THE DDR STRESS TEST IS FINE
enter desired START freq (135 to 672 MHz), then hit enter.
Note: DDR3 minimum is ~333MHz, do not recommend to go too much below this.
528
The freq you entered was: 528
Enter desired END freq (135 to 672 MHz), then hit enter.
Make sure this is equal to or greater than start freq
528
Beginning stress test
loop: 1
DDR Freq: 528 MHz
t0.1: data is addr test
t0: memcpy10 SSN x64 test
t1: memcpy8 SSN x64 test
t2: byte-wise SSN x64 test
t3: memcpy11 random pattern test
t4: IRAM_to_DDRv2 test
t5: IRAM_to_DDRv1 test
t6: read noise walking ones and zeros test
loop: 2
DDR Freq: 528 MHz
loop: 3
DDR Freq: 528 MHz
loop: 4
DDR Freq: 528 MHz
loop: 5
DDR Freq: 528 MHz
loop: 6
DDR Freq: 528 MHz
loop: 7
DDR Freq: 528 MHz
