error in compilation optee with Yocto for imx8mm
661 次查看
antonio_santagi
I am trying doing what suggested by the webpage linked on the document :
 https://www.nxp.com.cn/docs/en/application-note/AN12632.pdf
 it is this page :
https://source.codeaurora.org/external/imxsupport/imx_sec_apps/tree/enhanced-openssl/README.md
it is everything OK until I compile with bitbake :
bitbake -f -c compile optee-os-imx
bitbake optee-os-imx
I get error in compilation of recipe "Bison".
What should I do in this case ? I tried looking online for the error and applying a patch for it but it then gave me other error.
I was hoping that following those instructions would have led me quickly to have optee for imx8mm but it is not at the moment.
Is there an update I can use ?
thank you
标签 (1)
0 回复数
