Hello.
I'm on a dual core imx6 using a modified version of the imx6.cfg, with the second cpu added. Further I'm using openocd-0.9 from debian/unstable), JTAG is flyswatter2 and I'm trying to debug the Linux kernel. The problem is, that after hitting a break point I'm unable to resume the target properly, it stops in the same breakpoint again, even after removing the breakpoint. Franis Sirkovic
Hi Franis
please check helpful link
Programming Guide: OpenOCD + Eclipse + Jtag debug on Uboot & Linux
Hi Igor.
Thanks for your reply. I saw this guide and initially discarded it (it seems to complicated). I thought my problem should be some configuration problem or some easy fix. I will try to follow this guide.
Did you use this guide?
Best wishes, Franis Sirkovic.
