bsp : android_N7.1.1_1.0.0
board : i.MX6qp sabresd
reference document : Android_Frequently_Asked_Questions.pdf (8 How do I enter the Android recovery mode manually?)
"reboot recovery" command does not enter recovery in Android N7.1.1
but, it works in factory reset menu in settings.
and, one strange...
after doing the "reboot ..." command, output "Reset cause: POR" message in u-boot.
is "Reset cause: WDOG" true?
to my recollection, it seems that "Reset cause: WDOG" message in Android gingerbread.
ask for advice.
Hi, JayTu.
This problem occurred because did not set BCB.
It's solved.
Thanks!!
