console not working in imx6 SABRE Lite rev2 board
ashokp
Hi All,
I am using sabre lite rev2 board with ubuntu prebilt image. I have connected the console connector to the system com port via cross cable (RX and TX cross over). I tested with 19200 and 9600 buad rate. When i reboot the board i am not seeing any console logs.
P.Ashok
pranavmadhu
Hi Ashok,
Try by giving baudrate 115200 on bootargs, also make sure you are using the same baudrate on your pc application (minicom, teraterm etc)
