Hello,Haifeng,
**In chinese:
OBDS是用来进行底层硬件测试的,既然没有了error,那么花点时间做做修改,对硬件经进行一次完整的测试时必要的。运行OBDS,不会对eFUSE进行误烧写。
**In English,
OBDS is used to test hardware by low level software, It is valueable to do customized modification for your board. efuse can not be burned by mistake when you run OBDS.
Weidong
Hello,Haifeng,
如果遇到问题,暂时放下cfimager,使用MFG Tool 烧写你的images 进MicroSD 卡。MFG Tool是我们提供的量产工具,你早晚都要用到它。从网站下载下来,解压到你的电脑上,把板子的USB OTG 通过USB线接到你的PC USB上,运行MFG tool烧写image.
(English:
if you meet issue on cfimage, in oder to burn your images quickly, using MFG Tool , this is a mass-product tools provided by freescale. you can download it from official website , decompress it to your PC, connect USB OTG on board to PC USB , then run MFG Tool to begin to burn images)
weidong
Hello,Weidong,
我之前使用是OBDS里自带的cfimager,会出现上述错误提示。我重新下载了CFImager.v1.7.3.001_bin_2bsrc,使用
cfimager -raw -offset 0x400 -skip 0x400 -f u-boot.bin -d <card reader drive letter without colon>下载就可以了。
你说的对,其实可以直接下载images来测试。
那我还要不要再花些时间修改OBDS来测试我的定制版?运行OBDS会不会blow the fuses?
Reagrds,
Haifeng
Hello,Haifeng,
**In chinese:
**In English,
Weidong
