Hi Bio_TICFSL,
Thanks for your reply, I haven't created any dts file for my own display because I thought multiple display was set to default in the build. In the android user guide it says only to connect the two displays with sas cable to LVDS 0 and 1.
1.Do we need to create our own dts file for my display, if yes, then do you have any example dts file to take reference? .
2.what command should I give in the uboot console for getting multiple displays?
3.Is there any other modification needed?
(btw I am not using demo images. I have build the source in my system and then flashing)
