Hi navanisrivastana,
you can set this bit as part of USB reset sequence in file
<ltib_dir>/rpm/BUILD/linux/arch/arm/plat-mxc/usb_common.c
Speed can not changed dynamically, in particular sect.
9.2.6.6 "Speed Dependent Descriptors" USB 2.0 specification states:
"A device also operates at a single speed after completing the reset
sequence. In particular, there is no speed switch during normal operation."
