   mOutputSurface.format = G2D_RGBA8888;
   mOutputSurface.blendfunc = G2D_SRC_ALPHA;//G2D_ZERO;
   mOutputSurface.global_alpha = 0;     //Global alpha value 0~255
   mOutputSurface.clrcolor = 0;
   if(0 != g2d_make_current(mhG2d, G2D_HARDWARE_2D))
      return -4;
   g2d_enable(mhG2d,G2D_BLEND);
   if(0 != g2d_blit(mhG2d, &mInputSurface, &mOutputSurface))
      g2d_finish(mhG2d);
      return -5;
   g2d_disable(mhG2d, G2D_BLEND);
   if(0 != g2d_finish(mhG2d))
      return -6;
标记 (2)
2,089 次查看
Hi yong
recommended to try latest Vivante v5.0.11p7.4 gpu library (included
in L3.14.52), attached document Table 9. New features shows its
improvements.
