export DISPLAY=:0.0,xrandr -o inverted/left/right command rotate the screen
勇姚
Rotate the screen(system is Linux and the MCU is MCIMX6Q5EYM10AD),use export DISPLAY=:0.0xrandr -o inverted/left/right command rotate the screen,after rotate the screen playing the video is very slowly.if do not rotate the screen playing the video is  normal(smooth)
Bio_TICFSL
Hi andy,
Current xrand is supported however there are some features that are not accelerated by GPU, and this is marked as a bug.
Reduced graphic performance with rotated screen (imx6, sabresd)
