flashing im8xx with Android 10 with emmc 8G
YanHo0103
Can I flash with emmc 8G board that we designed for Andriod 10?
Having problem flashing it.
Can anyone help?
Rita_Wang
Recommend you to use 16 GB or larger , here if you already designed you can try to modify the partition, the default support is used for 16 GB SD card and eMMC. Details you can see the android user guide.
