error in compiling ltib
3,516件の閲覧回数
AlexanderKelle1
I just got a i.mx53 quick start board, so I am rather new at this. I been trying to get ltib to compiling but everytime I try I get this error in the log. The log is in the attached file. I am using Ubuntu version 11.01. Any advice would be helpful.
タグ(1)
7 返答(返信)
3,362件の閲覧回数
AlexanderKelle1
I tried that command and the terminal said:
libncurses5-dev is already the newest version
0 upgrade, 0 newly installed, 0 removed and 0 not upgraded
I ran ltib again and it gave me the same error host_config file that I posted.
3,362件の閲覧回数
Kirill
sudo apt-get install libncurses5-dev  on my Ubuntu 10
3,362件の閲覧回数
Kirill
try to reinstall libncurses, check which packages in your system you need to build ltib, check versions
3,362件の閲覧回数
AlexanderKelle1
I am kind of confused on how to include the .o files in a .c file. Can you post example to show exactly what you are talking about. Thanks for your help.
3,362件の閲覧回数
Kirill
or did not attach object files with functions wmove, ... to linking process. try to grep this functions in your sources to define which file implement this function , and check if you have these files with extension .o after compilation, then check strings like "ar rc lxdialog.a checklist.o menubox.o textbox.o yesno.o inputbox.o util.o msgbox.o ", "gcc  -lncurses mconf.o zconf.tab.o lxdialog/lxdialog.a -o mconf" and if they do not included include them
3,362件の閲覧回数
KrishnaPavan
Most of the times the errors in compilation are caused due to missing packages and you have to choose correct paths & packages required.
The log clearly shows that..
Regards krishna pavan
3,361件の閲覧回数
Kirill
Hello, looks like you did not define "include" path for compilation process.
