can't read/write data from/to 4-bit eMMC (USDHC4)
6,337件の閲覧回数
kruglikov_dmt
Hello. I've connected eMMC memory to pins USDHC4 (4-bit data) of i.mx6 solo.
I can read information about device, but I/O operations has been excepted.
U-Boot > mmc dev 2
MMC: mmc_getcd(mmc) = 1
MMC: mmc_send_cmd
                CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
                MMC: mmc_send_cmd result=0
MMC: mmc_send_cmd
                CMD_SEND:8
                ARG                      0x000001AA
                MMC_RSP_R1,5,6,7         0x2FF67610
                MMC: mmc_send_cmd result=-19
MMC: mmc_send_cmd
                CMD_SEND:55
                ARG                      0x00000000
MMC: mmc_send_cmd
                CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
MMC: mmc_send_cmd
                CMD_SEND:1
                ARG                      0x00000000
                MMC_RSP_R3,4             0x00FF8080
MMC: mmc_send_cmd
                CMD_SEND:1
                ARG                      0x40300000
MMC: mmc_send_cmd
                CMD_SEND:1
                ARG                      0x40300000
MMC: mmc_send_cmd
                CMD_SEND:1
                ARG                      0x40300000
                MMC_RSP_R3,4             0xC0FF8080
MMC: mmc_send_cmd
                CMD_SEND:2
                ARG                      0x00000000
                MMC_RSP_R2               0x9D010149
                                         0x53303332
                                         0x475011C3
                                         0xA0D31500
                                        DUMPING DATA
                                        000 - 9D 01 01 49
                                        004 - 53 30 33 32
                                        008 - 47 50 11 C3
                                        012 - A0 D3 15 00
MMC: mmc_send_cmd
                CMD_SEND:3
                ARG                      0x00010000
                MMC_RSP_R1,5,6,7         0x00000500
MMC: mmc_send_cmd
                CMD_SEND:9
                ARG                      0x00010000
                MMC_RSP_R2               0xD04F0132
                                         0x0F5903FF
                                         0xFFFFFFEF
                                         0x8A400000
                                        DUMPING DATA
                                        000 - D0 4F 01 32
                                        004 - 0F 59 03 FF
                                        008 - FF FF
U-Boot > mmc part
## Unknown partition table
U-Boot > mmc write 1000 0 1
MMC write: dev # 2, block # 0, count 1 ... MMC: mmc_set_blocklen = 512
MMC: mmc_send_cmd
                CMD_SEND:16
                ARG                      0x00000200
                MMC_RSP_R1,5,6,7         0x00000001
0 blocks written: ERROR
FF EF
                                        012 - 8A 40 00 00
MMC: mmc_send_cmd
                CMD_SEND:13
                ARG                      0x00010000
                MMC_RSP_R1,5,6,7         0x00000700
CURR STATE:3
MMC: mmc_send_cmd
                CMD_SEND:7
                ARG                      0x00010000
MMC: mmc_send_cmd
                CMD_SEND:8
                ARG                      0x00000000
                MMC_RSP_R1,5,6,7         0x00000900
MMC: mmc_send_cmd
                CMD_SEND:8
                ARG                      0x00000000
MMC: mmc_send_cmd
                CMD_SEND:6
                ARG                      0x03B90100
                MMC_RSP_R1b              0x00000800
MMC: mmc_send_cmd
                CMD_SEND:13
                ARG                      0x00010000
CURR STATE:4
MMC: mmc_send_cmd
                CMD_SEND:8
                ARG                      0x00000000
MMC: mmc_send_cmd
                CMD_SEND:6
                ARG                      0x03B70200
MMC: mmc_send_cmd
                CMD_SEND:13
                ARG                      0x00010000
CURR STATE:4
MMC: mmc_send_cmd
                CMD_SEND:8
                ARG                      0x00000000
MMC: mmc_send_cmd
                CMD_SEND:6
                ARG                      0x03B70100
MMC: mmc_send_cmd
                CMD_SEND:13
                ARG                      0x00010000
CURR STATE:4
MMC: mmc_send_cmd
                CMD_SEND:8
                ARG                      0x00000000
MMC: mmc_bread
MMC: mmc_send_cmd
                CMD_SEND:16
                ARG                      0x00000200
                MMC_RSP_R1,5,6,7         0xBEFB25EF
MMC: mmc_set_blocklen = -19
 U-Boot > mmcinfo
Device: FSL_SDHC
Manufacturer ID: 9d
OEM: 101
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 29.1 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 29.1 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
U-Boot > mmc part
MMC: mmc_send_cmd
                CMD_SEND:16
                ARG                      0x00000200
What I'm doing wrong?
Thanks!
ラベル(2)
タグ(2)
9 返答(返信)
5,356件の閲覧回数
BiyongSUN
If it is customized board, have you changed the index according to the customized hardware design.
how is mmc list output?
MMC: mmc_send_cmd
                CMD_SEND:16
                ARG                      0x00000200
The following index is for i.MX6 reference board hardware design and port mapping.
int board_mmc_init(bd_t *bis)
#ifndef CONFIG_SPL_BUILD
	int ret;
	int i;
	 * According to the board_mmc_init() the following map is done:
	 * (U-Boot device node)    (Physical Port)
	 * mmc0                    SD2
	 * mmc1                    SD3
	 * mmc2                    eMMC
	for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) {
		switch (i) {
		case 0:
			imx_iomux_v3_setup_multiple_pads(
				usdhc2_pads, ARRAY_SIZE(usdhc2_pads));
			gpio_direction_input(USDHC2_CD_GPIO);
			usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK);
			break;
		case 1:
				usdhc3_pads, ARRAY_SIZE(usdhc3_pads));
			gpio_direction_input(USDHC3_CD_GPIO);
			usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK);
			break;
		case 2:
				usdhc4_pads, ARRAY_SIZE(usdhc4_pads));
			usdhc_cfg[2].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK);
			break;
		default:
			printf("Warning: you configured more USDHC controllers"
			       "(%d) then supported by the board (%d)\n",
			       i + 1, CONFIG_SYS_FSL_USDHC_NUM);
			return -EINVAL;
I have above question, because the log shows the interface connect to sdcard, has cd.
but the mmcinfo shows connect to emmc.
BTW, emmc has no wp, no cd.
U-Boot > mmc dev 2
MMC: mmc_send_cmd
5,360件の閲覧回数
kevibruy
Harris Teeter has made a specialist login entrance where dynamic accomplices can get to their business related records. The entry means to decrease the administrative obligation and beat any issues among laborers and HR. Also, a lot of online organizations are available for the delegates to get to and make due.
The Harris Teeter specialist login entrance was once known as the MyhtSpace login doorway. After a few changes, the passage is by and by directed by Benefit Solver. So the door will be known as the Harris Teeter Benefit Solver login passage. This article will give your information about delegate selection and login processes.
6,112件の閲覧回数
crawfords
There have been many different papers and presentations on auditing hardware in the past, and several of them went into the topic of acquiring the code from the target. One such example comes from Micah Elizabeth Scott. On her blog, Micah discussed how she went about reverse engineering an eMMC flash pinout upsers
6,112件の閲覧回数
kruglikov_dmt
Hello.
This eMMC has a public datasheet and pinout.
So, there is no need on reverse engineering.
6,112件の閲覧回数
jimmychan
what is the status of the WP pin?
6,112件の閲覧回数
kruglikov_dmt
It's shorted to GND.
However, WP just forbids data write, but reading should work.
error -19 is command timeout.
I've checked CMD and DATA channels by osciloscope, I'm seeing normal voltage levels (1V8), host and eMMC have transferred some requests and responces to each other.
CLK has signal 386.7kHz
6,112件の閲覧回数
jimmychan
Could you tell me which BSP are you using?
Could you send me the device tree file of your board?
6,112件の閲覧回数
jimmychan
The u-boot version seem quite old.
You may try to use the BSP from NXP.
i.MX Software and Development Tools | NXP
for example : Linux L4.14.98_2.0.0 Documentation
