cmake error: yocto(dora) + meta-qt5(dizzy) on imx6
781 次查看
luiscamacho
I'm trying to build an image for the SabreLite board, I cloned yocto-dora and meta-qt5 (dizzy).  At compile (bitbake), I'm getting the following error: ..../cmake-native_2.8.11.2.bb, do_configure) failed with exit code '1'
So far, I gathered that the file Qt5CoreConfigExtras.cmake may not have the right path for the qt5 binaries.  So, I input:
..../fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/qt5
It still produces the same error.  Can anyone please advise on how to fix this cmake error?
Thank you!
标签 (2)
0 回复数
