I am trying to build package xserver-xorg-video-imx-3 individually using LTIB.
But, it fails on some package requirements on my Ubuntu host.
The messge I get is something like this:
checking for XORG... configure: error: Package requirements (xorg-server >= 1.0.99.901 xproto fontsproto ) were not met:
Package pciaccess was not found in the pkg-config search path.
Perhaps you should add the directory containing `pciaccess.pc'
to the PKG_CONFIG_PATH environment variable
Package 'pciaccess', required by 'xorg-server', not found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables XORG_CFLAGS
and XORG_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I tried to find the packages xorg-server,xproto and fontsproto on Ubuntu repository and also at other places.
But, I couldn't find them anywhere.
Can you let me know how I can get the packages.
Prathamesh Ghanekar
Hi prathamesh,
"xserver-xorg-video-imx" is i.MX accelerated video driver for X.org.
Have you chose "gpu-viv-bin-mx6q"in package list when you build with LTIB?
Best Regards
Dan
