chromium could not play video on network on imx93evk
1,311 次查看
jiangyaqiang
Contributor V
Hi experts:
  I found that the chromium could not play video on network on platfrom imx93evk,
yocto: LF 6.1.55.  No log print out,  just show "network could not connect" on wed.
 Does any knows why ?
 Best Regards
标签 (3)
标记 (1)
1,213 次查看
jiangyaqiang
Contributor V
HI Bio_TICFS:
Thanks .
I't's not the problem of ethernet, but the problem of no hardware decoder in imx93.
I have fixed the problem,  it need to add config to chromium to build h264 software decoder.
Best Regards
4 回复数
1,296 次查看
Bio_TICFSL
Try the latest BSP, chromium has some bugs in the version you are playing.
1,237 次查看
jiangyaqiang
Contributor V
Hi Bio_TICFSL:
I have upgraded  to LF.6.6.36, but the issue still remain.
Any suggestion ?
1,217 次查看
Bio_TICFSL
Please send us the log file, is this your custom board or is EVK? I have the MX93EVK and everything works well on ethernet.
1,214 次查看
jiangyaqiang
Contributor V
HI Bio_TICFS:
Thanks .
Best Regards
