drm error message at boot
1,845件の閲覧回数
acremonini
I'm developing a Yocto distro for a custom board, starting from the one for imx8mp_evk. I'm trying to remove errors during the boot but there's three messages about ldb I can't explain. Notice that my lvds display works fine despite the messages.
[    0.183364] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with 32e90000.lcd-controller
[    0.346205] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with phy-lvds
[    0.375242] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with lvds0_panel
After some debugging on on my board I've moved to the evk that has the same error.
[ 0.222956] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with 32e90000.lcd-controller
[ 0.403848] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with 1-004c
[ 0.467060] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with 1-004c
I'm working on imx-linux-scarthgap distro with manifest imx-6.6.23-2.0.0.xml. Before this revision I worked with a mickledore one and no ldb error messages were printed on serial console.
Can someone help me removing this issue?
3 返答(返信)
1,138件の閲覧回数
SanthoshRajavel
My Board 8MPLUSLPD4-EVK
1,188件の閲覧回数
SanthoshRajavel
Hi @Manuel_Salas ,
Iam also facing the same issue in Scarthgap.
[ 0.090951] platform panel-lvds: Fixed dependency cycle(s) with /ldb-display- controller/lvds-channel@0
[ 1.605694] panel-lvds panel-lvds: /panel-lvds: problems parsing panel-timing (-22)
[ 1.613391] panel-lvds: probe of panel-lvds failed with error -22
[ 1.630510] imx8mp-ldb ldb-display-controller: Failed to create device link ( 0x180) with 32e90000.lcd-controller
[ 2.659304] imx8mp-ldb ldb-display-controller: Failed to create device link ( 0x180) with phy-lvds
My dts file
// SPDX-License-Identifier: GPL-2.0+
* i.MX8M Plus EVK
* LVDS Panel: 800x480 @ 60Hz
* Kernel: Linux 6.6+
#include "imx8mp-evk.dts"
model = "NXP i.MX8M Plus EVK - LVDS 800x480";
compatible = "fsl,imx8mp-evk", "fsl,imx8mp";
panel_lvds: panel-lvds {
compatible = "panel-lvds";
status = "okay";
data-mapping = "vesa-24";
data-width = <24>;
display-timings {
native-mode = <&timing0>;
timing0: timing0 {
clock-frequency = <25005000>;
hactive = <800>;
hsync-len = <6>;
hback-porch = <14>;
hfront-porch = <44>;
vactive = <480>;
vsync-len = <1>;
vback-porch = <3>;
vfront-porch = <5>;
port {
panel_in: endpoint {
remote-endpoint = <&ldb_lvds_out>;
&ldb_phy {
status = "okay";
&ldb {
status = "okay";
port@0 {
reg = <0>;
ldb_lcdif_in: endpoint {
remote-endpoint = <&lcdif3_out>;
lvds-channel@0 {
status = "okay";
fsl,data-mapping = "vesa-24";
fsl,data-width = <24>;
port@1 {
reg = <1>;
ldb_lvds_out: endpoint {
remote-endpoint = <&panel_in>;
&lcdif3 {
status = "okay";
port {
lcdif3_out: endpoint {
remote-endpoint = <&ldb_lcdif_in>;
/* Disable HDMI controller ONLY */
&hdmi {
status = "disabled";
/* Disable MIPI + unused LCDIFs */
&mipi_dsi { status = "disabled"; };
&lcdif1 { status = "disabled"; };
&lcdif2 { status = "disabled"; };
can you help me to fix that . I also attach my display details . Could you address the issue
1,823件の閲覧回数
Manuel_Salas
Hello @acremonini
I hope you are doing very well.
That error code 0x180 just means “no device found” at the time the link was attempted. It's more of a timing thing than an actual bug.
Since your LVDS display is working fine, it means the drivers eventually did their job. These logs are new in recent kernels (like 6.6 from Scarthgap). Older versions like Mickledore didn’t log this as an issue, which is probably why you hadn’t seen it before.
You can share your device tree and we can check if there is any inconsistency that is displaying this log.
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-2094607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AEDRM%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2094607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81imx8mp_evk%20%E7%94%A8%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%A6%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%20Yocto%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E4%B8%AD%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81ldb%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%203%20%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81LVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%20%20%20%200.183364%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%2032e90000.lcd-controller%0A%5B%20%20%20%200.346205%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%20phy-lvds%0A%5B%20%20%20%200.375242%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%20lvds0_panel%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8B%20evk%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%200.222956%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%2032e90000.lcd-controller%0A%5B%200.403848%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%201-004c%0A%5B%200.467060%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%201-004c%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%20imx-6.6.23-2.0.0.xml%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20imx-linux-scarthgap%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%94%B9%E8%A8%82%E7%89%88%E3%81%AE%E5%89%8D%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%20mickledore%20%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%20ldb%20%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20drm%20error%20message%20at%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%E7%A7%81%E3%82%82%3CSPAN%3EScarthgap%E3%81%A7%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%5B%200.090951%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20panel-lvds%3A%20%2Fldb-display-%20controller%2Flvds-channel%400%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E5%BE%AA%E7%92%B0%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.605694%5D%20panel-lvds%20panel-lvds%3A%20%2Fpanel-lvds%3A%20panel-timing%20%E3%81%AE%E8%A7%A3%E6%9E%90%E4%B8%AD%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-22)%3CBR%20%2F%3E%20%5B%201.613391%5D%20panel-lvds%3A%20panel-lvds%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.630510%5D%20imx8mp-ldb%20ldb-display-controller%3A%2032e90000.lcd-controller%20%E3%81%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20(0x180)%20%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.659304%5D%20imx8mp-ldb%20ldb-display-controller%3A%20phy-lvds%20%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20(0x180)%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AEdts%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F%2F%20SPDX%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E8%AD%98%E5%88%A5%E5%AD%90%3A%20GPL-2.0%2B%3CBR%20%2F%3E%2F*%3CBR%20%2F%3E%20*%20i.MX8M%20Plus%20EVK%3CBR%20%2F%3E%20*%20LVDS%E3%83%91%E3%83%8D%E3%83%AB%3A%20800x480%20%40%2060Hz%3CBR%20%2F%3E%20*%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3A%20Linux%206.6%2B%3CBR%20%2F%3E%20*%2F%3C%2FP%3E%3CP%3E%23include%20%22imx8mp-evk.dts%22%3C%2FP%3E%3CP%3E%2F%20%7B%3CBR%20%2F%3E%E3%83%A2%E3%83%87%E3%83%AB%20%3D%20%22NXP%20i.MX8M%20Plus%20EVK%20-%20LVDS%20800x480%22%3B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Cimx8mp-evk%22%2C%20%22fsl%2Cimx8mp%22%3B%3C%2FP%3E%3CP%3Epanel_lvds%3A%20%E3%83%91%E3%83%8D%E3%83%ABlvds%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%83%91%E3%83%8D%E3%83%ABLVDS%22%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20%3D%20%22vesa-24%22%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%20%3D%20%26lt%3B24%26gt%3B%3B%3C%2FP%3E%3CP%3E%E8%A1%A8%E7%A4%BA%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%7B%3CBR%20%2F%3E%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20%26lt%3B%26amp%3Btiming0%26gt%3B%3B%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B00%3A%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B00%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B25005000%26gt%3B%3B%3C%2FP%3E%3CP%3Ehactive%20%3D%20%26lt%3B800%26gt%3B%3B%3CBR%20%2F%3E%20hsync-len%20%3D%20%26lt%3B6%26gt%3B%3B%3CBR%20%2F%3E%20hback-porch%20%3D%20%26lt%3B14%26gt%3B%3B%3CBR%20%2F%3E%20h%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%83%9D%E3%83%BC%E3%83%81%20%3D%20%26lt%3B44%26gt%3B%3B%3C%2FP%3E%3CP%3Ev%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%3D%20%26lt%3B480%26gt%3B%3B%3CBR%20%2F%3E%20vsync-len%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20vback-porch%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%20v%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%83%9D%E3%83%BC%E3%83%81%20%3D%20%26lt%3B5%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20%7B%3CBR%20%2F%3E%20panel_in%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bldb_lvds_out%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%26amp%3Bldb_phy%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%26amp%3Bldb%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%400%20%7B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20ldb_lcdif_in%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Blcdif3_out%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Elvds-%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%400%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20fsl%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20%3D%20%22vesa-24%22%3B%3CBR%20%2F%3E%20fsl%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%20%3D%20%26lt%3B24%26gt%3B%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%401%20%7B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20ldb_lvds_out%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bpanel_in%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%26amp%3Blcdif3%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20%7B%3CBR%20%2F%3E%20lcdif3_out%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bldb_lcdif_in%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%2F*%20HDMI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%20%26amp%3Bhdmi%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F*%20MIPI%20%2B%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%20LCDIF%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%20%26amp%3Bmipi_dsi%20%7B%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%20%7D%3B%3CBR%20%2F%3E%20%26amp%3Blcdif1%20%7B%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%20%7D%3B%3CBR%20%2F%3E%20%26amp%3Blcdif2%20%7B%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%7D%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%82%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374815iF680ADBA41920781%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Media%20(2).jpg%22%20alt%3D%22Media%20(2).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2094685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20drm%20error%20message%20at%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2094685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F56935%22%20target%3D%22_blank%22%3E%40acremonini%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%200x180%20%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%9F%E6%99%82%E7%82%B9%E3%81%A7%E3%80%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%8D%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%90%E3%82%B0%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%82%8A%E3%82%82%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ELVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E5%BD%B9%E5%89%B2%E3%82%92%E6%9E%9C%E3%81%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AF%E6%9C%80%E8%BF%91%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20(Scarthgap%20%E3%81%AE%206.6%20%E3%81%AA%E3%81%A9)%20%E3%81%A7%E6%96%B0%E3%81%97%E3%81%8F%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82Mickledore%20%E3%81%AA%E3%81%A9%E3%81%AE%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%83%AD%E3%82%B0%E3%81%AB%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AB%E4%B8%8D%E6%95%B4%E5%90%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20drm%20error%20message%20at%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%208MPLUSLPD4-EVK%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
