failed to enable l2 cache on imx6d
1,547 次查看
jiaojinxing
hello , i have ported sylixos(an rtos from china) to imx6d cpu which work at smp mode
i have a question, when i enable l2 cache, i write pl310 control register to 0x01, but i read it again, i found its value is 0x00, this mean i enable l2 cache failed,
why?
标记 (2)
1,368 次查看
AnsonHuang
Hi, jinxing
     Which register you wrote? The PL310's enable reg offset is 0x100, so you need to write 0x1 to 0xa02100.
