failed to build tensorflow on offline machine for imx8mp Scarthgap
1,355 次查看
greeran
I’m building the fsl-image-qt6 image for i.MX8MP with Scarthgap. I built it on an online machine and copied the downloads directory to the offline machine. I’ve successfully used this workflow many times before with other BSP releases (Kirkstone, Zeus, and others), so this isn’t my first offline BSP build.
However, when I try to build the same image on the offline machine, the build fails at tensorflow-lite-tools-native. It seems to attempt cloning extended third-party dependencies (protobuf, etc.), and the downloaded tar.gz files are not sufficient to satisfy it.
Has anyone come across this issue before? If so, what’s the recommended way to resolve it?
Thanks in advance
6 回复数
1,018 次查看
greeran
i delete all my build, download and sstate and rebuild from scratch. the build was long but successful. i then removed the build_xwayland directory (and kept the downloads and sstate path in the site.conf). i added this flags to the
BB_NO_NETWORK = "1"
BB_FETCH_PREMIRRORONLY = "1"
i removed the internet cable to simulate my offline computer. when running the bitbake fsl-image-qt6 it fails in the parsing
WARNING: /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb: Exception during build_dependencies for fetcher_hashes_dummyfunc | ETA: 0:00:04
WARNING: /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb: Error during finalise of /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb
ERROR: ExpansionError during parsing /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb
Traceback (most recent call last):
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 1248, in srcrev_internal_helper(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
d.setVar("__BBAUTOREV_ACTED_UPON", True)
> srcrev = ud.method.latest_revision(ud, d, name)
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 1670, in GitSM.latest_revision(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
except KeyError:
> revs[key] = rev = self._latest_revision(ud, d, name)
return rev
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/git.py", line 850, in GitSM._latest_revision(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
> output = self._lsremote(ud, d, "")
# Tags of the form ^{} may not work, need to fallback to other form
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/git.py", line 832, in GitSM._lsremote(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, search=''):
if ud.proto.lower() != 'file':
> bb.fetch2.check_network_access(d, cmd, repourl)
output = runfetchcmd(cmd, d, True)
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 970, in check_network_access(d=<bb.data_smart.DataSmart object at 0x78233207c820>, info='git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://github.com/NXP/matter.git ', url='https://github.com/NXP/matter.git'):
if bb.utils.to_boolean(d.getVar("BB_NO_NETWORK")):
> raise NetworkAccess(url, info)
elif not trusted_network(d, url):
bb.data_smart.ExpansionError: Failure expanding variable fetcher_hashes_dummyfunc[vardepvalue], expression was ${@bb.fetch.get_hashvalue(d)} which triggered exception NetworkAccess: Network access disabled through BB_NO_NETWORK (or set indirectly due to use of BB_FETCH_PREMIRRORONLY) but access requested with command git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://github.com/NXP/matter.git (for url https://github.com/NXP/matter.git)
The variable dependency chain for the failure is: fetcher_hashes_dummyfunc[vardepvalue]
ERROR: Parsing halted due to errors, see error messages above
Summary: There were 2 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
to fix it i need to connect to the internet and then run bitbake fsl-image-qt6 --runall=fetch and then offline build works. the problem that in the offline machine i will not be able to do the runall=fetch.
might you know what my error is and why i am not able to build offline
thanks
1,278 次查看
greeran
thanks for the response
i am sending the manifests from the repo and the error i get. i tried downloading the download twice and i still get the same error when running in offline (BB_NO_NETWORK = "1" and BB+GENERATE_MIRROR_TARBALLS  = "1" )
<manifest>
<include name="imx-6.6.52-2.2.0.xml" />
</manifest>
this is the manifests from the repo
<manifest>
<default revision="scarthgap" sync-j="4"/>
<remote name="yp" fetch="https://git.yoctoproject.org"/>
<remote name="yp-gh" fetch="https://github.com/yoctoproject"/>
<remote name="oe" fetch="https://github.com/openembedded"/>
<remote name="kraj" fetch="https://github.com/kraj"/>
<remote name="community" fetch="https://github.com/Freescale"/>
<remote name="ossystems" fetch="https://github.com/OSSystems"/>
<remote name="qt" fetch="https://github.com/YoeDistro"/>
<remote name="timesys" fetch="https://github.com/TimesysGit"/>
<remote name="imx" fetch="https://github.com/nxp-imx"/>
<remote name="imx-support" fetch="https://github.com/nxp-imx-support"/>
<remote name="sbabic" fetch="https://github.com/sbabic"/>
<remote name="variscite" fetch="https://github.com/varigit"/>
<project name="poky" remote="yp-gh" path="sources/poky" revision="200d12b6a58ad961d60a7774ca0f7a9d29498724" upstream="scarthgap"/>
<project name="meta-openembedded" remote="oe" path="sources/meta-openembedded" revision="72018ca1b1a471226917e8246e8bbf9a374ccf97" upstream="scarthgap"/>
<project name="meta-clang" remote="kraj" path="sources/meta-clang" revision="2b7433611d80f6d0ee1b04156fa91fc73d3c2665" upstream="scarthgap"/>
<project name="meta-freescale" remote="community" path="sources/meta-freescale" revision="0627128b341cfb2bef7a0832ce8cac0ce1127f13" upstream="scarthgap"/>
<project name="meta-freescale-3rdparty" remote="community" path="sources/meta-freescale-3rdparty" revision="6c063450d464eb2f380443c7d9af1b94ce9b9d75" upstream="scarthgap"/>
<project name="meta-freescale-distro" remote="community" path="sources/meta-freescale-distro" revision="b9d6a5d9931922558046d230c1f5f4ef6ee72345" upstream="scarthgap"/>
<project name="meta-arm" remote="yp" path="sources/meta-arm" revision="950a4afce46a359def2958bd9ae33fc08ff9bb0d" upstream="scarthgap"/>
<project name="meta-qt6" remote="qt" path="sources/meta-qt6" revision="586a6cb5aec755803a3be3cec359baafe89d6432" upstream="6.8"/>
<project name="meta-browser" remote="ossystems" path="sources/meta-browser" revision="dc31889c0899971def535dc1c040edf18bc16691"/>
<project name="meta-security" remote="yp" path="sources/meta-security" revision="459d837338ca230254baa2994f870bf6eb9d0139" upstream="scarthgap"/>
<project name="meta-timesys" remote="timesys" path="sources/meta-timesys" revision="4dc3f4bdfde4a86904b6e1a3d58df4696e7a63fa" upstream="scarthgap"/>
<project name="meta-virtualization" remote="yp" path="sources/meta-virtualization" revision="6f3c1d8f90947408a6587be222fec575a1ca5195" upstream="scarthgap"/>
<project name="meta-imx" remote="imx" path="sources/meta-imx" revision="219f6d04a4c339eb6f2dc626f944bbdf9a716ff5" upstream="scarthgap-6.6.52-2.2.0">
<linkfile src="tools/imx-setup-release.sh" dest="imx-setup-release.sh"/>
<linkfile src="README" dest="README-IMXBSP"/>
</project>
<project name="meta-nxp-connectivity" remote="imx" path="sources/meta-nxp-connectivity" revision="f58365ec75a5768ff3e8e8bcd64f237738c93160" upstream="imx_matter_2024_q3-post"/>
<project name="meta-nxp-demo-experience" remote="imx-support" path="sources/meta-nxp-demo-experience" revision="e8e646e22b1f926aac83bb7ad522efa9cd8ccc45" upstream="scarthgap-6.6.52-2.2.0"/>
<project name="meta-swupdate" remote="sbabic" path="sources/meta-swupdate" revision="d598d4e675b541301ea1dfc8f0c8931983b4dcd0" upstream="scarthgap"/>
<project name="meta-variscite-bsp-common" remote="variscite" path="sources/meta-variscite-bsp-common" revision="10fb8ca3956c6359a9f744da47197048cc28a483" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-bsp-imx" remote="variscite" path="sources/meta-variscite-bsp-imx" revision="19052e7e0b96814b84069fdfd0d03568271c7ec6" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-hab" remote="variscite" path="sources/meta-variscite-hab" revision="ec4e9f1b2f99ad03077af6b847c38f6e9c2378a7" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-sdk-common" remote="variscite" path="sources/meta-variscite-sdk-common" revision="ee4ade553e063e5daed4e083c62ebff647d9e7dd" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-sdk-imx" remote="variscite" path="sources/meta-variscite-sdk-imx" revision="fbd0a9e4a7390f66e63af63ec7338bced09686f1" upstream="scarthgap_6.6.52-2.2.0_var01">
<linkfile src="scripts/var-setup-release.sh" dest="var-setup-release.sh"/>
</project>
<project name="variscite-bsp-base" remote="variscite" path="sources/base" revision="fa940410b6fa12155da5827c06351791147107d0" upstream="scarthgap_6.6.52-2.2.0_var01">
<linkfile src="setup-environment" dest="setup-environment"/>
<linkfile src="README" dest="README"/>
<linkfile src="scripts/var-start-container.sh" dest="var-start-container.sh"/>
</project>
<project name="var-host-docker-containers" remote="variscite" path="sources/var-host-docker-containers" revision="dd7218bb6e1c76db77cf40552b4cad7dfaa795fc" upstream="master"/>
</manifest>
the error i get
Initialising tasks: 100% |##########################################################################################################################################################################| Time: 0:00:12
NOTE: Executing Tasks
ERROR: tensorflow-lite-host-tools-native-2.16.2-r0 do_configure: ExecutionError('/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/temp/run.do_configure.179032', 1, None, None)
ERROR: Logfile of failure stored in: /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/temp/log.do_configure.179032
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/workdir/sources/poky/meta/recipes-devtools/cmake/cmake-native_3.28.3.bb:do_populate_sysroot', '/workdir/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', 'virtual:native:/workdir/sources/poky/meta/recipes-devtools/ninja/ninja_1.11.1.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'cmake-native', 'libtool-native', 'quilt-native', 'texinfo-dummy-native', 'openssl-native', 'ncurses-native', 'zlib-native', 'make-native', 'ninja-native', 'perl-native', 'bzip2-native', 'xz-native', 'zstd-native', 'gdbm-native', 're2c-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_configure
| + export HTTP_PROXY=
| + export HTTPS_PROXY=
| + export http_proxy=
| + export https_proxy=
| + cmake_do_configure
| + [ /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git = /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build ]
| + [ -e /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/site-file.cmake ]
| + oecmake_sitefile=
| + cmake -G Ninja -DCMAKE_MAKE_PROGRAM=ninja /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/native_tools -DCMAKE_INSTALL_PREFIX:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr -DCMAKE_INSTALL_BINDIR:PATH=bin -DCMAKE_INSTALL_SBINDIR:PATH=sbin -DCMAKE_INSTALL_LIBEXECDIR:PATH=libexec -DCMAKE_INSTALL_SYSCONFDIR:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/etc -DCMAKE_INSTALL_SHAREDSTATEDIR:PATH=../com -DCMAKE_INSTALL_LOCALSTATEDIR:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/var -DCMAKE_INSTALL_LIBDIR:PATH=lib -DCMAKE_INSTALL_INCLUDEDIR:PATH=include -DCMAKE_INSTALL_DATAROOTDIR:PATH=share -DPYTHON_EXECUTABLE:PATH=/usr/bin/python3 -DPython_EXECUTABLE:PATH=/usr/bin/python3 -DPython3_EXECUTABLE:PATH=/usr/bin/python3 -DLIB_SUFFIX= -DCMAKE_INSTALL_SO_NO_EXE=0 -DCMAKE_TOOLCHAIN_FILE:FILEPATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/toolchain.cmake -DCMAKE_NO_SYSTEM_FROM_IMPORTED=1 -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DFETCHCONTENT_FULLY_DISCONNECTED=ON -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=ON -DFETCHCONTENT_FULLY_DISCONNECTED=OFF -DCMAKE_SYSROOT= -Wno-dev
| -- The C compiler identification is GNU 9.4.0
| -- The CXX compiler identification is GNU 9.4.0
| -- Detecting C compiler ABI info
| -- Detecting C compiler ABI info - done
| -- Check for working C compiler: /workdir/build/tmp/hosttools/gcc - skipped
| -- Detecting C compile features
| -- Detecting C compile features - done
| -- Detecting CXX compiler ABI info
| -- Detecting CXX compiler ABI info - done
| -- Check for working CXX compiler: /workdir/build/tmp/hosttools/g++ - skipped
| -- Detecting CXX compile features
| -- Detecting CXX compile features - done
| -- Cloning flatbuffers repository from http://localhost:8080/7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz, found in /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/../third_party/flatbuffers/workspace.bzl
| -- Cloning flatbuffers repository revision 7d6d99c6befa635780a4e944d37ebfd58e68a108, found in /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/../third_party/flatbuffers/workspace.bzl
| -- Proceeding with version: 23.5.26.0
| -- Looking for strtof_l
| -- Looking for strtof_l - found
| -- Looking for strtoull_l
| -- Looking for strtoull_l - found
| -- Looking for realpath
| -- Looking for realpath - found
| -- CMAKE_CXX_FLAGS: -isystem/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/include -O2 -pipe
| -- Cloning https://github.com/protocolbuffers/protobuf...
| [1/9] Creating directories for 'protobuf-populate'
| [1/9] Performing download step (git clone) for 'protobuf-populate'
| Cloning into 'protobuf'...
| fatal: unable to access 'https://github.com/protocolbuffers/protobuf/': Could not resolve host: github.com
| -- Had to git clone more than once: 3 times.
| CMake Error at _deps/protobuf-subbuild/protobuf-populate-prefix/tmp/protobuf-populate-gitclone.cmake:39 (message):
| Failed to clone repository: 'https://github.com/protocolbuffers/protobuf'
| FAILED: protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download
| cd /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build && /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/bin/cmake -P /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/tmp/protobuf-populate-gitclone.cmake && /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/bin/cmake -E touch /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download
| ninja: build stopped: subcommand failed.
| CMake Error at /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1679 (message):
| Build step for protobuf failed: 1
| Call Stack (most recent call first):
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1819:EVAL:2 (__FetchContent_directPopulate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1819 (cmake_language)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/OverridableFetchContent.cmake:537 (FetchContent_Populate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/protobuf.cmake:37 (OverridableFetchContent_Populate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/Findprotobuf.cmake:18 (include)
| protobuf/CMakeLists.txt:34 (find_package)
| -- Configuring incomplete, errors occurred!
| WARNING: exit code 1 from a shell command.
| + bb_sh_exit_handler
| + ret=1
| + [ 1 != 0 ]
| + echo WARNING: exit code 1 from a shell command.
| + exit 1
ERROR: Task (virtual:native:/workdir/sources/meta-imx/meta-imx-ml/recipes-libraries/tensorflow-lite/tensorflow-lite-host-tools_2.16.2.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5477 tasks of which 5471 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 9 seconds
1,248 次查看
Bio_TICFSL
You need to erase everything and restart to download yocto, since I can not reproduce the issue in my building. If you are working with none BSP from NXP, please contact your vendor for this issue.
955 次查看
greeran
hello
after a number of deletions and build i have found a workaround for the problem. it seems that the branch and has for the matter did not match between the downloads/github..matter.git to the bb file. i added to my site.conf
SRCBRANCH:pn-matter = "release/v1.4.
SRCREV:pn-matter = "9042e9281bf619ce0d06d043d5ac3c0c34c24bbe"
and that solved the parsing error. after that  i have a fetch error that tried to get the thirdparty/nxp_matter_support that i did not find in my downloads (which successfully build an image with internet). so to workaround this problem i removed all the installs for "packagegroup-nxp-matter" and such.
This did not solve the problem but enabled me to build my image and because i do not need the application that use the matter it is a sufficient workaround
thanks
1,307 次查看
Bio_TICFSL
If you download the complete bsp and build the full-image you should not have any issue, please tell us which BSP are you using to test.
1,145 次查看
greeran
i am deleted all the build and download and sstate. i am now building from scratch and hopefully tomorrow i will be able to test it with a clean build on a machine without internet
%3CLINGO-SUB%20id%3D%22lingo-sub-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A0%E6%B3%95%E5%9C%A8%E7%A6%BB%E7%BA%BF%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E4%B8%BA%20imx8mp%20Scarthgap%20%E7%89%88%E6%9C%AC%20tensorflow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Scarthgap%20%E4%B8%BA%20i.MX8MP%20%E6%9E%84%E5%BB%BA%20fsl-image-qt6%20%E6%98%A0%E5%83%8F%E3%80%82%E6%88%91%E5%9C%A8%E5%9C%A8%E7%BA%BF%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E7%89%88%E6%9C%AC%E4%BA%86%E5%AE%83%EF%BC%8C%E5%B9%B6%E5%B0%86%E4%B8%8B%E8%BD%BD%E7%9B%AE%E5%BD%95%E5%A4%8D%E5%88%B6%E5%88%B0%E7%A6%BB%E7%BA%BF%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E3%80%82%E6%88%91%E4%B9%8B%E5%89%8D%E5%9C%A8%E5%85%B6%E4%BB%96%20BSP%20%E7%89%88%E6%9C%AC%EF%BC%88Kirkstone%E3%80%81Zeus%20%E7%AD%89%EF%BC%89%E4%B8%AD%E6%9B%BE%E5%A4%9A%E6%AC%A1%E6%88%90%E5%8A%9F%E4%BD%BF%E7%94%A8%E8%BF%87%E8%BF%99%E4%B8%AA%E5%B7%A5%E4%BD%9C%E6%B5%81%E7%A8%8B%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E4%B8%8D%E6%98%AF%E6%88%91%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E7%A6%BB%E7%BA%BF%20BSP%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E7%A6%BB%E7%BA%BF%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E6%9E%84%E5%BB%BA%E7%9B%B8%E5%90%8C%E7%9A%84%E9%95%9C%E5%83%8F%E6%97%B6%EF%BC%8Ctensorflow-lite-tools-native%E7%9A%84%E7%89%88%E6%9C%AC%E5%A4%B1%E8%B4%A5%E3%80%82%E5%AE%83%E4%BC%BC%E4%B9%8E%E8%AF%95%E5%9B%BE%E5%85%8B%E9%9A%86%E6%89%A9%E5%B1%95%E7%9A%84%E7%AC%AC%E4%B8%89%E6%96%B9%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%88protobuf%20%E7%AD%89%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%8B%E8%BD%BD%E7%9A%84%20tar.gz%20%E6%96%87%E4%BB%B6%E4%B8%8D%E8%B6%B3%E4%BB%A5%E6%BB%A1%E8%B6%B3%E5%AE%83%E7%9A%84%E8%A6%81%E6%B1%82%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E7%BB%8F%E8%BF%87%E5%A4%9A%E6%AC%A1%E5%88%A0%E9%99%A4%E5%92%8C%E7%89%88%E6%9C%AC%EF%BC%8C%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%E7%9C%8B%E6%9D%A5%E4%B8%8B%E8%BD%BD%E7%9A%84%E5%88%86%E6%94%AF%E5%92%8C%20github...%20matter.git%20%E4%B8%8E%20bb%20%E6%96%87%E4%BB%B6%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%E6%88%91%E5%9C%A8%20site.conf%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20%3C%2FP%3E%3CP%3EsrcBranch%3A%20PN-Matter%20%3D%20%22%E7%89%88%E6%9C%AC%2Fv1.4%E3%80%82%3C%2FP%3E%3CP%3ESRCREV%3Apn-matter%20%3D%229042e9281bf619ce0d06d043d5ac3c0c34c24bbe%22%3C%2FP%3E%3CP%3E%E5%B0%B1%E8%A7%A3%E5%86%B3%E4%BA%86%E8%A7%A3%E6%9E%90%E9%94%99%E8%AF%AF%E3%80%82%E4%B9%8B%E5%90%8E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E6%8F%90%E5%8F%96%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%95%E5%9B%BE%E8%8E%B7%E5%BE%97%E6%88%91%E5%9C%A8%E4%B8%8B%E8%BD%BD%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E7%9A%84%E7%AC%AC%E4%B8%89%E6%96%B9%2Fnxp_matter_support%EF%BC%88%E5%AE%83%E6%88%90%E5%8A%9F%E5%9C%B0%E4%BD%BF%E7%94%A8%E4%BA%92%E8%81%94%E7%BD%91%E7%89%88%E6%9C%AC%E4%BA%86%E9%95%9C%E5%83%8F%EF%BC%89%E3%80%82%E4%B8%BA%E4%BA%86%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%22packagegroup-nxp-matter%22%20%E7%AD%89%E7%9A%84%E6%89%80%E6%9C%89%E5%AE%89%E8%A3%85%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E4%BD%BF%E6%88%91%E8%83%BD%E5%A4%9F%E7%89%88%E6%9C%AC%E8%87%AA%E5%B7%B1%E7%9A%84%E9%95%9C%E5%83%8F%EF%BC%8C%E8%80%8C%E4%B8%94%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B8%8D%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E8%B6%B3%E5%A4%9F%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%E6%88%91%E6%89%80%E6%9C%89%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%81%E4%B8%8B%E8%BD%BD%E5%92%8C%E7%8A%B6%E6%80%81%E7%84%B6%E5%90%8E%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E9%87%8D%E5%BB%BA%E3%80%82%E7%89%88%E6%9C%AC%E5%BE%88%E9%95%BF%E6%97%B6%E9%97%B4%E4%BD%86%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%20build_xwayland%20%E7%9B%AE%E5%BD%95%EF%BC%88%E5%9C%A8%20site.conf%20%E4%B8%AD%E4%BF%9D%E7%95%99%E4%BA%86%20downloads%20%E5%92%8C%20sstate%20%E8%B7%AF%E5%BE%84%EF%BC%89%E3%80%82%E6%88%91%E5%9C%A8%20%3C%2FP%3E%3CP%3Ebb_noo_network%20%3D%221%22%3CBR%20%2F%3E%20bb_fetch_premirroronly%20%3D%221%22%3C%2FP%3E%3CP%3E%E6%88%91%E7%A7%BB%E9%99%A4%E4%BA%86%E7%BD%91%E7%BA%BF%EF%BC%8C%E4%BB%A5%E6%A8%A1%E6%8B%9F%E6%88%91%E7%9A%84%E7%A6%BB%E7%BA%BF%E7%94%B5%E8%84%91%E3%80%82%E8%BF%90%E8%A1%8C%20bitbake%20fsl-image-qt6%20%E6%97%B6%EF%BC%8C%E8%A7%A3%E6%9E%90%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter-baseline%2Frecipes-matter%2Fmatter.bb%EF%BC%9A%E5%9C%A8%E6%9E%84%E5%BB%BA%20fetcher_hases_dummyfunc%20%E6%97%B6%E5%87%BA%E7%8E%B0%E5%BC%82%E5%B8%B8%20%7C%20ETA%3A%200%3A00%3A04%20%E8%AD%A6%E5%91%8A%EF%BC%9A%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter%2Fmatter.bb%EF%BC%9A%3CBR%20%2F%3E%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter-baseline%2Frecipes-matter%2Fmatter.bb%20%E5%9C%A8%E6%95%B2%E5%AE%9A%E6%97%B6%E5%87%BA%E9%94%99%20%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%A7%A3%E6%9E%90%E6%97%B6%E5%87%BA%E7%8E%B0%E6%89%A9%E5%B1%95%E9%94%99%E8%AF%AF%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter%2Fmatter%2Fmatter.bb%20%3CBR%20%2F%3E%E5%9B%9E%E9%A1%BE%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__%20.py%20%22%EF%BC%8C%E7%AC%AC%201248%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20srcrev_internal_helper%20(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20%EF%BC%8Cd%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%E7%9A%84%3CBR%20%2F%3E%20DataSmart%20%E5%AF%B9%E8%B1%A1%EF%BC%8Cname%3D'default')%EF%BC%9Ad.setVar%20(%20%22%20__BBAUTOREV_%E8%A1%8C%E5%8A%A8_UPON%20%22%EF%BC%8CTrue)%3CBR%20%2F%3E%20%26gt%3B%20srcrev%20%3D%20ud.method.latest_revision%20(ud%2Cd%EF%BC%8C%E5%90%8D%E7%A7%B0%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__%20.py%20%22%EF%BC%8C%E7%AC%AC%201670%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20gitsm.Latest_Revision%20(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20%EF%BC%8Cd%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%EF%BC%8Cname%3D'default'%EF%BC%89%EF%BC%9A%E9%99%A4%E4%BA%86%3CBR%20%2F%3E%20KeyError%EF%BC%9A%3CBR%20%2F%3E%20%26gt%3B%20revs%20%5Bkey%5D%20%3D%20rev%20%3D%20self%E3%80%82_latest_revision%20(ud%2Cd%EF%BC%8Cname)%3CBR%20%2F%3E%20%E5%9C%A8%3CBR%20%2F%3E%20GitSM%20%E4%B8%AD%20%E8%BF%94%E5%9B%9E%20rev%20%E6%96%87%E4%BB%B6%20%22%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%20%22%EF%BC%8C%E7%AC%AC%20850%20%E8%A1%8C%E3%80%82_latest_revision%EF%BC%88ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20%EF%BC%8Cd%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%EF%BC%8Cname%3D'default'%EF%BC%89%EF%BC%9A%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E8%BE%93%E5%87%BA%20%3D%20self%E3%80%82%20_lsremote%20(ud%2Cd%EF%BC%8C%22%20%22)%3CBR%20%2F%3E%20%23%20%E6%A0%BC%E5%BC%8F%E4%B8%BA%20%5E%20%7B%7D%20%E7%9A%84%E6%A0%87%E7%AD%BE%E5%8F%AF%E8%83%BD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%3CBR%20%2F%3E%20GitSM%20%E4%B8%AD%E5%9B%9E%E9%80%80%E5%88%B0%E5%85%B6%E4%BB%96%E8%A1%A8%E5%8D%95%20F%20ile%20%22%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%20%22%EF%BC%8C%E7%AC%AC%20832%20%E8%A1%8C%E3%80%82_lsremote%20(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20%EF%BC%8Cd%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%EF%BC%8Csearch%3D%E2%80%9D)%EF%BC%9A%E5%A6%82%E6%9E%9C%3CBR%20%2F%3E%20ud.proto.lower%20()!%3D%20'file'%3A%3CBR%20%2F%3E%26gt%3B%20bb.fetch2.check_network_access(d.%E3%80%81cmd%EF%BC%8Crepourl)%3CBR%20%2F%3E%20%E8%BE%93%E5%87%BA%20%3D%20runfetchcmd%EF%BC%88cmd%EF%BC%8Cd%EF%BC%8CTrue%EF%BC%89%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F.py%22%EF%BC%8C%E7%AC%AC__init__%20970%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20check_network_access%20(d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%EF%BC%8Cinfo%3D'git-c%20gc.autodetach%3Dfalse-c%20core.pager%3Dcat-c%20safe.bareRepository%3Dallls-remote%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E'%2C%20url%3D%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E'https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git'%3C%2FA%3E)%EF%BC%9A%3CBR%20%2F%3Eif%20bb.utils.to_boolean(d.getVar(%22BB_NO_NETWORK%22))%EF%BC%9A%3CBR%20%2F%3E%26gt%3B%20raise%20NetworkAccess%EF%BC%88%E7%BD%91%E5%9D%80%EF%BC%8C%E4%BF%A1%E6%81%AF%EF%BC%89%3CBR%20%2F%3Eelif%20%E4%B8%8D%E6%98%AF%20trusted_network%EF%BC%88d%EF%BC%8Curl%EF%BC%89%EF%BC%9A%3CBR%20%2F%3Ebb.data_smart.ExpansionError%EF%BC%9A%E6%89%A9%E5%B1%95%E5%8F%98%E9%87%8F%20fetcher_hashes_dummyfunc%20%5Bvardepvalue%5D%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%A1%A8%E8%BE%BE%E5%BC%8F%E6%98%AF%20%24%7B%40bb.fetch.get_hashvalue(d)%7D%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E5%BC%82%E5%B8%B8%20NetworkAccess%EF%BC%9A%E9%80%9A%E8%BF%87%20BB_NO_NETWORK%20%E7%A6%81%E7%94%A8%E7%BD%91%E7%BB%9C%E8%AE%BF%E9%97%AE%EF%BC%88%E6%88%96%E7%94%B1%E4%BA%8E%E4%BD%BF%E7%94%A8%20BB_FETCH_PREORONLY%20%E8%80%8C%E9%97%B4%E6%8E%A5%E8%AE%BE%E7%BD%AE%EF%BC%89%EF%BC%8C%E4%BD%86%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%20git-c%20%E8%AF%B7%E6%B1%82%E8%AE%BF%E9%97%AE%20c.autodetach%3Dfalse-c%20core.pager%3Dcat-c%20safe.bareRepository%3Dallls-remote%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%EF%BC%88%E7%94%A8%E4%BA%8E%E7%BD%91%E5%9D%80%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%EF%BC%89%3C%2FA%3E%3CBR%20%2F%3E%E6%95%85%E9%9A%9C%E7%9A%84%E5%8F%98%E9%87%8F%E4%BE%9D%E8%B5%96%E9%93%BE%E6%98%AF%EF%BC%9A%20fetcher_hashes_dummyfunc%5Bvardepvalue%5D.%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%A7%A3%E6%9E%90%E5%9B%A0%E9%94%99%E8%AF%AF%E8%80%8C%E5%81%9C%E6%AD%A2%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8A%E9%9D%A2%E7%9A%84%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%20%E6%9C%89%202%20%E6%9D%A1%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E3%80%82%3CBR%20%2F%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%9C%89%202%20%E6%9D%A1ERROR%20%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%81%E4%BF%AE%E5%A4%8D%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%88%91%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%BA%92%E8%81%94%E7%BD%91%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20bitbake%20fsl-image-qt6--runall%3Dfetch%20%E7%84%B6%E5%90%8E%E7%A6%BB%E7%BA%BF%E7%89%88%E6%9C%AC%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%9C%A8%E8%84%B1%E6%9C%BA%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E6%89%A7%E8%A1%8C%20runall%3Dfetch%20%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E7%9F%A5%E9%81%93%E6%88%91%E7%9A%84%E9%94%99%E8%AF%AF%E6%98%AF%E4%BB%80%E4%B9%88%E4%BB%A5%E5%8F%8A%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E6%97%A0%E6%B3%95%E7%A6%BB%E7%BA%BF%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2160999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%88%A0%E9%99%A4%E4%BA%86%E6%89%80%E6%9C%89%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%81%E4%B8%8B%E8%BD%BD%E5%92%8C%E7%8A%B6%E6%80%81%E3%80%82%E6%88%91%E7%8E%B0%E5%9C%A8%E6%AD%A3%E5%9C%A8%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%B8%8C%E6%9C%9B%E6%98%8E%E5%A4%A9%E6%88%91%E8%83%BD%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BA%92%E8%81%94%E7%BD%91%E7%9A%84%E6%9C%BA%E5%99%A8%E4%B8%8A%E7%94%A8%E5%B9%B2%E5%87%80%E7%9A%84%E7%89%88%E6%9C%AC%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E9%9C%80%E8%A6%81%E6%B8%85%E9%99%A4%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E5%B9%B6%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E4%B8%8B%E8%BD%BD%20yocto%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%88%91%E7%9A%84%E5%BB%BA%E7%AD%91%E7%89%A9%E4%B8%AD%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%E6%81%A9XP%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%8C%E8%AF%B7%E5%B0%B1%E6%AD%A4%E9%97%AE%E9%A2%98%E8%81%94%E7%B3%BB%E6%82%A8%E7%9A%84%E4%BE%9B%E5%BA%94%E5%95%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BB%8E%E4%BB%93%E5%BA%93%E4%B8%AD%E5%8F%91%E9%80%81%E6%B8%85%E5%8D%95%E5%92%8C%E6%88%91%E6%94%B6%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E8%AF%95%E7%9D%80%E4%B8%8B%E8%BD%BD%E4%BA%86%E4%B8%A4%E6%AC%A1%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%84%B1%E6%9C%BA%E8%BF%90%E8%A1%8C%E6%97%B6%E4%BB%8D%E7%84%B6%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%88BB_NO_NETWORK%20%3D%221%22%20%E5%92%8C%20BB%2BGENERATE_MIRROR_TARBALLS%20%3D%221%22%20)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CMANIFEST%3E%3CBR%20%2F%3E%20%26lt%3B%20include%20name%3D%22imx-6.6.52-2.2.0.xml%22%20%2F%26gt%3B%3CBR%20%2F%3E%20%3C%2FMANIFEST%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%20repo%20%E7%9A%84%E6%B8%85%E5%8D%95%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CMANIFEST%3E%3C%2FMANIFEST%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E9%BB%98%E8%AE%A4%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20sync-j%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%204%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%20%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20yp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20fetch%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgit.yoctoproject.org%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgit.yoctoproject.org%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20yp-gh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Efetch%3D%20%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fyoctoproject%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fyoctoproject%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20oe%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20fetch%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fopenembedded%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fopenembedded%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20kraj%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20fetch%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fkraj%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fkraj%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Ecommunity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20ossystems%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20fetch%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOSSystems%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2FOSSystems%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20qt%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Efetch%3D%20%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FYoeDistro%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2FYoeDistro%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Etimesys%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FTimesysGit%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FTimesysGit%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Eimx-support%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E8%BF%9C%E7%A8%8B%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Esbabic%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fsbabic%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fsbabic%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fvarigit%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fvarigit%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20poky%3C%2FSPAN%3E%20%22%20remot%20e%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20yp-gh%3C%2FSPAN%3E%20%22%20p%20at%20h%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fp%3C%2FSPAN%3E%20%3C%2FSPAN%3Eoky%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%20%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%22%20200d12b6a58ad961d60a7774ca0f74ca0f7a9d29498%20724%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E%20%E4%B8%8A%E6%B8%B8%20%3D%3C%2FSPAN%3E%20%22%20scarthgap%20%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20meta-openembedded%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20oe%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-openembedded%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20revision%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%2072018ca1b1a471226917e8246e8bbf9a374ccf97%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-clang%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20kraj%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-clang%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%202b7433611d80f6d0ee1b04156fa91fc73d3c2665%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20meta-freescale%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20community%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Epath%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-freescale%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20revision%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%200627128b341cfb2bef7a0832ce8cac0ce1127f13%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-freescale-3rdparty%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20community%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-freescale-3rdparty%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%206c063450d464eb2f380443c7d9af1b94ce9b9d75%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%20meta-freescale-distro%20%22%3C%2FSPAN%3E%20rem%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20ot%20e%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20%E7%A4%BE%E5%8C%BA%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sourcescale%2Fmeta-freescale-distro%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20b9d6a5d9931922558046d230c1f5f4ef6ee72345%3C%2FSPAN%3E%20%22%20%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthga%20p%3C%2FSPAN%3E%20%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%20meta-arm%20%22%3C%2FSPAN%3E%20rem%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20ot%20e%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20yp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20p%20ath%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2F%20meta-arm%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20950a4afce46a359def2958bd9ae33fc08ff9bb0d%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%20%3D%20%22%20scarthgap%20%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-qt6%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20qt%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-qt6%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%20586a6cb5aec755803a3be3cec359baafe89d6432%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20upstream%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%206.8%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20meta-browser%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20ossystems%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Epath%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-browser%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%20dc31889c0899971def535dc1c040edf18bc16691%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%20%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%20meta-%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%20%22%3C%2FSPAN%3E%20rem%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20ot%20e%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20yp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20p%3C%2FSPAN%3E%20ath%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20459d837338ca230254baa2994f870bf6eb9d0139%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%20%3D%20%22%20scarthgap%20%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20meta-timesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20timesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-timesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20revision%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%204dc3f4bdfde4a86904b6e1a3d58df4696e7a63fa%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Ename%3D%20%22%3CSPAN%20class%3D%22%22%3E%20meta-virtualization%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20yp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-virtualization%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20revision%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%206f3c1d8f90947408a6587be222fec575a1ca5195%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Emeta-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3E219f6d04a4c339eb6f2dc626f944bbdf9a716ff5%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3D%3C%2FSPAN%3E%22%3CSPAN%20class%3D%22%22%3Escarthgap-6.6.52-2.2.0%3C%2FSPAN%3E%22%3C%2FSPAN%3E%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Etools%2Fimx-setup-%E7%89%88%E6%9C%AC.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx-setup-%E7%89%88%E6%9C%AC.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20src%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20README%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20dest%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20README-IMXBSP%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%20meta-nxp-%E8%BF%9E%E6%8E%A5%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20rem%20ot%3C%2FSPAN%3E%20e%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20im%20x%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-nxp-%E8%BF%9E%E6%8E%A5%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eity%3C%2FSPAN%3E%20%22%20%E4%BF%AE%E8%AE%A2%E7%89%88%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20f58365ec75a5768ff3e8e8e8e8bcd64f237738c%2093160%3C%2FSPAN%3E%20%22%20%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20imx_matter_2024_q3-post%3C%2FSPAN%3E%20%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-nxp-demo-experience%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20imx-support%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Epath%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-nxp-demo-experience%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%20e8e646e22b1f926aac83bb7ad522efa9cd8ccc45%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap-6.6.52-2.2.0%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-swupdate%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sbabic%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-swupdate%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20revision%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20d598d4e675b541301ea1dfc8f0c8931983b4dcd0%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%20meta-variscite-bsp-common%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-variscite-bs%20p%20-%20common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%2010fb8ca3956c6359a9f744da47197048cc28a483%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap_6.6.52-2.%200_var01%3C%2FSPAN%3E%20%3C%2FSPAN%3E%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20meta-variscite-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-variscite-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%2019052e7e0b96814b84069fdfd0dfd0d0d03568271c7ec6%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%E4%B8%8A%E6%B8%B8%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap_6.6.52-2.0_var01%3C%2FSPAN%3E%20%22%2F%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-variscite-hab%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-variscite-hab%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20revision%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20ec4e9f1b2f99ad03077af6b847c38f6e9c2378a7%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-variscite-sdk-common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-variscite-sdk-common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%20ee4ade553e063e5daed4e083c62ebff647d9e7dd%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20name%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20meta-variscite-sdk-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Epath%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fmeta-variscite-sdk-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Erevision%3D%20%22%3CSPAN%20class%3D%22%22%3E%20fbd0a9e4a7390f66e63af63ec7338bced09686f1%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Eupstream%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escripts%2Fvar-setup-%E7%89%88%E6%9C%AC.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evar-setup-%E7%89%88%E6%9C%AC.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%20%3D%20%22%20variscite-bsp-base%20%22%20rem%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20ot%20e%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fbase%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20fa940410b6fa12155da5827c06351791147107d0%3C%2FSPAN%3E%20%22%20%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20scarthgap%20_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Esrc%3D%20%22%3CSPAN%20class%3D%22%22%3E%20setup-environment%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20dest%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20setup-environment%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20src%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20README%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20dest%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20README%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20src%3D%3C%2FSPAN%3E%20%22%3CSPAN%20class%3D%22%22%3E%20scripts%2Fvar-start-container.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3Edest%3D%20%22%3CSPAN%20class%3D%22%22%3E%20var-start-container.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%E9%A1%B9%E7%9B%AE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%E5%90%8D%E7%A7%B0%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20var-host-docker-%E5%AE%B9%E5%99%A8%20%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20remote%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20variscite%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20path%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20sources%2Fvar-host-docker-%20%E5%AE%B9%E5%99%A8%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%20dd7218bb6e1c76db77cf40552b4cad7dfaa795fc%3C%2FSPAN%3E%20%22%20%E4%B8%8A%E6%B8%B8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3D%20%22%3CSPAN%20class%3D%22%22%3E%20master%3C%2FSPAN%3E%20%3C%2FSPAN%3E%22%2F%20%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A12%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%89%A7%E8%A1%8C%E4%BB%BB%E5%8A%A1%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Atensorflow-lite-host-tools-native-2.16.2-r0%20do_configure%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%94%99%E8%AF%AF%EF%BC%88'%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftemp%2Frun.do_configure.179032'%EF%BC%8C1%EF%BC%8C%E6%97%A0%EF%BC%8C%E6%97%A0%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftemp%2Flog.do_configure.179032%3CBR%20%2F%3E%E6%97%A5%E5%BF%97%E6%95%B0%E6%8D%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%7C%20%E8%B0%83%E8%AF%95%EF%BC%9A%E6%89%A7%E8%A1%8C%20python%20%E5%87%BD%E6%95%B0%20extend_%E9%85%8D%E6%96%B9_sysroot%20%3CBR%20%2F%3E%20%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E7%9B%B4%E6%8E%A5%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%E6%98%AF%20%5B'%2Fworkdir%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fmeta%2Frecipes-devtools%2Fcmake%2Fcmake-native_3.28.3.bb%3A%20do_populate_sysroot'%EF%BC%8C'%2Fworkdir%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fmeta%2Frecipes-devtools%2Fquilt%2Fquilt-native_0.67.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fworkdir%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fmeta%2Frecipes-devtools%2Fninja%2Fninja_1.11.1.bb%3Ado_populate_sysroot'%5D%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E5%88%B0%20sysroot%20%E4%B8%AD%EF%BC%9A%5B%5D%20%3CBR%20%2F%3E%20%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%B7%B3%E8%BF%87%E7%B3%BB%E7%BB%9F%E6%A0%B9%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%B7%B2%E5%AD%98%E5%9C%A8%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%5B'gettext-minimal-native'%E3%80%81'libtool-native'%E3%80%81'quilt-native'%E3%80%81'texinfo-dummy-native'%E3%80%81'texinfo-dummy-native'%E3%80%81'opensl-native'%E3%80%81'ninjsl-native'%E3%80%81'make-native'%E3%80%81'make-native'%E3%80%81'ninjs%20a-native'%E3%80%81'perl-native'%E3%80%81'bzip2-native'%E3%80%81'xz-native'%E3%80%81'zstd-native'%E3%80%81're2c-native'%5D%20%7C%20%E8%B0%83%E8%AF%95%EF%BC%9APython%20%E5%87%BD%E6%95%B0%20extend_recipe_sysroot%20%E5%B7%B2%E5%AE%8C%E6%88%90%20%7C%20%E8%B0%83%E8%AF%95%EF%BC%9A%E6%89%A7%E8%A1%8C%E5%A4%96%E5%A3%B3%E5%87%BD%E6%95%B0%20do_configure%20%7C%20%2B%20%E5%AF%BC%E5%87%BA%20HTTP_PROXY%3D%20%7C%20%2B%20%E5%AF%BC%E5%87%BA%20HTTP_PROXY%3D%20%7C%20%2B%20%E5%AF%BC%E5%87%BA%20HTTP_PROXY%3D%20%7C%20%2B%20%E5%AF%BC%E5%87%BA%20http_proxy%3D%20%7C%20%2B%20%E5%AF%BC%E5%87%BA%20http_proxy%3D%20%7C%20%2B%20%E5%AF%BC%E5%87%BA%20http_proxy%3D%20%7C%20%2B%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E5%AF%BC%E5%87%BA%20https_proxy%3D%20%3CBR%20%2F%3E%20%7C%20%2B%20cmake_do_configure%20%7C%20%2B%20%5B%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%20%3D%20%2Fwork%2Fbuild%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%20%3D%20%2Fwork%2Fbuild%2Fx86_%20%3CBR%20%2F%3E%2064-linux%2Ftensorflow-lite-host-tools-e%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fsite-file.cmake%3D%20%3CBR%20%2F%3E%20%7C%20%2B%20cmake-G%20Ninja-dcmake_make_program%3Dninja%20%2Fwork%2Fbuild%2Fbuild%2Ftemp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-native-lite-linux%2Ftensorflow-native-native-native-ve%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fnative_tools-DCMAKE_INSTALL_%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E5%89%8D%E7%BC%80%EF%BC%9Apath%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2FTensorflow-Lite-Host-Tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr-dcmake_install_bindir%3A%20path%3Dbin-dcmake_install_libexecdir%3A%20path%3Dbin-dcmake_install_libexecDIR%3A%20path%3Dbin-dcmake_install_libexecdir%3A%20path%3Dlibexec-dc_install_sysconfdir%3A%20path%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2FTensorflow-Lite-Host-Tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fetc-DCMAKE_INSTALL_SHAREDSTATEDIR%3A%20PATH%3D..%2Fcom-dcmake_install_localStatedir%3A%20path%3D%2Fwork%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2FTensorflow-Lite-Host-Tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fvar-dcmake_install_libdir%3A%20path%3Dlib-dcmake_install_include_install_dcrodir%3A%20path%3Dinclude-dcmake_install_dcrot_dataRoot%E5%88%86%E4%BA%AB-dpython_executable%3A%20path%3D%2Fusr%2Fbin%2Fpython3-dpython_executable%3A%20path%3D%2Fusr%2Fbin%2FPython3-dpython3_executable%3A%20path%3D%2Fbin%2Fpython3-DLIB_SUFFIX%3D-DCMAKE_INSTALL_NO_EXE%3D0-dcmake_toolchain_file%3A%20filePath%3D%2FWorkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftoolchain.cmake-DCMAKE_NO_SYSTEM_FROM_IMPORTED%3D1-DCMAKE_EXPORT_FROM_IMPORTED%3D1-DCMAKE_EXPORT_FULLY_COMMANDS%3A%20BOOL%3DON-PACKAKE_EXPORT_COMMANDS%3A%20BOOL%3DON%20DFETCHCONTENT_FULLY_DISCONNECTED%3DOFF-DCMAKE_SYSROOT%3D-WNO-dev%20%7C%20%E2%80%94%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%E7%9A%84%E6%A0%87%E8%AF%86%E6%98%AF%20GNU%209.4.0%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%7C%20--%20CXX%20%E7%BC%96%E8%AF%91%E5%99%A8%E6%A0%87%E8%AF%86%E4%B8%BA%20GNU%209.4.0%3CBR%20%2F%3E%7C--%E6%A3%80%E6%B5%8B%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%20ABI%20%E4%BF%A1%E6%81%AF%20%3CBR%20%2F%3E%20%7C--%E6%A3%80%E6%B5%8B%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%20ABI%20%E4%BF%A1%E6%81%AF-%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%7C--%E6%A3%80%E6%9F%A5%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%EF%BC%9A%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fhosttools%2Fgcc-%E5%B7%B2%E8%B7%B3%E8%BF%87%20%7C--%E6%A3%80%E6%B5%8B%20C%20%E7%BC%96%E8%AF%91%E5%8A%9F%E8%83%BD-%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%7C--%E6%A3%80%E6%B5%8B%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%20ABI%20%E4%BF%A1%E6%81%AF-%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%7C--%E6%A3%80%E6%9F%A5%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%20CXX%20%E7%BC%96%E8%AF%91%E5%99%A8%EF%BC%9A%2Fworkdir%2F%E7%89%88%E6%9C%AC%20d%2Ftmp%2Fhosttools%2Fg%2B%2B-%E5%B7%B2%E8%B7%B3%E8%BF%87%20%3CBR%20%2F%3E%20%7C--%E6%A3%80%E6%B5%8B%20CXX%20%E7%BC%96%E8%AF%91%E5%8A%9F%E8%83%BD%20%3CBR%20%2F%3E%20%7C--%E6%A3%80%E6%B5%8B%20CXX%20%E7%BC%96%E8%AF%91%E5%8A%9F%E8%83%BD-%E5%AE%8C%E6%88%90%20%7C--%E4%BB%8E%20flatbuffers%20%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E5%85%8B%E9%9A%86%20flatbuffers%20%E5%AD%98%E5%82%A8%E5%BA%93%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Flocalhost%3A8080%2F7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Flocalhost%3A8080%2F7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz%3C%2FA%3E%EF%BC%8C%E5%9C%A8%20%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2F...%20%E4%B8%AD%E6%89%BE%E5%88%B0%2F%E7%AC%AC%E4%B8%89%E6%96%B9%2Fflatbuffers%2Fworkspace.bzl%20%3CBR%20%2F%3E%7C%20%E2%80%94%20%E5%85%8B%E9%9A%86%20flatbuffers%20%E5%AD%98%E5%82%A8%E5%BA%93%E4%BF%AE%E8%AE%A2%E7%89%88%207d6d99c6befa635780a4e944d37ebfd58e68a108%EF%BC%8C%E4%BD%8D%E4%BA%8E%20%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2F...%2F%E7%AC%AC%E4%B8%89%E6%96%B9%2Fflatbuffers%2Fworkspace.bzl%20%3CBR%20%2F%3E%7C--%E7%BB%A7%E7%BB%AD%E5%A4%84%E7%90%86%E7%89%88%E6%9C%AC%EF%BC%9A23.5.26.0%3CBR%20%2F%3E%20%7C--%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%20strtof_l%3CBR%20%2F%3E%20%7C--%E5%AF%BB%E6%89%BE%20strtof_l-%E5%B7%B2%E6%89%BE%E5%88%B0%3CBR%20%2F%3E%20%7C--%E5%AF%BB%E6%89%BE%20strtoull_l%3CBR%20%2F%3E%20%7C--%E5%AF%BB%E6%89%BE%20strtoull_l-%E5%B7%B2%E6%89%BE%E5%88%B0%3CBR%20%2F%3E%20%3CBR%20%2F%3E%7C--%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E7%9C%9F%E5%AE%9E%E8%B7%AF%E5%BE%84-%E5%B7%B2%E6%89%BE%E5%88%B0%3CBR%20%2F%3E%20%7C--CMAKE_CXX_FLAGS%3A-isystem%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fwork%2Fwork%2Fflags%3A-isystem%2Fworkdir%2Fbuil%20d%2Ftmp%2Fwork%2Fwork%2Fwork%2Fwork%2Fflags%20x86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Finclude-O2-pipe%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3C%2FA%3E%3CBR%20%2F%3E%7C%20%E2%80%94%20%E5%85%8B%20%E9%9A%86%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%3C%2FA%3E...%20%7C%20%5B1%2F9%5D%3CBR%20%2F%3E%20%E4%B8%BA%20%E2%80%9Cprotobuf-populate%E2%80%9D%20%E5%88%9B%E5%BB%BA%E7%9B%AE%E5%BD%95%20%7C%20%5B1%2F9%5D%20%E4%B8%BA%20%E2%80%9Cprotobuf-populate%E2%80%9D%20%E6%89%A7%E8%A1%8C%E4%B8%8B%E8%BD%BD%E6%AD%A5%E9%AA%A4%EF%BC%88git%20clone%EF%BC%89%7C%3CBR%20%2F%3E%20%E5%85%8B%E9%9A%86%E5%88%B0%20%E2%80%9Cprotobuf%E2%80%9D%20%E4%B8%AD...%3CBR%20%2F%3E%20%7C%20%E8%87%B4%E5%91%BD%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%20%E2%80%9C%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%E2%80%9D%EF%BC%9A%3C%2FA%3E%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E4%B8%BB%E6%9C%BA%EF%BC%9Agithub.com%3CBR%20%2F%3E%7C%20%E5%85%8B%E9%9A%86%E5%88%B0'protobuf'...%3CBR%20%2F%3E%7C%20fatal%3A%20%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E'https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F'%EF%BC%9A%3C%2FA%3E%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E4%B8%BB%E6%9C%BA%EF%BC%9Agithub.com%3CBR%20%2F%3E%7C%20%E5%85%8B%E9%9A%86%E5%88%B0'protobuf'...%3CBR%20%2F%3E%7C%20fatal%3A%20%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E'https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F'%EF%BC%9A%3C%2FA%3E%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E4%B8%BB%E6%9C%BA%EF%BC%9Agithub.com%3CBR%20%2F%3E%7C%20--%20%E4%B8%8D%E5%BE%97%E4%B8%8D%20git%20%E5%85%8B%E9%9A%86%E4%B8%80%E6%AC%A1%E4%BB%A5%E4%B8%8A%EF%BC%9A3%20%E6%AC%A1%E3%80%82%3CBR%20%2F%3E%7C%20CMake%20Error%20at%20_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Ftmp%2Fprotobuf-populate-gitclone.cmake%3A39%20(message)%3A%3CBR%20%2F%3E%7C%20Failed%20to%20clone%20repository%3A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E'https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf'%3C%2FA%3E.%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%7C%20%E5%A4%B1%E8%B4%A5%EF%BC%9Aprotobuf%20%E5%A1%AB%E5%85%85%E5%89%8D%E7%BC%80%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-downl%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-tools-native%2F2.16.2%2Fbuild%2Fprotobuf-populate-subuf-subuf-polute-polate-polute-polate-polute-polate-tools-native%2Fbuild%2Ftmp%2F%7C%20cd%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%20%26amp%3B%20%26amp%3B%20%2Fwork%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2Fusr%2Fbin%2F%20%3CBR%20%2F%3Ecmake-P%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-populate-populate-protobuf-populate-gitclone.cmake%20%26amp%3B%20%26amp%3B%20%2Fwork%2Ftemp%2Fwork%2Fx86_64-linux%2Ftensor-liflow%20te-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcmake-E%20touch%20%2Fwork%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2Fprotobuf-lite-host-tools-native%2F2.16.2%2Fbuild%2Fprotobuf-lite-host-tools-native%2F2.16.2%2Fbuild%2Fprotobuf-%3CBR%20%2F%3E%7C%20ninja%EF%BC%9A%E6%9E%84%E5%BB%BA%E5%B7%B2%E5%81%9C%E6%AD%A2%EF%BC%9A%E5%AD%90%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%20%7C%20%E5%9C%A8%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2FTensorflow-Lite-Host-Tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2Fmodules%2FfetchContent.cmake%3A1679%EF%BC%88%E6%B6%88%E6%81%AF%EF%BC%89%E5%A4%84%E5%87%BA%E7%8E%B0%20CMake%20%E9%94%99%E8%AF%AF%EF%BC%9A%7C%20protobuf%20%E7%9A%84%E6%9E%84%E5%BB%BA%E6%AD%A5%E9%AA%A4%E5%A4%B1%E8%B4%A5%EF%BC%9A1%20%7C%20%E8%B0%83%E7%94%A8%E5%A0%86%E6%A0%88%EF%BC%88%E6%9C%80%E8%BF%91%E4%B8%80%E6%AC%A1%E8%B0%83%E7%94%A8%E4%BC%98%E5%85%88%EF%BC%89%EF%BC%9A%7C%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2FTensorflow-Lite-Lite-Host-Tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2Fmodules%2FfetchContent.cmake%3A%201819%3Aeval%3A%202%20(__fetchContent_DirectPolate)%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_linux%2Fcmake-3.28%2Fmodules%2FfetchContent.csorflow-lite-host-tools-native%2F2.16.2%2Frecipe-%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Esysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2Fmodules%2FfetchContent.cmake%3A%201819%20(cmake_language)%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2FTensorflow-Lite-Tools-native%2FTensorflow-Lite-Tools-native%2FTensorflow-Lite-Tools-native%2FTensorflow-Lite-Tools-native%2FTensorflow-Lite%20%3CBR%20%2F%3E(FetchContent_Populate)%3CBR%20%2F%3E%7C%20%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2Fprotobuf.cmake%3A37%20%EF%BC%88overridableFetchContent_Populate%EF%BC%89%3CBR%20%2F%3E%7C%20%2Fworkdir%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2FTensorflow-Lite-Host-Tools-native%2F2.16.2%2Fgit%2FTensorflow%2FLite%2FLite%2FTools%2Fcmake%2Fcmake%2Ffindprotobuf.cmake%3A%2018%20(include)%3CBR%20%2F%3E%7C%20protobuf%2FCMakeLists.txt%3A34%20(find_package)%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%20--%20%E9%85%8D%E7%BD%AE%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%81%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%EF%BC%9AShell%20%E5%91%BD%E4%BB%A4%E7%9A%84%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%201%E3%80%82%3CBR%20%2F%3E%7C%20%2B%20bb_sh_exit_handler%3CBR%20%2F%3E%7C%20%2B%20ret%3D1%3CBR%20%2F%3E%7C%20%2B%20%5B%201%20!%3D%200%20%5D%3CBR%20%2F%3E%7C%20%2B%20echo%20WARNING%3A%20exit%20code%201%20from%20a%20shell%20command.%3CBR%20%2F%3E%7C%20%2B%20%E9%80%80%E5%87%BA%201%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%E8%99%9A%E6%8B%9F%3Anative%3A%2Fworkdir%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2F%E9%85%8D%E6%96%B9s-libraries%2Ftensorflow-lite%2Ftensorflow-lite-host-tools_2.16.2.bb%3Ado_configure%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%20%E2%80%9C1%E2%80%9D%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%205477%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%205471%20%E4%B8%AA%E4%B8%8D%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C1%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E6%92%B0%E5%86%99%E5%BB%BA%E7%AB%8B%E5%8E%86%E5%8F%B2%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E6%92%B0%E5%86%99%E5%BB%BA%E7%AB%8B%E5%8E%86%E5%8F%B2%E7%94%A8%E6%97%B6%EF%BC%9A9%20%E7%A7%92%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%B8%8B%E8%BD%BD%E4%BA%86%E5%AE%8C%E6%95%B4%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%E5%B9%B6%E7%89%88%E6%9C%AC%E4%BA%86%E5%AE%8C%E6%95%B4%E9%95%9C%E5%83%8F%EF%BC%8C%E4%BD%A0%E5%BA%94%E8%AF%A5%E4%B8%8D%E4%BC%9A%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%E6%9D%A5%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
