Hi experts:
I found that the chromium could not play video on network on platfrom imx93evk,
yocto: LF 6.1.55. No log print out, just show "network could not connect" on wed.
Does any knows why ?
Best Regards
已解决! 转到解答。
HI Bio_TICFS:
Thanks .
I't's not the problem of ethernet, but the problem of no hardware decoder in imx93.
I have fixed the problem, it need to add config to chromium to build h264 software decoder.
在原帖中查看解决方案
Try the latest BSP, chromium has some bugs in the version you are playing.
Hi Bio_TICFSL:
I have upgraded to LF.6.6.36, but the issue still remain.
Any suggestion ?
Please send us the log file, is this your custom board or is EVK? I have the MX93EVK and everything works well on ethernet.
