custom board bring based on imx 8dx
1,091 次查看
pavith_mi_18_1
I was working on the custom board based on the imx 8dx. as per the documentation i have  configured DRAM Registered on the SCFW and generated the scfw-tcm.bin. now i need to verify whether the configuration works or not.  is there is were load the scfw binary directly to emmc(because custom board does not have the sd slot) and test it out.
1 回复
1,080 次查看
joanxie
pls refer to the chapter 4.5.13 How to build imx-boot image by using imx-mkimage of enclosed file
