can the mipi screen support tslib and QT interfaces?
ximenbingmeng
We are debugging dual-screen differential display.
1. Can the mipi screen display the QT interface? Where can we find reference examples?
2. If we transplant the touch screen TP driver, can the mipi screen display tslib for drawing points and lines?
3. If we want to use other versions of kernel and uboot, how do we set up the environment and transplant it to our board?
Looking forward to your reply, thank you very much!
Bio_TICFSL
A1. Yes it can, please check the qt-validation image from yocto.
A2. Current BSP need a driver for so this task, but in general yes.
A3. We suggest to work with kernel and uboot for the NXP images otherwise there are no support on it.
