[flexbuild v24.12][imx8mpevk] debian build failed in ml(tflite_ethosu_delegate)
5,909件の閲覧回数
yoooh8668
We are now trying the flexbuild of Debian 12, but it build failed on "tflite_ethosu_delegate"
We know the in v24.06 does not include the ml(machine learning) in build process.
But we do want to enable the ml in debian.
Here is the log:
[root@fbdebian tn_debian_flexbuild]$ bld tflite_ethosu_delegate
Building tflite_ethosu_delegate ...
repo: tflite_ethosu_delegate
tag: lf-6.6.36-2.1.0
-- Setting build type to Release, for debug builds use'-DCMAKE_BUILD_TYPE=Debug'.
-- Cloning absl repository revision fb3621f4f897824c0dbe0615fa94543df6192f30, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/absl/workspace.bzl
CMake Warning at build_debian_arm64/abseil-cpp/CMakeLists.txt:77 (message):
  A future Abseil release will default ABSL_PROPAGATE_CXX_STD to ON for CMake
  3.8 and up.  We recommend enabling this option to ensure your project still
  builds correctly.
-- Cloning eigen repository revision aa6964bf3a34fd607837dd8123bc42465185c4f8, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/eigen3/workspace.bzl
-- Standard libraries to link to explicitly: none
-- The Fortran compiler identification is unknown
-- Could NOT find CLANG_FORMAT: Found unsuitable version "0.0", but required is exact version "9" (found CLANG_FORMAT_EXECUTABLE-NOTFOUND)
-- Configured Eigen 3.4.90
-- Cloning farmhash repository revision 0d859a811870d10f53a594927d0d0b97573ad06d, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/farmhash/workspace.bzl
-- Cloning fft2d repository from https://storage.googleapis.com/mirror.tensorflow.org/github.com/petewarden/OouraFFT/archive/v1.0.tar.gz, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/workspace2.bzl
CMake Warning (dev) at /usr/share/cmake-3.25/Modules/FetchContent.cmake:1279 (message):
  The DOWNLOAD_EXTRACT_TIMESTAMP option was not given and policy CMP0135 is
  not set.  The policy's OLD behavior will be used.  When using a URL
  download, the timestamps of extracted files should preferably be that of
  the time of extraction, otherwise code that depends on the extracted
  contents might not be rebuilt if the URL changes.  The OLD behavior
  preserves the timestamps from the archive instead, but this is usually not
  what you want.  Update your project to the NEW behavior or specify the
  DOWNLOAD_EXTRACT_TIMESTAMP option with a value of true to avoid this
  robustness issue.
Call Stack (most recent call first):
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/OverridableFetchContent.cmake:398 (FetchContent_Declare)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/fft2d.cmake:25 (OverridableFetchContent_Declare)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/Findfft2d.cmake:18 (include)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/CMakeLists.txt:166 (find_package)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Cloning flatbuffers repository from https://github.com/google/flatbuffers/archive/7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/flatbuffers/workspace.bzl
-- Cloning flatbuffers repository revision 7d6d99c6befa635780a4e944d37ebfd58e68a108, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/flatbuffers/workspace.bzl
  robustness issue.
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/flatbuffers.cmake:33 (OverridableFetchContent_Declare)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/FindFlatBuffers.cmake:18 (include)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/CMakeLists.txt:167 (find_package)
-- Proceeding with version: 23.5.26.0
-- CMAKE_CXX_FLAGS: -O2 -pipe -g -fPIC -feliminate-unused-debug-types -I/home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include -I/home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/rfs/rootfs_lsdk2412_debian_desktop_arm64/usr/include
-- Cloning gemmlowp repository revision 16e8662c34917be0065110bfcd9cc27d30f52fdf, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/gemmlowp/workspace.bzl
-- Cloning neon2sse repository from https://storage.googleapis.com/mirror.tensorflow.org/github.com/intel/ARM_NEON_2_x86_SSE/archive/a15b489e1222b2087007546b4912e21293ea86ff.tar.gz, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/workspace2.bzl
  robustness issue.
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/neon2sse.cmake:25 (OverridableFetchContent_Declare)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/tools/cmake/modules/FindNEON_2_SSE.cmake:18 (include)
  /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/CMakeLists.txt:170 (find_package)
-- Cloning cpuinfo repository revision ef634603954d88d2643d5809011288b890ac126e, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/workspace2.bzl
-- Cloning ruy repository revision 3286a34cc8de6149ac6844107dfdffac91531e72, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/../third_party/ruy/workspace.bzl
-- Cloning xnnpack repository revision dcbfffb80fb4f6fcfcfb5b3723854ec8797fa546, found in /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/workspace2.bzl
-- Could NOT find Python (missing: Interpreter Development Development.Module Development.Embed) (found version "3.11.2")
-- Configuring done
-- Generating done
-- Build files have been written to: /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/build_debian_arm64
Building CXX object CMakeFiles/ethosu_delegate.dir/ethosu_delegate.cc.o
Building CXX object CMakeFiles/ethosu_delegate.dir/ethosu_delegate_utils.cc.o
Building CXX object CMakeFiles/ethosu_delegate.dir/ethosu_supported_ops.cc.o
In file included from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:83,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/optimized/optimized_ops.h:56,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/ethosu_supported_ops.cc:10:
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:28:36: error: 'StringRef' does not name a type
   28 | inline bool StringRefEqualFn(const StringRef& lhs, const StringRef& rhs) {
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:28:58: error: 'StringRef' does not name a type
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h: In function 'bool tflite::reference_ops::StringRefEqualFn(const int&, const int&)':
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:29:11: error: request for member 'len' in 'lhs', which is of non-class type 'const int'
   29 |   if (lhs.len != rhs.len) return false;
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:29:22: error: request for member 'len' in 'rhs', which is of non-class type 'const int'
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:30:27: error: request for member 'len' in 'lhs', which is of non-class type 'const int'
   30 |   for (int i = 0; i < lhs.len; ++i) {
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:31:13: error: request for member 'str' in 'lhs', which is of non-class type 'const int'
   31 |     if (lhs.str[i] != rhs.str[i]) return false;
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:31:27: error: request for member 'str' in 'rhs', which is of non-class type 'const int'
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h: At global scope:
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:36:39: error: 'StringRef' does not name a type
   36 | inline bool StringRefNotEqualFn(const StringRef& lhs, const StringRef& rhs) {
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:36:61: error: 'StringRef' does not name a type
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:40:50: error: 'StringRef' does not name a type
   40 | inline void ComparisonStringImpl(bool (*F)(const StringRef&, const StringRef&),
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:40:68: error: 'StringRef' does not name a type
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h: In function 'void tflite::reference_ops::ComparisonStringImpl(bool (*)(const int&, const int&), const tflite::RuntimeShape&, const TfLiteTensor*, const tflite::RuntimeShape&, const TfLiteTensor*, const tflite::RuntimeShape&, bool*)':
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:50:22: error: 'GetString' was not declared in this scope; did you mean 'testing'?
   50 |     const auto lhs = GetString(input1, i);
      |                      testing
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:57:21: error: 'StringRef' does not name a type
   57 |     bool (*F)(const StringRef&, const StringRef&),
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:57:39: error: 'StringRef' does not name a type
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h: In function 'void tflite::reference_ops::BroadcastComparison4DSlowStringImpl(bool (*)(const int&, const int&), const tflite::RuntimeShape&, const TfLiteTensor*, const tflite::RuntimeShape&, const TfLiteTensor*, const tflite::RuntimeShape&, bool*)':
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:71:15: error: 'GetString' was not declared in this scope; did you mean 'testing'?
   71 |               GetString(input1, SubscriptToIndex(dims.desc1, b, y, x, c));
      |               testing
In file included from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:89:
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/tensor.h: At global scope:
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/tensor.h:26:30: error: 'string' was not declared in this scope; did you mean 'std::string'?
   26 | class SequentialTensorWriter<string> {
      |                              std::string
In file included from /usr/aarch64-linux-gnu/include/c++/12/iosfwd:39,
                 from /usr/aarch64-linux-gnu/include/c++/12/bits/shared_ptr.h:52,
                 from /usr/aarch64-linux-gnu/include/c++/12/memory:77,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/optimized/optimized_ops.h:26:
/usr/aarch64-linux-gnu/include/c++/12/bits/stringfwd.h:77:33: note: 'std::string' declared here
   77 |   typedef basic_string<char>    string;
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/tensor.h:26:36: error: template argument 1 is invalid
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h: In function 'TfLiteStatus tflite::reference_ops::GatherNdString(const tflite::RuntimeShape&, const TfLiteTensor*, const tflite::RuntimeShape&, const IndicesT*, const tflite::RuntimeShape&, TfLiteTensor*)':
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:641:3: error: 'DynamicBuffer' was not declared in this scope
  641 |   DynamicBuffer buffer;
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:7: error: 'buffer' was not declared in this scope; did you mean 'setbuffer'?
  651 |       buffer.AddString(GetString(params_data, from_pos + j));
      |       setbuffer
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:24: error: there are no arguments to 'GetString' that depend on a template parameter, so a declaration of 'GetString' must be available [-fpermissive]
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:24: note: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:654:3: error: 'buffer' was not declared in this scope; did you mean 'setbuffer'?
  654 |   buffer.WriteToTensor(output_data, /*new_shape=*/nullptr);
      |   setbuffer
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/ethosu_delegate_utils.h:16,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/ethosu_delegate.cc:27:
      |                      testing
      |               testing
      |                              std::string
In file included from /usr/aarch64-linux-gnu/include/c++/12/string:39,
                 from /home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/base.h:41,
                 from /home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/flexbuffers.h:23,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/ethosu_delegate.cc:23:
      |       setbuffer
      |   setbuffer
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/ethosu_delegate_utils.cc:9:
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:50:22: error: 'GetString' was not declared in this scope; did you mean 'flatbuffers::GetString'?
In file included from /home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/flatbuffer_builder.h:34,
                 from /home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/flatbuffers.h:29,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/schema/schema_generated.h:21,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/tflite_enum_mapping.h:19,
                 from /home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite_ethosu_delegate/ethosu_delegate_utils.cc:8:
/home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/string.h:44:27: note: 'flatbuffers::GetString' declared here
   44 | static inline std::string GetString(const String *str) {
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/string_comparisons.h:71:15: error: 'GetString' was not declared in this scope; did you mean 'flatbuffers::GetString'?
      |                              std::string
                 from /home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/array.h:21,
                 from /home/joezhang/workspace/tn_debian_flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/flatbuffers.h:24:
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:7: error: 'buffer' was not declared in this scope; did you mean 'Buffer'?
      |       Buffer
/home/joezhang/workspace/tn_debian_flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:654:3: error: 'buffer' was not declared in this scope; did you mean 'Buffer'?
      |   Buffer
make[5]: *** [CMakeFiles/ethosu_delegate.dir/build.make:160: CMakeFiles/ethosu_delegate.dir/ethosu_supported_ops.cc.o] Error 1
make[5]: *** Waiting for unfinished jobs....
make[5]: *** [CMakeFiles/ethosu_delegate.dir/build.make:104: CMakeFiles/ethosu_delegate.dir/ethosu_delegate.cc.o] Error 1
make[5]: *** [CMakeFiles/ethosu_delegate.dir/build.make:146: CMakeFiles/ethosu_delegate.dir/ethosu_delegate_utils.cc.o] Error 1
make[4]: *** [CMakeFiles/Makefile2:1258: CMakeFiles/ethosu_delegate.dir/all] Error 2
make[3]: *** [CMakeFiles/Makefile2:1265: CMakeFiles/ethosu_delegate.dir/rule] Error 2
make[2]: *** [Makefile:169: ethosu_delegate] Error 2
make[1]: *** [/home/joezhang/workspace/tn_debian_flexbuild/src/apps/ml/tflite_ethosu_delegate.mk:11: tflite_ethosu_delegate] Error 2
make: *** [Makefile:21: tflite_ethosu_delegate] Error 2
Look like there is dependency issue in tensorflow => missing llvm(`StringRef`) library?
But `apt-get install llvm` in docker won't fix.
Add llvm in target rootfs won't fix, too.
joezhang@joezhang-System-Product-Name:~/workspace/tn_debian_flexbuild$ git diff
diff --git a/configs/debian/extra_packages_list b/configs/debian/extra_packages_list
index 54dede1..9064951 100644
--- a/configs/debian/extra_packages_list
+++ b/configs/debian/extra_packages_list
@@ -95,6 +95,7 @@ extra_server_devel_packages=" \
     libvorbis-dev \
     libjpeg62-turbo-dev \
     libjsoncpp-dev \
+    llvm-dev \
Or I missing something in build process?
$ bld docker
$ . setup.env
$ bld host-dep
$ bld apps -p IMX
# failed here...
THANKS~~~
Joe
タグ(3)
22 返答(返信)
3,656件の閲覧回数
Zhiming_Liu
Hello guys,
The next version has fixed this issue,
Please try the latest tflite makefile
# Copyright 2022-2024 NXP
# SPDX-License-Identifier: BSD-3-Clause
# TensorFlow Lite C++ Library
# Version: 2.16.2
# DEPEND: protobuf-compiler + libprotobuf-dev + libprotoc-dev for protoc on host
# libpython3.11-dev python3-pybind11 on target
# run ./benchmark_model --external_delegate_path=<patch_to_libvx_delegate.so> --graph=<tflite_model.tflite>
model-mobv1 = https://storage.googleapis.com/download.tensorflow.org/models/mobilenet_v1_2018_08_02/mobilenet_v1_1.0_224_quant.tgz
TFLITE_VERSION = tensorflow-lite-2.16.2
tflite:
	@[ $(SOCFAMILY) != IMX -o $(DISTROVARIANT) = tiny -o $(DISTROVARIANT) = base ] && exit || \
	 $(call fbprint_b,"tensorflow-lite") && \
	 $(call repo-mngr,fetch,tflite,apps/ml) && \
	 cd $(MLDIR)/tflite && \
	 if [ -f .builddone ]; then \
	     $(call fbprint_n,"TensorFlow-lite has been compiled already.") ; \
	     $(call fbprint_n,"Skip...") && exit ; \
	 fi && \
	 [ ! -f mobilenet.tgz ] && wget -q $(model-mobv1) -O mobilenet.tgz && tar xf mobilenet.tgz || true && \
	 export CC="$(CROSS_COMPILE)gcc --sysroot=$(RFSDIR)" && \
	 export CXX="$(CROSS_COMPILE)g++ --sysroot=$(RFSDIR)" && \
	 mkdir -p build_$(DISTROTYPE)_$(ARCH) && \
	 cmake  -S tensorflow/lite \
		-B build_$(DISTROTYPE)_$(ARCH) \
		-DCMAKE_BUILD_TYPE=release \
		-DCMAKE_SYSTEM_NAME=Linux \
		-DCMAKE_SYSTEM_PROCESSOR=aarch64 \
		-DTFLITE_HOST_TOOLS_DIR=/usr/bin \
		-DFETCHCONTENT_FULLY_DISCONNECTED=OFF \
		-DTFLITE_EVAL_TOOLS=on \
		-DTFLITE_BUILD_SHARED_LIB=on \
		-DTFLITE_ENABLE_NNAPI=off \
		-DTFLITE_ENABLE_NNAPI_VERBOSE_VALIDATION=on \
		-DTFLITE_ENABLE_RUY=on \
		-DTFLITE_ENABLE_XNNPACK=on \
		-DTFLITE_PYTHON_WRAPPER_BUILD_CMAKE2=on \
		-DTFLITE_ENABLE_EXTERNAL_DELEGATE=on && \
	 VERBOSE=0 cmake --build build_$(DISTROTYPE)_$(ARCH) -j$(JOBS) --target all -- benchmark_model label_image && \
	 cd build_$(DISTROTYPE)_$(ARCH) && \
	 CI_BUILD_PYTHON=python3 BUILD_NUM_JOBS=$(JOBS) \
	 $(MLDIR)/tflite/tensorflow/lite/tools/pip_package/build_pip_package_with_cmake2.sh aarch64 && \
	 $(CROSS_COMPILE)strip libtensorflow-lite.so* && \
	 cp -Pf libtensorflow-lite.so* $(DESTDIR)/usr/lib && \
	 install -d $(DESTDIR)/usr/include/tensorflow/lite && \
	 install -d $(DESTDIR)/usr/share/pkgconfig && \
	 install -d $(DESTDIR)/usr/include/tensorflow/core/public && \
	 install -d $(DESTDIR)/usr/include/tensorflow/core/platform && \
	 install -d $(DESTDIR)/usr/include/tsl/platform && \
	 install -d $(DESTDIR)/usr/lib/python3.11/site-packages && \
	 cd $(MLDIR)/tflite/tensorflow/lite && \
	 find . -name "*.h" | xargs -I {} cp {} $(DESTDIR)/usr/include/tensorflow/lite && \
	 cp $(MLDIR)/tflite/tensorflow/core/public/version.h $(DESTDIR)/usr/include/tensorflow/core/public && \
	 rsync -avz $(MLDIR)/tflite/tensorflow/* $(DESTDIR)/usr/include/tensorflow/ && \
	 cp $(FBDIR)/src/system/pkgconfig/tensorflow2-lite.pc $(DESTDIR)/usr/lib/pkgconfig && \
	 $(call fbprint_n,"install examples") && \
	 install -d $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 cd $(MLDIR)/tflite/build_$(DISTROTYPE)_$(ARCH) && \
	 $(CROSS_COMPILE)strip examples/label_image/label_image tools/benchmark/benchmark_model \
	     tools/evaluation/{coco_object_detection_run_eval,imagenet_image_classification_run_eval,inference_diff_run_eval} && \
	 install -m 0555 examples/label_image/label_image $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 install -m 0555 tools/benchmark/benchmark_model $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 install -m 0555 tools/evaluation/{coco_object_detection_run_eval,imagenet_image_classification_run_eval,inference_diff_run_eval} \
	 $(call fbprint_n,"install label_image data") && \
	 cp $(MLDIR)/tflite/tensorflow/lite/examples/label_image/testdata/grace_hopper.bmp $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 cp $(MLDIR)/tflite/tensorflow/lite/java/ovic/src/testdata/labels.txt $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 $(call fbprint_n,"install mobilenet tflite file python example and pip package") && \
	 cp $(MLDIR)/tflite/mobilenet_*.tflite $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 cp $(MLDIR)/tflite/tensorflow/lite/examples/python/label_image.py $(DESTDIR)/usr/bin/$(TFLITE_VERSION)/examples && \
	 pip3 install --ignore-installed --disable-pip-version-check -vvv --platform linux_aarch64 -t $(DESTDIR)/usr/lib/python3.11/site-packages \
		--no-cache-dir --no-deps $(MLDIR)/tflite/build_$(DISTROTYPE)_$(ARCH)/tflite_pip/dist/tflite_runtime-*.whl && \
	 #rm -rf $(DESTDIR)/usr/include/tensorflow/lite/{interpreter.h,util.h} && \
	 touch .builddone && \
	 $(call fbprint_d,"tflite")
Zhiming
3,597件の閲覧回数
David_Lu
It works.
Thanks a lot.
4,533件の閲覧回数
Zhiming_Liu
Hi @yoooh8668  @lvasa3091 @JasonFSYang @charleshuang @Edward_desplaines
Update:
I test again referring on this github issues and it can be successfully compiled.
https://github.com/NXP/flexbuild/issues/11#issuecomment-2561862237
4,413件の閲覧回数
yoooh8668
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/tensor.h: At global scope:
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/tensor.h:26:30: error: 'string' was not declared in this scope; did you mean 'std::string'?
      |                              std::string
                 from /home/joezhang/workspace/tn_debian_flexbuild_v24.12/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/array.h:21,
                 from /home/joezhang/workspace/tn_debian_flexbuild_v24.12/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/flatbuffers/flatbuffers.h:24:
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/tensor.h:26:36: error: template argument 1 is invalid
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h: In function 'TfLiteStatus tflite::reference_ops::GatherNdString(const tflite::RuntimeShape&, const TfLiteTensor*, const tflite::RuntimeShape&, const IndicesT*, const tflite::RuntimeShape&, TfLiteTensor*)':
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:641:3: error: 'DynamicBuffer' was not declared in this scope
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:7: error: 'buffer' was not declared in this scope; did you mean 'Buffer'?
      |       Buffer
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:24: error: there are no arguments to 'GetString' that depend on a template parameter, so a declaration of 'GetString' must be available [-fpermissive]
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:651:24: note: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/internal/reference/reference_ops.h:654:3: error: 'buffer' was not declared in this scope; did you mean 'Buffer'?
      |   Buffer
make[5]: Leaving directory '/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite_ethosu_delegate/build_debian_arm64'
make[4]: Leaving directory '/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite_ethosu_delegate/build_debian_arm64'
make[3]: Leaving directory '/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite_ethosu_delegate/build_debian_arm64'
make[2]: Leaving directory '/home/joezhang/workspace/tn_debian_flexbuild_v24.12/components_lsdk2412/apps/ml/tflite_ethosu_delegate/build_debian_arm64'
make[1]: *** [/home/joezhang/workspace/tn_debian_flexbuild_v24.12/src/apps/ml/tflite_ethosu_delegate.mk:11: tflite_ethosu_delegate] Error 2
make[1]: Leaving directory '/home/joezhang/workspace/tn_debian_flexbuild_v24.12/src/apps'
make: *** [Makefile:11: apps] Error 2
make: Leaving directory '/home/joezhang/workspace/tn_debian_flexbuild_v24.12/src'
@Zhiming_Liu
still got error on my computer,
[root@fbdebian tn_debian_flexbuild_v24.12]$ git diff
diff --git a/src/apps/ml/tflite.mk b/src/apps/ml/tflite.mk
index 3d5957b..ba135a5 100644
--- a/src/apps/ml/tflite.mk
+++ b/src/apps/ml/tflite.mk
@@ -51,7 +51,7 @@ tflite:
-        find . -name "*.h" | xargs -I {} cp {} $(DESTDIR)/usr/include/tensorflow/lite && \
+        find . -name "*.h" | grep -v lite/testing | xargs -I {} cp {} $(DESTDIR)/usr/include/tensorflow/lite && \
I removed the components/build folder before run bld command.
5,180件の閲覧回数
JasonFSYang
Dear Sirs,
I am having the same issue, any updates?
5,078件の閲覧回数
yoooh8668
From 9db918fa37e9448b4cb91dc8b5886166af297326 Mon Sep 17 00:00:00 2001
Date: Fri, 17 Jan 2025 07:34:08 +0000
Subject: [PATCH] flexbuild: disable ml component
 configs/technexion.yml                | 2 +-
 src/apps/gopoint/imx_smart_fitness.mk | 2 +-
 tools/create_bootpartition            | 5 +++--
 3 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/configs/technexion.yml b/configs/technexion.yml
index 625b99a..684ab09 100644
--- a/configs/technexion.yml
+++ b/configs/technexion.yml
@@ -26,7 +26,7 @@ PKG_GROUPS_NETWORKING: y
 PKG_GROUPS_CONNECTIVITY: y
 PKG_GROUPS_UTILS: y
 PKG_GROUPS_SECURITY: y
-PKG_GROUPS_ML: y
+PKG_GROUPS_ML: n
 PKG_GROUPS_GOPOINT: y
 PKG_GROUPS_ROBOTICS: n
diff --git a/src/apps/gopoint/imx_smart_fitness.mk b/src/apps/gopoint/imx_smart_fitness.mk
index ff57b8d..26fa46f 100644
--- a/src/apps/gopoint/imx_smart_fitness.mk
+++ b/src/apps/gopoint/imx_smart_fitness.mk
@@ -11,7 +11,7 @@ GPNT_APPS_FOLDER = /opt/gopoint-apps
 IMX_SMART_FITNESS_DIR = $(GPNT_APPS_FOLDER)/scripts/machine_learning/imx_smart_fitness
 imx_smart_fitness:
-	@[ $(SOCFAMILY) != IMX -o $(DISTROVARIANT) != desktop ] && exit || \
+	@[ $(SOCFAMILY) != IMX -o $(DISTROVARIANT) != desktop -o ${PKG_GROUPS_ML} != y ] && exit || \
 	 $(call fbprint_b,"imx_smart_fitness") && \
 	 $(call repo-mngr,fetch,imx_smart_fitness,apps/gopoint) && \
 	 if [ ! -f $(DESTDIR)/usr/lib/gstreamer-1.0/libnnstreamer.so ]; then \
diff --git a/tools/create_bootpartition b/tools/create_bootpartition
index 0c9e758..92cca87 100644
--- a/tools/create_bootpartition
+++ b/tools/create_bootpartition
@@ -50,7 +50,7 @@ generate_bootpartition_tarball() {
 	[ ! -d $FBOUTDIR/bsp/imx_firmware/lib/firmware/imx/dsp ] && bld imx_dsp -a $DESTARCH -p $SOCFAMILY
 	[ ! -d $FBOUTDIR/bsp/imx_firmware/lib/firmware/imx/easrc ] && bld imx_firmware -a $DESTARCH -p $SOCFAMILY
 	[ ! -d $FBOUTDIR/bsp/imx_mcore_demos/imx93-m33-demo ] && bld mcore_demo -a $DESTARCH -p $SOCFAMILY
-	[ ! -d $DESTDIR/usr/lib/ethosu_firmware ] && bld ethosu_firmware -a $DESTARCH -p $SOCFAMILY
+	[ ! -d $DESTDIR/usr/lib/ethosu_firmware ] && [ "$PKG_GROUPS_ML" = y ] && bld ethosu_firmware -a $DESTARCH -p $SOCFAMILY
 	cp -Prf $FBOUTDIR/bsp/imx_firmware/lib/firmware/* $bootpartdir/firmware
     fi
@@ -129,7 +129,8 @@ generate_bootpartition_tarball() {
                 dtb=${brd}*.dtb*
             fi
             ( echo $brd | grep -qE "imx93" ) && \
-                cp -Prf $FBOUTDIR/bsp/imx_mcore_demos/imx93-m33-demo/imx93-*m33*.elf $DESTDIR/usr/lib/ethosu_firmware $bootpartdir/firmware
+                cp -Prf $FBOUTDIR/bsp/imx_mcore_demos/imx93-m33-demo/imx93-*m33*.elf $bootpartdir/firmware && \
+		[ "$PKG_GROUPS_ML" = y ] && cp -Prf $DESTDIR/usr/lib/ethosu_firmware $bootpartdir/firmware
             ls $FBOUTDIR/bsp/u-boot/$socseries*/${brd}*_boot.scr | xargs -I {} cp -v {} $bootpartdir
             cp -f $FBOUTDIR/linux/kernel/$DESTARCH/$SOCFAMILY/${dtb} $bootpartdir
             boottarball=${bootpartname}_${brd}_lts_${kernelver}${imaevmopt}_${timestamp}
2.39.5
This patch disable ML, you can try to apply it.
5,168件の閲覧回数
Zhiming_Liu
Hi @JasonFSYang
Please refer this reply:
5,458件の閲覧回数
Zhiming_Liu
Hi all @yoooh8668 @charleshuang @Edward_desplaines
This could be a BUG as I can see same error about Could NOT find CLANG_FORMAT based on Ubuntu22.04(VMware virtual machine).
Have shared this issue with maintainer.
Zhiming
5,424件の閲覧回数
Zhiming_Liu
Hello all @yoooh8668  @charleshuang  @Edward_desplaines
Temporary solution:
1. Keep PKG_GROUPS_ML: y in sdk.yml
2. Comment these packages in ml.yml
3. Delete the .mk file about these packages.
The flexbuild will be updated after fixing this tflite issue.
Update: Gopoint also need to be removed. Any package has Tensorflow dependency should be removed
Zhiming
3,669件の閲覧回数
don_gunn
Contributor V
Is there a proper patch that has been created to resolve this issue?
5,541件の閲覧回数
charleshuang
Senior Contributor II
Hi all  and @Zhiming_Liu
I still have the issue about host PC Ubuntu 22.04.
We tried using an Azure VM and follow the NXP SOP.
If possible, do you have sop that compiler it without ml.
5,704件の閲覧回数
yoooh8668
I know:
For imx93:
 For imx8M:
tflite_vx_delegate.mk
But both of them build failed and require StringRef.
For each target in apps/ml:
sudo apt-get install python3-pybind11 protobuf-compiler
(pass)|-- eiq_examples.mk
(pass)|-- ethosu_driver_stack.mk
(pass)|-- ethosu_firmware.mk
(pass)|-- ethosu_vela.mk
(pass)|-- flatbuffers.mk
(pass)|-- nnshark.mk
(pass)|-- nnstreamer.mk
(pass)|-- nnstreamer_edge.mk
(CONFIG_PYTORCH not define)|-- pytorch.mk
(pass)|-- ssat.mk
(pass)|-- tflite.mk
(NG)|-- tflite_ethosu_delegate.mk
(NG)|-- tflite_vx_delegate.mk => NG
(pass)|-- tim_vx.mk
(pass)`-- tvm.mktflite_ethosu_delegate
 THANKS~~
Joe
5,675件の閲覧回数
Zhiming_Liu
We built it from debian docker with ML feature, there is no such issue when in our serveal tests.
You can try to delete the docker container and delete the rootfs build folder in flexbuild as the tflite_ethosu_delegate relies on the debian12 rootfs(not debian docker rootfs).
Zhiming
5,656件の閲覧回数
yoooh8668
Does there any specific environment requirement?
On host of 20.04LTS(v5.4 kernel), it will failed on nnstreamer, and 22.04LTS (v6.8) won't.
Both of them use the same docker image, and run the same command.
Why them got different result?
What's your host environment?
THANKS~~
Joe
5,653件の閲覧回数
Zhiming_Liu
The host environment is Ubuntu22.04 on our side. Referring the makefile of tflite_ethosu_delegate, the building should use python environment in container. But from the information you provided, it looks like relate to host python environment.. I need check this with maintainer. Please use Ubunut22.04 as host environment.
Zhiming
5,571件の閲覧回数
yoooh8668
Tested host environment: 18.04, 20.04, 22.04(x2).
Unfortunately, the only one who can build tflite_ethosu/vx_delegate is Ubuntu 18.04LTS...
All of the need to patch nnstreamer (expect one of the 22.04 computer).
Seems the build env is not isolated with host...
Still don't know what cause this happen.
And except for the 18.04LTS host, we need to disable the NPU makefile to complete the build...
THANKS~~
Joe
5,506件の閲覧回数
Zhiming_Liu
--->Yes, from your tests, it looks like the containers still rely on the host environment. This is very strange. Let me try to test under different WSL Ubuntu version.
@Edward_desplaines @yoooh8668 @charleshuang
To remove the ML feature,  set the PKG_GROUPS_ML:n here https://github.com/NXP/flexbuild/blob/LSDK-24.12_DEBIAN-12_LF-6.6.36/configs/sdk.yml
Zhiming
5,486件の閲覧回数
charleshuang
Hi @Zhiming_Liu
Follow your suggest : set the PKG_GROUPS_ML:n
We still can not compiler to success.
Building isp_vvcam_module ...
isp_vvcam_module [Done]
linux-modules [Done]
Installing kernel and dtb ...
Installing kernel modules ...
SOCFAMILY: IMX
Building sof_zephyr ...
sof_zephyr [Done]
SOCFAMILY: IMX
make: *** No rule to make target 'ethosu_firmware'. Stop.
[root@fbdebian flexbuild]$
4,769件の閲覧回数
lvasa3091
Hello! I did it - PKG_GROUPS_ML:n, delete the build_lsdk2412 folder. But the result - "make: *** No rule to make target 'ethosu_firmware'. Stop."
4,758件の閲覧回数
yoooh8668
