Hi All,
In Freescale git, the branch "daisy 3.10.31-1.1.0"(meta-fsl-bsp-release) is not avilable. Is it possible to get the same branch?
P.Ashok
Ashok
You can use daisy branch and use PREFERRED_VERSION_linux-imx_mx6 = "3.10.31" in machine config file which should solve your issue.
Saurabh
Hi Saurabh,
We are not able clone the branch itself. The machine config file will create after sucessful coloning on the all required files.
I need the branch "daisy_3.10.53-1.1.2_patch" from git://git.freescale.com/imx. Now this branch was deleted
P.Ashok
Hi Ashok
Here is a list of branch available
remotes/origin/imx-3.10.17-1.0.0_ga
remotes/origin/imx-3.10.17-1.0.1_ga
remotes/origin/imx-3.10.17-1.0.2_ga
remotes/origin/imx-3.10.31-1.1.0_alpha
remotes/origin/imx-3.10.31-1.1.0_beta
remotes/origin/imx-3.10.53-1.1.0_ga
remotes/origin/imx-3.10.53-1.1.1_patch
remotes/origin/imx-3.10.53-1.1.2_patch
remotes/origin/imx-3.14.28-1.0.0_ga
remotes/origin/imx-3.14.28-1.0.1_patch
remotes/origin/imx-3.14.28-7D_alpha
remotes/origin/imx-3.14.38-6QP_beta
Saurabh
