creating yocto image on i.mx6q sabre lite board
sribinkr
hii,
   How to create yocto image(dora) on i.mx6q sabre lite board..I tried my .ext3 file not getting copied to sd card
pls give suggestions.
Labels (3)
saurabh206
Senior Contributor III
check following link.
You can use .sdcard image to prepare card for your board.
Freescale Yocto Project main page
Yocto Training - HOME
Saurabh
sribinkr
In the 3rd step(build) there are 2 .sdcard image.In that  which one I have to copy? Also the name of the .ext3 file specified not same as that obtained.Anyway all i have to copy is the .ext3 file and .sd card image right?t
saurabh206
You just need to use dd command.
sudo dd if=core-image-minimal.sdcard  of=/dev/sdb bs=1M && sync
Saurabh
