Table 37-2 of IMX6DQRM demostrates the formats the camera port support. Where I can find the timing diagrams of this format? I planed to configure the camera port as parallel interface style. There is a FPGA chip connect to i.mx6 qurd chip externally so that the timing diagrams is critical for FPGA to generate the video stream that i.mx6 can receive.
已解决! 转到解答。
Hi Jie
timings can be found in sect.4.12.10.2 Sensor Interface Timings i.MX6DQ Datasheet
http://www.nxp.com/docs/en/data-sheet/IMX6DQCEC.pdf
Hi Jie
