failed to build tensorflow on offline machine for imx8mp Scarthgap
greeran
I’m building the fsl-image-qt6 image for i.MX8MP with Scarthgap. I built it on an online machine and copied the downloads directory to the offline machine. I’ve successfully used this workflow many times before with other BSP releases (Kirkstone, Zeus, and others), so this isn’t my first offline BSP build.
However, when I try to build the same image on the offline machine, the build fails at tensorflow-lite-tools-native. It seems to attempt cloning extended third-party dependencies (protobuf, etc.), and the downloaded tar.gz files are not sufficient to satisfy it.
Has anyone come across this issue before? If so, what’s the recommended way to resolve it?
Thanks in advance
greeran
i delete all my build, download and sstate and rebuild from scratch. the build was long but successful. i then removed the build_xwayland directory (and kept the downloads and sstate path in the site.conf). i added this flags to the
BB_NO_NETWORK = "1"
BB_FETCH_PREMIRRORONLY = "1"
i removed the internet cable to simulate my offline computer. when running the bitbake fsl-image-qt6 it fails in the parsing
WARNING: /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb: Exception during build_dependencies for fetcher_hashes_dummyfunc | ETA: 0:00:04
WARNING: /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb: Error during finalise of /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb
ERROR: ExpansionError during parsing /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb
Traceback (most recent call last):
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 1248, in srcrev_internal_helper(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
d.setVar("__BBAUTOREV_ACTED_UPON", True)
> srcrev = ud.method.latest_revision(ud, d, name)
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 1670, in GitSM.latest_revision(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
except KeyError:
> revs[key] = rev = self._latest_revision(ud, d, name)
return rev
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/git.py", line 850, in GitSM._latest_revision(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
> output = self._lsremote(ud, d, "")
# Tags of the form ^{} may not work, need to fallback to other form
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/git.py", line 832, in GitSM._lsremote(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, search=''):
if ud.proto.lower() != 'file':
> bb.fetch2.check_network_access(d, cmd, repourl)
output = runfetchcmd(cmd, d, True)
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 970, in check_network_access(d=<bb.data_smart.DataSmart object at 0x78233207c820>, info='git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://github.com/NXP/matter.git ', url='https://github.com/NXP/matter.git'):
if bb.utils.to_boolean(d.getVar("BB_NO_NETWORK")):
> raise NetworkAccess(url, info)
elif not trusted_network(d, url):
bb.data_smart.ExpansionError: Failure expanding variable fetcher_hashes_dummyfunc[vardepvalue], expression was ${@bb.fetch.get_hashvalue(d)} which triggered exception NetworkAccess: Network access disabled through BB_NO_NETWORK (or set indirectly due to use of BB_FETCH_PREMIRRORONLY) but access requested with command git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://github.com/NXP/matter.git (for url https://github.com/NXP/matter.git)
The variable dependency chain for the failure is: fetcher_hashes_dummyfunc[vardepvalue]
ERROR: Parsing halted due to errors, see error messages above
Summary: There were 2 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
to fix it i need to connect to the internet and then run bitbake fsl-image-qt6 --runall=fetch and then offline build works. the problem that in the offline machine i will not be able to do the runall=fetch.
might you know what my error is and why i am not able to build offline
thanks
greeran
thanks for the response
i am sending the manifests from the repo and the error i get. i tried downloading the download twice and i still get the same error when running in offline (BB_NO_NETWORK = "1" and BB+GENERATE_MIRROR_TARBALLS  = "1" )
<manifest>
<include name="imx-6.6.52-2.2.0.xml" />
</manifest>
this is the manifests from the repo
<manifest>
<default revision="scarthgap" sync-j="4"/>
<remote name="yp" fetch="https://git.yoctoproject.org"/>
<remote name="yp-gh" fetch="https://github.com/yoctoproject"/>
<remote name="oe" fetch="https://github.com/openembedded"/>
<remote name="kraj" fetch="https://github.com/kraj"/>
<remote name="community" fetch="https://github.com/Freescale"/>
<remote name="ossystems" fetch="https://github.com/OSSystems"/>
<remote name="qt" fetch="https://github.com/YoeDistro"/>
<remote name="timesys" fetch="https://github.com/TimesysGit"/>
<remote name="imx" fetch="https://github.com/nxp-imx"/>
<remote name="imx-support" fetch="https://github.com/nxp-imx-support"/>
<remote name="sbabic" fetch="https://github.com/sbabic"/>
<remote name="variscite" fetch="https://github.com/varigit"/>
<project name="poky" remote="yp-gh" path="sources/poky" revision="200d12b6a58ad961d60a7774ca0f7a9d29498724" upstream="scarthgap"/>
<project name="meta-openembedded" remote="oe" path="sources/meta-openembedded" revision="72018ca1b1a471226917e8246e8bbf9a374ccf97" upstream="scarthgap"/>
<project name="meta-clang" remote="kraj" path="sources/meta-clang" revision="2b7433611d80f6d0ee1b04156fa91fc73d3c2665" upstream="scarthgap"/>
<project name="meta-freescale" remote="community" path="sources/meta-freescale" revision="0627128b341cfb2bef7a0832ce8cac0ce1127f13" upstream="scarthgap"/>
<project name="meta-freescale-3rdparty" remote="community" path="sources/meta-freescale-3rdparty" revision="6c063450d464eb2f380443c7d9af1b94ce9b9d75" upstream="scarthgap"/>
<project name="meta-freescale-distro" remote="community" path="sources/meta-freescale-distro" revision="b9d6a5d9931922558046d230c1f5f4ef6ee72345" upstream="scarthgap"/>
<project name="meta-arm" remote="yp" path="sources/meta-arm" revision="950a4afce46a359def2958bd9ae33fc08ff9bb0d" upstream="scarthgap"/>
<project name="meta-qt6" remote="qt" path="sources/meta-qt6" revision="586a6cb5aec755803a3be3cec359baafe89d6432" upstream="6.8"/>
<project name="meta-browser" remote="ossystems" path="sources/meta-browser" revision="dc31889c0899971def535dc1c040edf18bc16691"/>
<project name="meta-security" remote="yp" path="sources/meta-security" revision="459d837338ca230254baa2994f870bf6eb9d0139" upstream="scarthgap"/>
<project name="meta-timesys" remote="timesys" path="sources/meta-timesys" revision="4dc3f4bdfde4a86904b6e1a3d58df4696e7a63fa" upstream="scarthgap"/>
<project name="meta-virtualization" remote="yp" path="sources/meta-virtualization" revision="6f3c1d8f90947408a6587be222fec575a1ca5195" upstream="scarthgap"/>
<project name="meta-imx" remote="imx" path="sources/meta-imx" revision="219f6d04a4c339eb6f2dc626f944bbdf9a716ff5" upstream="scarthgap-6.6.52-2.2.0">
<linkfile src="tools/imx-setup-release.sh" dest="imx-setup-release.sh"/>
<linkfile src="README" dest="README-IMXBSP"/>
</project>
<project name="meta-nxp-connectivity" remote="imx" path="sources/meta-nxp-connectivity" revision="f58365ec75a5768ff3e8e8bcd64f237738c93160" upstream="imx_matter_2024_q3-post"/>
<project name="meta-nxp-demo-experience" remote="imx-support" path="sources/meta-nxp-demo-experience" revision="e8e646e22b1f926aac83bb7ad522efa9cd8ccc45" upstream="scarthgap-6.6.52-2.2.0"/>
<project name="meta-swupdate" remote="sbabic" path="sources/meta-swupdate" revision="d598d4e675b541301ea1dfc8f0c8931983b4dcd0" upstream="scarthgap"/>
<project name="meta-variscite-bsp-common" remote="variscite" path="sources/meta-variscite-bsp-common" revision="10fb8ca3956c6359a9f744da47197048cc28a483" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-bsp-imx" remote="variscite" path="sources/meta-variscite-bsp-imx" revision="19052e7e0b96814b84069fdfd0d03568271c7ec6" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-hab" remote="variscite" path="sources/meta-variscite-hab" revision="ec4e9f1b2f99ad03077af6b847c38f6e9c2378a7" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-sdk-common" remote="variscite" path="sources/meta-variscite-sdk-common" revision="ee4ade553e063e5daed4e083c62ebff647d9e7dd" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-sdk-imx" remote="variscite" path="sources/meta-variscite-sdk-imx" revision="fbd0a9e4a7390f66e63af63ec7338bced09686f1" upstream="scarthgap_6.6.52-2.2.0_var01">
<linkfile src="scripts/var-setup-release.sh" dest="var-setup-release.sh"/>
</project>
<project name="variscite-bsp-base" remote="variscite" path="sources/base" revision="fa940410b6fa12155da5827c06351791147107d0" upstream="scarthgap_6.6.52-2.2.0_var01">
<linkfile src="setup-environment" dest="setup-environment"/>
<linkfile src="README" dest="README"/>
<linkfile src="scripts/var-start-container.sh" dest="var-start-container.sh"/>
</project>
<project name="var-host-docker-containers" remote="variscite" path="sources/var-host-docker-containers" revision="dd7218bb6e1c76db77cf40552b4cad7dfaa795fc" upstream="master"/>
</manifest>
the error i get
Initialising tasks: 100% |##########################################################################################################################################################################| Time: 0:00:12
NOTE: Executing Tasks
ERROR: tensorflow-lite-host-tools-native-2.16.2-r0 do_configure: ExecutionError('/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/temp/run.do_configure.179032', 1, None, None)
ERROR: Logfile of failure stored in: /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/temp/log.do_configure.179032
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/workdir/sources/poky/meta/recipes-devtools/cmake/cmake-native_3.28.3.bb:do_populate_sysroot', '/workdir/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', 'virtual:native:/workdir/sources/poky/meta/recipes-devtools/ninja/ninja_1.11.1.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'cmake-native', 'libtool-native', 'quilt-native', 'texinfo-dummy-native', 'openssl-native', 'ncurses-native', 'zlib-native', 'make-native', 'ninja-native', 'perl-native', 'bzip2-native', 'xz-native', 'zstd-native', 'gdbm-native', 're2c-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_configure
| + export HTTP_PROXY=
| + export HTTPS_PROXY=
| + export http_proxy=
| + export https_proxy=
| + cmake_do_configure
| + [ /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git = /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build ]
| + [ -e /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/site-file.cmake ]
| + oecmake_sitefile=
| + cmake -G Ninja -DCMAKE_MAKE_PROGRAM=ninja /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/native_tools -DCMAKE_INSTALL_PREFIX:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr -DCMAKE_INSTALL_BINDIR:PATH=bin -DCMAKE_INSTALL_SBINDIR:PATH=sbin -DCMAKE_INSTALL_LIBEXECDIR:PATH=libexec -DCMAKE_INSTALL_SYSCONFDIR:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/etc -DCMAKE_INSTALL_SHAREDSTATEDIR:PATH=../com -DCMAKE_INSTALL_LOCALSTATEDIR:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/var -DCMAKE_INSTALL_LIBDIR:PATH=lib -DCMAKE_INSTALL_INCLUDEDIR:PATH=include -DCMAKE_INSTALL_DATAROOTDIR:PATH=share -DPYTHON_EXECUTABLE:PATH=/usr/bin/python3 -DPython_EXECUTABLE:PATH=/usr/bin/python3 -DPython3_EXECUTABLE:PATH=/usr/bin/python3 -DLIB_SUFFIX= -DCMAKE_INSTALL_SO_NO_EXE=0 -DCMAKE_TOOLCHAIN_FILE:FILEPATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/toolchain.cmake -DCMAKE_NO_SYSTEM_FROM_IMPORTED=1 -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DFETCHCONTENT_FULLY_DISCONNECTED=ON -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=ON -DFETCHCONTENT_FULLY_DISCONNECTED=OFF -DCMAKE_SYSROOT= -Wno-dev
| -- The C compiler identification is GNU 9.4.0
| -- The CXX compiler identification is GNU 9.4.0
| -- Detecting C compiler ABI info
| -- Detecting C compiler ABI info - done
| -- Check for working C compiler: /workdir/build/tmp/hosttools/gcc - skipped
| -- Detecting C compile features
| -- Detecting C compile features - done
| -- Detecting CXX compiler ABI info
| -- Detecting CXX compiler ABI info - done
| -- Check for working CXX compiler: /workdir/build/tmp/hosttools/g++ - skipped
| -- Detecting CXX compile features
| -- Detecting CXX compile features - done
| -- Cloning flatbuffers repository from http://localhost:8080/7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz, found in /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/../third_party/flatbuffers/workspace.bzl
| -- Cloning flatbuffers repository revision 7d6d99c6befa635780a4e944d37ebfd58e68a108, found in /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/../third_party/flatbuffers/workspace.bzl
| -- Proceeding with version: 23.5.26.0
| -- Looking for strtof_l
| -- Looking for strtof_l - found
| -- Looking for strtoull_l
| -- Looking for strtoull_l - found
| -- Looking for realpath
| -- Looking for realpath - found
| -- CMAKE_CXX_FLAGS: -isystem/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/include -O2 -pipe
| -- Cloning https://github.com/protocolbuffers/protobuf...
| [1/9] Creating directories for 'protobuf-populate'
| [1/9] Performing download step (git clone) for 'protobuf-populate'
| Cloning into 'protobuf'...
| fatal: unable to access 'https://github.com/protocolbuffers/protobuf/': Could not resolve host: github.com
| -- Had to git clone more than once: 3 times.
| CMake Error at _deps/protobuf-subbuild/protobuf-populate-prefix/tmp/protobuf-populate-gitclone.cmake:39 (message):
| Failed to clone repository: 'https://github.com/protocolbuffers/protobuf'
| FAILED: protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download
| cd /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build && /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/bin/cmake -P /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/tmp/protobuf-populate-gitclone.cmake && /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/bin/cmake -E touch /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download
| ninja: build stopped: subcommand failed.
| CMake Error at /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1679 (message):
| Build step for protobuf failed: 1
| Call Stack (most recent call first):
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1819:EVAL:2 (__FetchContent_directPopulate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1819 (cmake_language)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/OverridableFetchContent.cmake:537 (FetchContent_Populate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/protobuf.cmake:37 (OverridableFetchContent_Populate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/Findprotobuf.cmake:18 (include)
| protobuf/CMakeLists.txt:34 (find_package)
| -- Configuring incomplete, errors occurred!
| WARNING: exit code 1 from a shell command.
| + bb_sh_exit_handler
| + ret=1
| + [ 1 != 0 ]
| + echo WARNING: exit code 1 from a shell command.
| + exit 1
ERROR: Task (virtual:native:/workdir/sources/meta-imx/meta-imx-ml/recipes-libraries/tensorflow-lite/tensorflow-lite-host-tools_2.16.2.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5477 tasks of which 5471 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 9 seconds
Bio_TICFSL
You need to erase everything and restart to download yocto, since I can not reproduce the issue in my building. If you are working with none BSP from NXP, please contact your vendor for this issue.
greeran
hello
after a number of deletions and build i have found a workaround for the problem. it seems that the branch and has for the matter did not match between the downloads/github..matter.git to the bb file. i added to my site.conf
SRCBRANCH:pn-matter = "release/v1.4.
SRCREV:pn-matter = "9042e9281bf619ce0d06d043d5ac3c0c34c24bbe"
and that solved the parsing error. after that  i have a fetch error that tried to get the thirdparty/nxp_matter_support that i did not find in my downloads (which successfully build an image with internet). so to workaround this problem i removed all the installs for "packagegroup-nxp-matter" and such.
This did not solve the problem but enabled me to build my image and because i do not need the application that use the matter it is a sufficient workaround
thanks
Bio_TICFSL
If you download the complete bsp and build the full-image you should not have any issue, please tell us which BSP are you using to test.
greeran
i am deleted all the build and download and sstate. i am now building from scratch and hopefully tomorrow i will be able to test it with a clean build on a machine without internet
%3CLINGO-SUB%20id%3D%22lingo-sub-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efailed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EI%E2%80%99m%20building%20the%20fsl-image-qt6%20image%20for%20i.MX8MP%20with%20Scarthgap.%20I%20built%20it%20on%20an%20online%20machine%20and%20copied%20the%20downloads%20directory%20to%20the%20offline%20machine.%20I%E2%80%99ve%20successfully%20used%20this%20workflow%20many%20times%20before%20with%20other%20BSP%20releases%20(Kirkstone%2C%20Zeus%2C%20and%20others)%2C%20so%20this%20isn%E2%80%99t%20my%20first%20offline%20BSP%20build.%3C%2FP%3E%3CP%3EHowever%2C%20when%20I%20try%20to%20build%20the%20same%20image%20on%20the%20offline%20machine%2C%20the%20build%20fails%20at%20tensorflow-lite-tools-native.%20It%20seems%20to%20attempt%20cloning%20extended%20third-party%20dependencies%20(protobuf%2C%20etc.)%2C%20and%20the%20downloaded%20tar.gz%20files%20are%20not%20sufficient%20to%20satisfy%20it.%3C%2FP%3E%3CP%3EHas%20anyone%20come%20across%20this%20issue%20before%3F%20If%20so%2C%20what%E2%80%99s%20the%20recommended%20way%20to%20resolve%20it%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGraphics%20%26amp%3B%20Display%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%3C%2FP%3E%3CP%3Eafter%20a%20number%20of%20deletions%20and%20build%20i%20have%20found%20a%20workaround%20for%20the%20problem.%20it%20seems%20that%20the%20branch%20and%20has%20for%20the%20matter%20did%20not%20match%20between%20the%20downloads%2Fgithub..matter.git%20to%20the%20bb%20file.%20i%20added%20to%20my%20site.conf%26nbsp%3B%3C%2FP%3E%3CP%3ESRCBRANCH%3Apn-matter%20%3D%20%22release%2Fv1.4.%3C%2FP%3E%3CP%3ESRCREV%3Apn-matter%20%3D%20%229042e9281bf619ce0d06d043d5ac3c0c34c24bbe%22%3C%2FP%3E%3CP%3Eand%20that%20solved%20the%20parsing%20error.%20after%20that%26nbsp%3B%20i%20have%20a%20fetch%20error%20that%20tried%20to%20get%20the%20thirdparty%2Fnxp_matter_support%20that%20i%20did%20not%20find%20in%20my%20downloads%20(which%20successfully%20build%20an%20image%20with%20internet).%20so%20to%20workaround%20this%20problem%20i%20removed%20all%20the%20installs%20for%20%22packagegroup-nxp-matter%22%20and%20such.%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20did%20not%20solve%20the%20problem%20but%20enabled%20me%20to%20build%20my%20image%20and%20because%20i%20do%20not%20need%20the%20application%20that%20use%20the%20matter%20it%20is%20a%20sufficient%20workaround%26nbsp%3B%3C%2FP%3E%3CP%3Ethanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20delete%20all%20my%20build%2C%20download%20and%20sstate%20and%20rebuild%20from%20scratch.%20the%20build%20was%20long%20but%20successful.%20i%20then%20removed%20the%20build_xwayland%20directory%20(and%20kept%20the%20downloads%20and%20sstate%20path%20in%20the%20site.conf).%20i%20added%20this%20flags%20to%20the%26nbsp%3B%3C%2FP%3E%3CP%3EBB_NO_NETWORK%20%3D%20%221%22%3CBR%20%2F%3EBB_FETCH_PREMIRRORONLY%20%3D%20%221%22%3C%2FP%3E%3CP%3Ei%20removed%20the%20internet%20cable%20to%20simulate%20my%20offline%20computer.%20when%20running%20the%20bitbake%26nbsp%3Bfsl-image-qt6%20it%20fails%20in%20the%20parsing%3C%2FP%3E%3CP%3EWARNING%3A%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter%2Fmatter%2Fmatter.bb%3A%20Exception%20during%20build_dependencies%20for%20fetcher_hashes_dummyfunc%20%7C%20ETA%3A%200%3A00%3A04%3CBR%20%2F%3EWARNING%3A%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter%2Fmatter%2Fmatter.bb%3A%20Error%20during%20finalise%20of%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter%2Fmatter%2Fmatter.bb%3CBR%20%2F%3EERROR%3A%20ExpansionError%20during%20parsing%20%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fmeta-nxp-connectivity%2Fmeta-nxp-matter-baseline%2Frecipes-matter%2Fmatter%2Fmatter.bb%3CBR%20%2F%3ETraceback%20(most%20recent%20call%20last)%3A%3CBR%20%2F%3EFile%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__.py%22%2C%20line%201248%2C%20in%20srcrev_internal_helper(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%2C%20d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%2C%20name%3D'default')%3A%3CBR%20%2F%3Ed.setVar(%22__BBAUTOREV_ACTED_UPON%22%2C%20True)%3CBR%20%2F%3E%26gt%3B%20srcrev%20%3D%20ud.method.latest_revision(ud%2C%20d%2C%20name)%3CBR%20%2F%3E%3CBR%20%2F%3EFile%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__.py%22%2C%20line%201670%2C%20in%20GitSM.latest_revision(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%2C%20d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%2C%20name%3D'default')%3A%3CBR%20%2F%3Eexcept%20KeyError%3A%3CBR%20%2F%3E%26gt%3B%20revs%5Bkey%5D%20%3D%20rev%20%3D%20self._latest_revision(ud%2C%20d%2C%20name)%3CBR%20%2F%3Ereturn%20rev%3CBR%20%2F%3EFile%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%22%2C%20line%20850%2C%20in%20GitSM._latest_revision(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%2C%20d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%2C%20name%3D'default')%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%26gt%3B%20output%20%3D%20self._lsremote(ud%2C%20d%2C%20%22%22)%3CBR%20%2F%3E%23%20Tags%20of%20the%20form%20%5E%7B%7D%20may%20not%20work%2C%20need%20to%20fallback%20to%20other%20form%3CBR%20%2F%3EFile%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%22%2C%20line%20832%2C%20in%20GitSM._lsremote(ud%3D%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%2C%20d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%2C%20search%3D'')%3A%3CBR%20%2F%3Eif%20ud.proto.lower()%20!%3D%20'file'%3A%3CBR%20%2F%3E%26gt%3B%20bb.fetch2.check_network_access(d%2C%20cmd%2C%20repourl)%3CBR%20%2F%3Eoutput%20%3D%20runfetchcmd(cmd%2C%20d%2C%20True)%3CBR%20%2F%3EFile%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__.py%22%2C%20line%20970%2C%20in%20check_network_access(d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%2C%20info%3D'git%20-c%20gc.autoDetach%3Dfalse%20-c%20core.pager%3Dcat%20-c%20safe.bareRepository%3Dall%20ls-remote%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%20'%2C%20url%3D'%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E')%3A%3CBR%20%2F%3Eif%20bb.utils.to_boolean(d.getVar(%22BB_NO_NETWORK%22))%3A%3CBR%20%2F%3E%26gt%3B%20raise%20NetworkAccess(url%2C%20info)%3CBR%20%2F%3Eelif%20not%20trusted_network(d%2C%20url)%3A%3CBR%20%2F%3Ebb.data_smart.ExpansionError%3A%20Failure%20expanding%20variable%20fetcher_hashes_dummyfunc%5Bvardepvalue%5D%2C%20expression%20was%20%24%7B%40bb.fetch.get_hashvalue(d)%7D%20which%20triggered%20exception%20NetworkAccess%3A%20Network%20access%20disabled%20through%20BB_NO_NETWORK%20(or%20set%20indirectly%20due%20to%20use%20of%20BB_FETCH_PREMIRRORONLY)%20but%20access%20requested%20with%20command%20git%20-c%20gc.autoDetach%3Dfalse%20-c%20core.pager%3Dcat%20-c%20safe.bareRepository%3Dall%20ls-remote%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%20(for%20url%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E)%3CBR%20%2F%3EThe%20variable%20dependency%20chain%20for%20the%20failure%20is%3A%20fetcher_hashes_dummyfunc%5Bvardepvalue%5D%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FP%3E%3CP%3EERROR%3A%20Parsing%20halted%20due%20to%20errors%2C%20see%20error%20messages%20above%3C%2FP%3E%3CP%3ESummary%3A%20There%20were%202%20WARNING%20messages.%3CBR%20%2F%3ESummary%3A%20There%20were%202%20ERROR%20messages%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FP%3E%3CP%3Eto%20fix%20it%20i%20need%20to%20connect%20to%20the%20internet%20and%20then%20run%26nbsp%3Bbitbake%20fsl-image-qt6%20--runall%3Dfetch%20and%20then%20offline%20build%20works.%20the%20problem%20that%20in%20the%20offline%20machine%20i%20will%20not%20be%20able%20to%20do%20the%20runall%3Dfetch.%3C%2FP%3E%3CP%3Emight%20you%20know%20what%20my%20error%20is%20and%20why%20i%20am%20not%20able%20to%20build%20offline%3C%2FP%3E%3CP%3Ethanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2160999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20am%20deleted%20all%20the%20build%20and%20download%20and%20sstate.%20i%20am%20now%20building%20from%20scratch%20and%20hopefully%20tomorrow%20i%20will%20be%20able%20to%20test%20it%20with%20a%20clean%20build%20on%20a%20machine%20without%20internet%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EYou%20need%20to%20erase%20everything%20and%20restart%20to%20download%20yocto%2C%20since%20I%20can%20not%20reproduce%20the%20issue%20in%20my%20building.%20If%20you%20are%20working%20with%20none%20BSP%20from%20NXP%2C%20please%20contact%20your%20vendor%20for%20this%20issue.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethanks%20for%20the%20response%3C%2FP%3E%3CP%3Ei%20am%20sending%20the%20manifests%20from%20the%20repo%20and%20the%20error%20i%20get.%20i%20tried%20downloading%20the%20download%20twice%20and%20i%20still%20get%20the%20same%20error%20when%20running%20in%20offline%20(BB_NO_NETWORK%20%3D%20%221%22%20and%20BB%2BGENERATE_MIRROR_TARBALLS%26nbsp%3B%20%3D%20%221%22%20)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CMANIFEST%3E%3CBR%20%2F%3E%3CINCLUDE%20name%3D%22imx-6.6.52-2.2.0.xml%22%3E%3C%2FINCLUDE%3E%3CBR%20%2F%3E%3C%2FMANIFEST%3E%3C%2FP%3E%3CP%3Ethis%20is%20the%20manifests%20from%20the%20repo%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CMANIFEST%3E%3C%2FMANIFEST%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CDEFAULT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esync-j%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FDEFAULT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgit.yoctoproject.org%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgit.yoctoproject.org%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eyp-gh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fyoctoproject%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fyoctoproject%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eoe%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fopenembedded%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fopenembedded%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ekraj%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fkraj%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fkraj%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ecommunity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eossystems%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOSSystems%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FOSSystems%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eqt%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FYoeDistro%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FYoeDistro%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Etimesys%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FTimesysGit%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FTimesysGit%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx-support%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esbabic%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fsbabic%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fsbabic%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CREMOTE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efetch%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fvarigit%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fvarigit%3C%2FA%3E%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Epoky%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eyp-gh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fpoky%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E200d12b6a58ad961d60a7774ca0f7a9d29498724%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-openembedded%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eoe%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-openembedded%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E72018ca1b1a471226917e8246e8bbf9a374ccf97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-clang%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ekraj%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-clang%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E2b7433611d80f6d0ee1b04156fa91fc73d3c2665%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-freescale%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ecommunity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-freescale%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E0627128b341cfb2bef7a0832ce8cac0ce1127f13%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-freescale-3rdparty%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ecommunity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-freescale-3rdparty%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E6c063450d464eb2f380443c7d9af1b94ce9b9d75%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-freescale-distro%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ecommunity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-freescale-distro%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eb9d6a5d9931922558046d230c1f5f4ef6ee72345%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-arm%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-arm%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E950a4afce46a359def2958bd9ae33fc08ff9bb0d%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-qt6%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eqt%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-qt6%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E586a6cb5aec755803a3be3cec359baafe89d6432%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E6.8%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-browser%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eossystems%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-browser%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Edc31889c0899971def535dc1c040edf18bc16691%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-security%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-security%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E459d837338ca230254baa2994f870bf6eb9d0139%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-timesys%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Etimesys%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-timesys%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E4dc3f4bdfde4a86904b6e1a3d58df4696e7a63fa%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-virtualization%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-virtualization%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E6f3c1d8f90947408a6587be222fec575a1ca5195%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E219f6d04a4c339eb6f2dc626f944bbdf9a716ff5%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap-6.6.52-2.2.0%3C%2FSPAN%3E%22%3C%2FSPAN%3E%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Etools%2Fimx-setup-release.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx-setup-release.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3EREADME%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3EREADME-IMXBSP%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-nxp-connectivity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-nxp-connectivity%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ef58365ec75a5768ff3e8e8bcd64f237738c93160%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx_matter_2024_q3-post%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-nxp-demo-experience%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eimx-support%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-nxp-demo-experience%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ee8e646e22b1f926aac83bb7ad522efa9cd8ccc45%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap-6.6.52-2.2.0%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-swupdate%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esbabic%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-swupdate%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Ed598d4e675b541301ea1dfc8f0c8931983b4dcd0%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-variscite-bsp-common%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-bsp-common%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E10fb8ca3956c6359a9f744da47197048cc28a483%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-variscite-bsp-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-bsp-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E19052e7e0b96814b84069fdfd0d03568271c7ec6%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-variscite-hab%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-hab%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eec4e9f1b2f99ad03077af6b847c38f6e9c2378a7%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-variscite-sdk-common%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-sdk-common%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Eee4ade553e063e5daed4e083c62ebff647d9e7dd%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-variscite-sdk-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-sdk-imx%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Efbd0a9e4a7390f66e63af63ec7338bced09686f1%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%22%3C%2FSPAN%3E%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escripts%2Fvar-setup-release.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evar-setup-release.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite-bsp-base%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fbase%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Efa940410b6fa12155da5827c06351791147107d0%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%22%3C%2FSPAN%3E%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esetup-environment%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esetup-environment%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3EREADME%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3EREADME%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CLINKFILE%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Escripts%2Fvar-start-container.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evar-start-container.sh%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FLINKFILE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CPROJECT%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evar-host-docker-containers%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eremote%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Evariscite%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epath%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Esources%2Fvar-host-docker-containers%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erevision%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Edd7218bb6e1c76db77cf40552b4cad7dfaa795fc%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eupstream%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emaster%3C%2FSPAN%3E%22%3C%2FSPAN%3E%2F%26gt%3B%3C%2FPROJECT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Ethe%20error%20i%20get%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CP%3EInitialising%20tasks%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A12%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3EERROR%3A%20tensorflow-lite-host-tools-native-2.16.2-r0%20do_configure%3A%20ExecutionError('%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftemp%2Frun.do_configure.179032'%2C%201%2C%20None%2C%20None)%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftemp%2Flog.do_configure.179032%3CBR%20%2F%3ELog%20data%20follows%3A%3CBR%20%2F%3E%7C%20DEBUG%3A%20Executing%20python%20function%20extend_recipe_sysroot%3CBR%20%2F%3E%7C%20NOTE%3A%20Direct%20dependencies%20are%20%5B'%2Fworkdir%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fcmake%2Fcmake-native_3.28.3.bb%3Ado_populate_sysroot'%2C%20'%2Fworkdir%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fquilt%2Fquilt-native_0.67.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fworkdir%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fninja%2Fninja_1.11.1.bb%3Ado_populate_sysroot'%5D%3CBR%20%2F%3E%7C%20NOTE%3A%20Installed%20into%20sysroot%3A%20%5B%5D%3CBR%20%2F%3E%7C%20NOTE%3A%20Skipping%20as%20already%20exists%20in%20sysroot%3A%20%5B'gettext-minimal-native'%2C%20'cmake-native'%2C%20'libtool-native'%2C%20'quilt-native'%2C%20'texinfo-dummy-native'%2C%20'openssl-native'%2C%20'ncurses-native'%2C%20'zlib-native'%2C%20'make-native'%2C%20'ninja-native'%2C%20'perl-native'%2C%20'bzip2-native'%2C%20'xz-native'%2C%20'zstd-native'%2C%20'gdbm-native'%2C%20're2c-native'%5D%3CBR%20%2F%3E%7C%20DEBUG%3A%20Python%20function%20extend_recipe_sysroot%20finished%3CBR%20%2F%3E%7C%20DEBUG%3A%20Executing%20shell%20function%20do_configure%3CBR%20%2F%3E%7C%20%2B%20export%20HTTP_PROXY%3D%3CBR%20%2F%3E%7C%20%2B%20export%20HTTPS_PROXY%3D%3CBR%20%2F%3E%7C%20%2B%20export%20http_proxy%3D%3CBR%20%2F%3E%7C%20%2B%20export%20https_proxy%3D%3CBR%20%2F%3E%7C%20%2B%20cmake_do_configure%3CBR%20%2F%3E%7C%20%2B%20%5B%20%5D%3CBR%20%2F%3E%7C%20%2B%20%5B%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%20%3D%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%20%5D%3CBR%20%2F%3E%7C%20%2B%20%5B%20-e%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fsite-file.cmake%20%5D%3CBR%20%2F%3E%7C%20%2B%20oecmake_sitefile%3D%3CBR%20%2F%3E%7C%20%2B%20cmake%20-G%20Ninja%20-DCMAKE_MAKE_PROGRAM%3Dninja%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fnative_tools%20-DCMAKE_INSTALL_PREFIX%3APATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%20-DCMAKE_INSTALL_BINDIR%3APATH%3Dbin%20-DCMAKE_INSTALL_SBINDIR%3APATH%3Dsbin%20-DCMAKE_INSTALL_LIBEXECDIR%3APATH%3Dlibexec%20-DCMAKE_INSTALL_SYSCONFDIR%3APATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fetc%20-DCMAKE_INSTALL_SHAREDSTATEDIR%3APATH%3D..%2Fcom%20-DCMAKE_INSTALL_LOCALSTATEDIR%3APATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fvar%20-DCMAKE_INSTALL_LIBDIR%3APATH%3Dlib%20-DCMAKE_INSTALL_INCLUDEDIR%3APATH%3Dinclude%20-DCMAKE_INSTALL_DATAROOTDIR%3APATH%3Dshare%20-DPYTHON_EXECUTABLE%3APATH%3D%2Fusr%2Fbin%2Fpython3%20-DPython_EXECUTABLE%3APATH%3D%2Fusr%2Fbin%2Fpython3%20-DPython3_EXECUTABLE%3APATH%3D%2Fusr%2Fbin%2Fpython3%20-DLIB_SUFFIX%3D%20-DCMAKE_INSTALL_SO_NO_EXE%3D0%20-DCMAKE_TOOLCHAIN_FILE%3AFILEPATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftoolchain.cmake%20-DCMAKE_NO_SYSTEM_FROM_IMPORTED%3D1%20-DCMAKE_EXPORT_NO_PACKAGE_REGISTRY%3DON%20-DFETCHCONTENT_FULLY_DISCONNECTED%3DON%20-DCMAKE_EXPORT_COMPILE_COMMANDS%3ABOOL%3DON%20-DFETCHCONTENT_FULLY_DISCONNECTED%3DOFF%20-DCMAKE_SYSROOT%3D%20-Wno-dev%3CBR%20%2F%3E%7C%20--%20The%20C%20compiler%20identification%20is%20GNU%209.4.0%3CBR%20%2F%3E%7C%20--%20The%20CXX%20compiler%20identification%20is%20GNU%209.4.0%3CBR%20%2F%3E%7C%20--%20Detecting%20C%20compiler%20ABI%20info%3CBR%20%2F%3E%7C%20--%20Detecting%20C%20compiler%20ABI%20info%20-%20done%3CBR%20%2F%3E%7C%20--%20Check%20for%20working%20C%20compiler%3A%20%2Fworkdir%2Fbuild%2Ftmp%2Fhosttools%2Fgcc%20-%20skipped%3CBR%20%2F%3E%7C%20--%20Detecting%20C%20compile%20features%3CBR%20%2F%3E%7C%20--%20Detecting%20C%20compile%20features%20-%20done%3CBR%20%2F%3E%7C%20--%20Detecting%20CXX%20compiler%20ABI%20info%3CBR%20%2F%3E%7C%20--%20Detecting%20CXX%20compiler%20ABI%20info%20-%20done%3CBR%20%2F%3E%7C%20--%20Check%20for%20working%20CXX%20compiler%3A%20%2Fworkdir%2Fbuild%2Ftmp%2Fhosttools%2Fg%2B%2B%20-%20skipped%3CBR%20%2F%3E%7C%20--%20Detecting%20CXX%20compile%20features%3CBR%20%2F%3E%7C%20--%20Detecting%20CXX%20compile%20features%20-%20done%3CBR%20%2F%3E%7C%20--%20Cloning%20flatbuffers%20repository%20from%20%3CA%20href%3D%22http%3A%2F%2Flocalhost%3A8080%2F7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Flocalhost%3A8080%2F7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz%3C%2FA%3E%2C%20found%20in%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2F..%2Fthird_party%2Fflatbuffers%2Fworkspace.bzl%3CBR%20%2F%3E%7C%20--%20Cloning%20flatbuffers%20repository%20revision%207d6d99c6befa635780a4e944d37ebfd58e68a108%2C%20found%20in%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2F..%2Fthird_party%2Fflatbuffers%2Fworkspace.bzl%3CBR%20%2F%3E%7C%20--%20Proceeding%20with%20version%3A%2023.5.26.0%3CBR%20%2F%3E%7C%20--%20Looking%20for%20strtof_l%3CBR%20%2F%3E%7C%20--%20Looking%20for%20strtof_l%20-%20found%3CBR%20%2F%3E%7C%20--%20Looking%20for%20strtoull_l%3CBR%20%2F%3E%7C%20--%20Looking%20for%20strtoull_l%20-%20found%3CBR%20%2F%3E%7C%20--%20Looking%20for%20realpath%3CBR%20%2F%3E%7C%20--%20Looking%20for%20realpath%20-%20found%3CBR%20%2F%3E%7C%20--%20CMAKE_CXX_FLAGS%3A%20-isystem%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Finclude%20-O2%20-pipe%3CBR%20%2F%3E%7C%20--%20Cloning%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%3C%2FA%3E...%3CBR%20%2F%3E%7C%20%5B1%2F9%5D%20Creating%20directories%20for%20'protobuf-populate'%3CBR%20%2F%3E%7C%20%5B1%2F9%5D%20Performing%20download%20step%20(git%20clone)%20for%20'protobuf-populate'%3CBR%20%2F%3E%7C%20Cloning%20into%20'protobuf'...%3CBR%20%2F%3E%7C%20fatal%3A%20unable%20to%20access%20'%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%3C%2FA%3E'%3A%20Could%20not%20resolve%20host%3A%20github.com%3CBR%20%2F%3E%7C%20Cloning%20into%20'protobuf'...%3CBR%20%2F%3E%7C%20fatal%3A%20unable%20to%20access%20'%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%3C%2FA%3E'%3A%20Could%20not%20resolve%20host%3A%20github.com%3CBR%20%2F%3E%7C%20Cloning%20into%20'protobuf'...%3CBR%20%2F%3E%7C%20fatal%3A%20unable%20to%20access%20'%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%3C%2FA%3E'%3A%20Could%20not%20resolve%20host%3A%20github.com%3CBR%20%2F%3E%7C%20--%20Had%20to%20git%20clone%20more%20than%20once%3A%203%20times.%3CBR%20%2F%3E%7C%20CMake%20Error%20at%20_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Ftmp%2Fprotobuf-populate-gitclone.cmake%3A39%20(message)%3A%3CBR%20%2F%3E%7C%20Failed%20to%20clone%20repository%3A%20'%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%3C%2FA%3E'%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%20FAILED%3A%20protobuf-populate-prefix%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-download%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-download%3CBR%20%2F%3E%7C%20cd%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%20%26amp%3B%26amp%3B%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcmake%20-P%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Ftmp%2Fprotobuf-populate-gitclone.cmake%20%26amp%3B%26amp%3B%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcmake%20-E%20touch%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-download%3CBR%20%2F%3E%7C%20ninja%3A%20build%20stopped%3A%20subcommand%20failed.%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%20CMake%20Error%20at%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2FModules%2FFetchContent.cmake%3A1679%20(message)%3A%3CBR%20%2F%3E%7C%20Build%20step%20for%20protobuf%20failed%3A%201%3CBR%20%2F%3E%7C%20Call%20Stack%20(most%20recent%20call%20first)%3A%3CBR%20%2F%3E%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2FModules%2FFetchContent.cmake%3A1819%3AEVAL%3A2%20(__FetchContent_directPopulate)%3CBR%20%2F%3E%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2FModules%2FFetchContent.cmake%3A1819%20(cmake_language)%3CBR%20%2F%3E%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2FOverridableFetchContent.cmake%3A537%20(FetchContent_Populate)%3CBR%20%2F%3E%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2Fprotobuf.cmake%3A37%20(OverridableFetchContent_Populate)%3CBR%20%2F%3E%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2FFindprotobuf.cmake%3A18%20(include)%3CBR%20%2F%3E%7C%20protobuf%2FCMakeLists.txt%3A34%20(find_package)%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%20--%20Configuring%20incomplete%2C%20errors%20occurred!%3CBR%20%2F%3E%7C%20WARNING%3A%20exit%20code%201%20from%20a%20shell%20command.%3CBR%20%2F%3E%7C%20%2B%20bb_sh_exit_handler%3CBR%20%2F%3E%7C%20%2B%20ret%3D1%3CBR%20%2F%3E%7C%20%2B%20%5B%201%20!%3D%200%20%5D%3CBR%20%2F%3E%7C%20%2B%20echo%20WARNING%3A%20exit%20code%201%20from%20a%20shell%20command.%3CBR%20%2F%3E%7C%20%2B%20exit%201%3CBR%20%2F%3EERROR%3A%20Task%20(virtual%3Anative%3A%2Fworkdir%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2Frecipes-libraries%2Ftensorflow-lite%2Ftensorflow-lite-host-tools_2.16.2.bb%3Ado_configure)%20failed%20with%20exit%20code%20'1'%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%205477%20tasks%20of%20which%205471%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%3CBR%20%2F%3ENOTE%3A%20Writing%20buildhistory%3CBR%20%2F%3ENOTE%3A%20Writing%20buildhistory%20took%3A%209%20seconds%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EIf%20you%20download%20the%20complete%20bsp%20and%20build%20the%20full-image%20you%20should%20not%20have%20any%20issue%2C%20please%20tell%20us%20which%20BSP%20are%20you%20using%20to%20test.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
