chimei LCD can't work.
6,095件の閲覧回数
jackliu
Hi, Mr. / Ms.
   Lcd can't work , i upload the LCD spec , can't you tell me what should be change .
   we use imx6dl project .
Thanks.
ラベル(2)
10 返答(返信)
5,790件の閲覧回数
jackliu
BSP i.MX 6 (DL).  and there is no log about this part
5,790件の閲覧回数
jimmychan
There are different BSP for i.MX6. Please see this web page.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6_SW
Please let me know which BSP are you using and please tell me how the LCD not work.
5,790件の閲覧回数
jackliu
We are use i.MX6DL: i.MX 6DualLite Proces   and there is no valid kernel log in this part .
By the way , we are use 4 line data
******************** boot parmeter
console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.serialno=0a2049d4df644f5a
5,790件の閲覧回数
jimmychan
Attached is a porting guide. Please see the Chapter 6 for the LVDS porting.
5,790件の閲覧回数
jackliu
Hi, jimmy:
   can you help us to change the parameter cause this is first time to use this platform.
Thanks.
5,790件の閲覧回数
saurabh206
Senior Contributor III
Jack
Have you tried to set up ldb_data.transfer_mode = LDB_BIT_MAP_CH0_SPWG | LDB_BIT_MAP_CH1_SPWG;
Saurabh
5,790件の閲覧回数
jackliu
hi, Patel:
   I can't find ldb_data.transfer_mode in our code , can you let me know which file i can change it . now our driver use ldb.c
   Only place i can find set LDB_BIT_MAP_CH0_SPWG | LDB_BIT_MAP_CH1_SPWG is in ldb.c . the code is :
  /* TODO: now only use SPWG data mapping for both channel */
  reg &= ~(LDB_BIT_MAP_CH0_MASK | LDB_BIT_MAP_CH1_MASK);
  reg |= LDB_BIT_MAP_CH0_SPWG | LDB_BIT_MAP_CH1_SPWG;
Thanks.
5,789件の閲覧回数
saurabh206
Jack
You can set
or
reg |= LDB_BIT_MAP_CH0_JEIDA | LDB_BIT_MAP_CH1_JEIDA;
According to your panel.
5,789件の閲覧回数
saurabh206
#define LDB_BIT_MAP_CH1_JEIDA 0x00000100
#define LDB_BIT_MAP_CH0_JEIDA 0x00000040
5,789件の閲覧回数
jimmychan
Which BSP are you using? Any log message show how it cannot work?
