dynamically change caps fro mfw_ipucsc and vpuenc
910 次查看
nagendrasarma
hi freescale
i am writing gstreamer application in which i have following requirement
video-source(1080p always)----> video scale-----> vpu encoder
the video scale will downscale the video to different formats (like 720 etc)
how to achieve this using gstreamer application
i am using  "gst_element_link_filtered"  call to change capabilities, working initially, but not working when changing dynamically
can anybody help me ?
regards
nagendra
标签 (1)
1 回复
802 次查看
joanxie
in fact, you needn't use this, you can set encoder format on the command, could you tell me what's your detailed case? you want to encode what resolution to what?
