Hello , how to setup the SABRE to dual screen with LVDS & HDMI
#printenv : // I add two line in uboot
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200 ${lvds_and_hdmi}'
setenv lvds_and_hdmi 'video=mxcdi0fb:RGB24,1024x768M@60 hdmi video=mxcdi1fb:RGB666,XGA di1_primary ldb=di1'
# when I login , I turn the screen on :
echo 0 > /sys/class/graphics/fb1/blank
# the terminal output
mxc_ipu mxc_ipu: Channel already disabled 7
mxc_ipu mxc_ipu: Channel already uninitialized 7
# when I plug HDMI connector to SABRE, the terminal output :
sii902x 2-0039: Sii902x: same edid
# I try to write some garbage to framebuffer
cat /bin/busybox > /dev/fb0
cat /bin/busybox > /dev/fb1
# LVDS (/dev/fb0) change
# HDMI (/dev/fb1) not change, the screen always show 'no signal'
It seem the framebuffer (/dev/fb1) not connect to HDMI
Thanks.
#the setting work
setenv lvds_and_hdmi 'video=mxcdi0fb:RGB24,1280x1024M@60 hdmi video=mxcdi1fb:RGB666,XGA di1_primary ldb=di1'
