cpufreq-set not working
4,721 次查看
kishan_dudhatra
I am using imx8mm with Kirkstone (5.15.71). I am trying to set the CPU frequency but "/sys/devices/system/cpu/cpufreq" is empty. I also try to run cpufreq-info but getting below error:
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  no or unknown cpufreq driver is active on this CPU
analyzing CPU 1:
analyzing CPU 2:
analyzing CPU 3:
Can you please suggest how to set CPU frequency from userspace?
Kishan Dudhatra
标记 (1)
5 回复数
3,827 次查看
pfiorini
@ nxp team
Same problem. Any Suggestion?
Regards.
Paolo Fiorini.
4,003 次查看
himanshu_bhavani
Hi @kishan_dudhatra,
One of my colleague is able to resolve the issue.
This is a workaround patch, Please check this patch at your end.
This patch will resolve your issue!
Thanks & Regards,
Himanshu Bhavani
BSP Engineer at Silicon Signals Pvt Ltd | https://siliconsignals.io/
4,665 次查看
Manuel_Salas
Hello @kishan_dudhatra!
Please refer to the attached document in the section 2.5.3 CPU Frequency Scaling (CPUFREQ), there is explained how to change the CPU frequency in user space.
I hope this can help to you.
Best regards.
4,602 次查看
kishan_dudhatra
I refer to the documents but cpufreq is not available.
ls: cannot access '/sys/devices/system/cpu/cpu0/cpufreq': No such file or directory
My goal is to set the CPU frequency from userspace in Kirkstone and it's already worked in Zeus. I also try to enable it from driver side but did not succeed.
Can you please provide more information to enable the control to set the CPU frequency from userspace?
Kishan Dudhatra
标记 (1)
4,674 次查看
kishan_dudhatra
@ nxp team,
Could you please reply?
Kishan Dudhatra
