hi,
how can i copy the boot.scr file from tmp/deploy/images/imx6qsabresd/boot.scr into my sdcard image ?
I tried it with IMAGE_BOOT_FILES = "boot.scr" but nothing happens ? Also there is no /temp output where i can debug that ?
How do i copy a file to my sdcard image ?
Hello Florian Koenig,
I haven’t use that method, but I would recommend doing a clean an baking again, as if your image is already baked it’s very likely that it won’t rebuild because of this change, as Yocto is not good at keeping track of changes in the code, because it’s focused on distribution and customization rather than development.
If you would like to place a certain file on your image you may find the following document useful:
https://community.nxp.com/docs/DOC-105374
It’s possible that the problem in this case the problem is that you’re defining IMAGE_BOOT_FILES but you are not giving an instruction to add this to the image.
There may be other ways of achieving this, but this is one.
I hope this helps!
