Hi everyone,
Currently I have built the tpm2_tool library on the IMX8MQEVK board to communicate with SE050. But I don't know how to use this tool to turn SE050 into a TPM, if anyone knows any example of how to implement this tool, please help me.
DuongLV
We have the S05 with RT1060 and RT1170 please check it:
https://www.nxp.com/docs/en/application-note/AN12450.pdf
Thank you for the prompt support, but it seems you misunderstood my point. I have successfully built the Plug & Trust middleware on the i.MX8MQ EVK board, but I need to implement the TPM feature on the SE05x as described in the document https://www.nxp.com/docs/en/application-note/AN12663.pdf. Currently, I have built the SE-PLUG-TRUST-MW-ADDON-TPM, but I need additional examples to be able to implement the TPM functionality of the SE05x on my device.
