eCSPI1 on i.MX51
eCSPI1 on i.MX51
646 次查看
GoranJakovljevi
Hi all,
I have a problem with using eCSPI1 on i.MX51. I can't access registers of this periphery. Every time I try to read or write, I got segmentation fault. Does anyone know why that is happening?
I guess the problem is related with fact that eCSPI1 is inside of SPBA Memory Range. Is there some way to enable it or access in some other way?
Thanks in advance and regards,
Goran
标签 (2)
标记 (5)
483 次查看
VladanJovanovic
Is clock to eCSPI1 enabled (CCGR4)?
484 次查看
VladanJovanovic
