I'm following the documentation on Yocto development specifically on setting-up-to-use-crops is there a possibility to use poky-container to build Yocto/Linux?
I'm having difficulty setting up a container properly and not having there needed packages...
pokyuser@27f6ff974afe:/workdir/imx-yocto-bsp$ exit
(base) PS C:\> docker run --rm -it -v myvolume:/workdir crops/poky --workdir=/workdir
pokyuser@06932ce45056:/workdir$ apt-get install curl
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
Hello erikraynolds,
From the error you have to root to get curl. From Yocto BSP is better to follow up the Yocto project user guide in you yocto documentation.
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
