board has been restarted
10,370件の閲覧回数
秀超田
board has been restarted,Here is a serial port to print information:
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 189
Temperature:   30 C, calibration data 0x5aa5285f
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61012 [POR ]
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
*** Warning - bad CRC or MMC, using default environment
In:    serial
Out:   serial
Err:   serial
i2c: I2C3 SDA is low, start i2c recovery...
I2C3 Recovery failed, I2C1 SDA still low!!!
Found PFUZE100! deviceid=10,revid=21
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot:  0
kernel   @ 10808000 (4718568)
ramdisk  @ 11800000 (233818)
kernel cmdline:
        use boot.img command line:
        console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 3.0.35-06072-ge1c0848 (b18293@madspeed) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Oct 29 02:24:48 CST 2013
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6DL/SOLO, silicon rev 1.2
PERCPU: Embedded 7 pages/cpu @c12f9000 s6592 r8192 d13888 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 208128
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 379MB 378MB 64MB = 821MB total
Memory: 820584k/820584k available, 227992k reserved, 441344K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
    vmalloc : 0xd9800000 - 0xf2000000   ( 392 MB)
    lowmem  : 0xc0000000 - 0xd9000000   ( 400 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0046000   ( 248 kB)
      .text : 0xc0046000 - 0xc08cfd60   (8744 kB)
      .data : 0xc08d0000 - 0xc0967e00   ( 608 kB)
       .bss : 0xc0967e24 - 0xc0aefb68   (1568 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
Set periph_clk's parent to pll2_pfd_400M!
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3162.11 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
ram_console: got buffer at 3ff00000, size 100000
ram_console: uncorrectable error in header
ram_console: no valid data in buffer (sig = 0xd800bca2)
console [ram-1] enabled
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32050000, Cache size: 524288 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: SPKVDD: 4200 mV
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mc_pfuze 1-0008: ID: 0,Full lay: 2 ,Metal lay: 1
mc_pfuze 1-0008: FAB: 0 ,FIN: 0
print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
print_constraints: PFUZE100_VREFDDR: at 750 mV
print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2800 mV
print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 3000 mV
print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
max17135_regulator_init abort: EPDC not enabled
max17135 2-0048: PMIC MAX17135 for eInk display
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Unpacking initramfs...
Freeing initrd memory: 228K
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = d9820000 suspend_iram_base=d98bc000
PM driver module loaded
iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
PCIE: imx_pcie_pltfm_probe start link up.
link up failed, DB_R0:0x00133900, DB_R1:0x08200000!
IMX PCIe port: link down with power supply 1!
IMX usb wakeup probe
the wakeup pdata is 0xd45f6ba0
add wake up source irq 75
the wakeup pdata is 0xd45f6960
cpu regulator mode:ldo_bypass
_regulator_get: get() with no identifier
mx6_cpu_regulator_init: failed to get pu regulator
i.MXC CPU frequency driver
highmem bounce pool size: 64 pages
ashmem: initialized
NTFS driver 2.1.30 [Flags: R/O].
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 741
NET: Registered protocol family 38
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled, bootconsole disabled
loop: module loaded
m25p80 spi0.0: unrecognized JEDEC id ffffff
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for Qualcomm USB modem
usbcore: registered new interface driver qcserial
ARC USBOTG Device Controller driver (1 August 2005)
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
Gadget Android: controller 'fsl-usb2-udc' not recognized
android_usb gadget: android_usb ready
Suspend udc for OTG auto detect
USB Host suspend begins
will suspend roothub and its children
ehci_fsl_bus_suspend begins, DR
ehci_fsl_bus_suspend ends, DR
host suspend ends
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
dr_controller_run: udc out low power mode
USB Gadget resume ends
fsl-usb2-udc: bind to driver android_usb
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: max11801_ts as /devices/platform/imx-i2c.1/i2c-1/1-0048/input/input1
egalax_ts 1-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
usb 2-1: new high speed USB device number 2 using fsl-ehci
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
elan - Read Hello Packet Failed
elan-touch: probe of 2-0010 failed with error -22
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
camera ov5640_mipi is not found
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
FIFO_RD_AUX_MSB read fails
FIFO_RD_AUX_LSB read fails
mag3110 2-000e: check mag3110 chip ID
mag3110 2-000e: read chip ID 0xffffff92 is not equal to 0xc4!
mag3110: probe of 2-000e failed with error -22
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
input: FreescaleAccelerometer as /devices/virtual/input/input2
mma8x5x device driver probe successfully
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.6622
revserved_memory_account:viv_gpu registerd
Thermal calibration data is 0x5aa5285f
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
Registered led device: chg_now_led
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM08G 7.28 GiB
imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk0: p4 size 13090816 extends beyond EOD, truncated
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
wm8962 0-001a: customer id 0 revision D
input: WM8962 Beep Generator as /devices/platform/imx-i2c.0/i2c-0/0-001a/input/input3
asoc: wm8962 <-> imx-ssi.1 mapping ok
input: wm8962-audio DMIC as /devices/platform/soc-audio.5/sound/card0/input4
input: wm8962-audio Headphone Jack as /devices/platform/soc-audio.5/sound/card0/input5
imx_3stack asoc driver
Initialize HDMI-audio failed. Load HDMI-video first!
ALSA device list:
  #0: wm8962-audio
oprofile: using arm/armv7-ca9
GACT probability NOT on
Mirror/redirect action on
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (12825 buckets, 51300 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
IPv4 over IPv4 tunneling driver
GRE over IPv4 demultiplexor driver
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
NET: Registered protocol family 10
Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
L2TP IP encapsulation support (L2TPv3)
L2TP netlink interface
L2TP ethernet pseudowire support (L2TPv3)
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
lib80211_crypt: registered algorithm 'WEP'
lib80211_crypt: registered algorithm 'CCMP'
lib80211_crypt: registered algorithm 'TKIP'
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1)
Freeing init memory: 248K
init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
android_usb: already disabled
mtp_bind_config
root@sabresd_6dq:/ # imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
ERROR: v4l2 capture: slave not found!
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 17845762338 (1970-01-02 00:00:06.172161334 UTC)
cpufreq_interactive_input_connect: connect to max11801_ts
mma enable setting active
eth0: no PHY, assuming direct connection to switch
PHY 0:00 not found
eth0: could not attach to PHY
acc_open
acc_release
ehci_fsl_bus_resume begins, DR
binder: 2551:2566 transaction failed 29189, size 96-0
binder: release 2551:2551 transaction 2989 in, still active
binder: send failed reply for transaction 2989 to 2846:2885
binder: release 2551:2561 transaction 2893 in, still active
binder: send failed reply for transaction 2893 to 2668:2668
binder: release 2551:2562 transaction 3211 in, still active
binder: send failed reply for transaction 3211 to 2895:2895
binder: 2875:2875 transaction failed 29189, size 64-0
binder: 2668:2668 transaction failed 29189, size 208-0
binder: 2875:2875 transaction failed 29189, size 96-0
binder: 2668:2668 transaction failed 29189, size 4324-4
binder: 2875:2875 transaction failed 29189, size 5812-4
binder: 2886:2886 transaction failed 29189, size 1336-8
alarm_release: clear alarm, pending 0
request_suspend_state: wakeup (0->0) at 22510575006 (1970-01-02 00:00:10.836974335 UTC)
init: untracked pid 2274 exited
init: untracked pid 2279 exited
init: untracked pid 2748 exited
init: untracked pid 2686 exited
init: untracked pid 2846 exited
mma enable setting inactive
request_suspend_state: wakeup (0->0) at 30005351006 (1970-01-02 00:00:18.331750335 UTC)
kernel BUG at include/linux/netdevice.h:520!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = d5fdc000
[00000000] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP
Modules linked in:
CPU: 0    Not tainted  (3.0.35-06072-ge1c0848 #1)
PC is at __bug+0x1c/0x28
LR is at __bug+0x18/0x28
pc : [<c004ffec>]    lr : [<c004ffe8>]    psr: 600b0013
sp : d5f21df8  ip : 00000000  fp : 00000001
r10: d5f20000  r9 : d414cc20  r8 : 00000000
r7 : d45f2044  r6 : 00000000  r5 : c06a03e0  r4 : d45f2000
r3 : 00000000  r2 : c090413c  r1 : 600b0093  r0 : 00000033
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 25fdc04a  DAC: 00000015
PC: 0xc004ff6c:
ff6c  e1a04000 e24dd010 e590003c eb01caa4 e3500000 0594003c 0a00000d e2841034
ff8c  e594002c e891000e e88d000f ea000003 e59d000c eb01ca9a e3500000 0a000006
ffac  e1a0000d eb000eac e3500000 aafffff7 e3a00000 e28dd010 e8bd8010 e59d000c
ffcc  eafffffb e92d4008 e1a03000 e1a02001 e59f0010 e1a01003 eb183ed9 e3a03000
ffec  e5833000 eafffffe c07cfe18 e30f0e34 e30012e1 e92d4008 e34c007c ebfffff0
000c  e1a01000 e30f0e4c e92d4008 e34c007c eb183ecb e30f0e34 e30012c5 e34c007c
002c  ebffffe7 e92d4008 e1a02000 e1a03001 e30f0e6c e1a0100e e34c007c eb183ec0
004c  e30f0e34 e3001299 e34c007c ebffffdc e92d4ff0 e24dd06c e1a06002 e1a08000
LR: 0xc004ff68:
ff68  e92d4010 e1a04000 e24dd010 e590003c eb01caa4 e3500000 0594003c 0a00000d
ff88  e2841034 e594002c e891000e e88d000f ea000003 e59d000c eb01ca9a e3500000
ffa8  0a000006 e1a0000d eb000eac e3500000 aafffff7 e3a00000 e28dd010 e8bd8010
ffc8  e59d000c eafffffb e92d4008 e1a03000 e1a02001 e59f0010 e1a01003 eb183ed9
ffe8  e3a03000 e5833000 eafffffe c07cfe18 e30f0e34 e30012e1 e92d4008 e34c007c
0008  ebfffff0 e1a01000 e30f0e4c e92d4008 e34c007c eb183ecb e30f0e34 e30012c5
0028  e34c007c ebffffe7 e92d4008 e1a02000 e1a03001 e30f0e6c e1a0100e e34c007c
0048  eb183ec0 e30f0e34 e3001299 e34c007c ebffffdc e92d4ff0 e24dd06c e1a06002
SP: 0xd5f21d78:
1d78  00000002 c05a93a0 d5f812c0 00000001 00000000 c0940f70 600b0013 00000000
1d98  00000001 0000040f 00000005 00000000 d45f2044 c004c2d0 00000033 600b0093
1db8  c090413c 00000000 d45f2000 c06a03e0 00000000 d45f2044 00000000 d414cc20
1dd8  d5f20000 00000001 00000000 d5f21df8 c004ffe8 c004ffec 600b0013 ffffffff
1df8  00000000 c0361804 c0505978 ffffffee 00000000 00000000 d45f2000 0000000d
1e18  d5f20000 d5f20000 00000001 c00b2b04 d45f2000 c06a03e0 d45f2000 c06a03e0
1e38  00000000 d45f2044 00000000 d5f20000 d5f20000 c04ff20c c04ff16c d45f2000
1e58  00001003 00001002 00000001 c04ff434 00000000 d45f2000 00001002 40c57474
R2: 0xc09040bc:
40bc  00000018 00000019 0000001a 0000001b 0000001c 0000001d 0000001e 0000001f
40dc  c096aae8 00004000 00000001 c09040e8 c09040e8 00000000 00000000 000001f4
40fc  0000000a 00000000 00000000 00000000 0000000f 00000004 00000001 00000007
411c  00000000 00000000 00000001 c0904128 c0904128 00000000 00000000 00000000
413c  c090413c c090413c 00000004 ffffffff 00000000 ffffffff 00000000 c0090564
415c  c0952d7c 00000000 00000000 00000001 00000000 00000000 c0904174 c0904174
417c  00000000 00000000 00000001 00000000 00000000 c0904190 c0904190 00000000
419c  00000000 c07d956c c07d9570 c07d9578 c07d9580 c07d9588 c07d9590 c07d95a0
R4: 0xd45f1f80:
1f80  00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000
1fa0  00000000 00000000 00000000 00000000 00000000 d45f1fb4 d45f1fb4 ff24f2be
1fc0  f6dcb6f7 ed1eecf1 c00cfcfa bec969e7 fe1acefd 9d7b3ff6 feedf49f fea6af4d
1fe0  fe8ef83f 57bbfb57 f3f5ddce 4fde5bdf d69e9cf7 def44bb2 d2ecb5ad 9ba18bf4
2000  30687465 00000000 00000000 00000000 00000000 00000000 00000000 00000000
2020  00000000 00000000 00000000 d43a66c0 00000000 00000000 00000000 00000000
2040  00000000 00000007 d42f8848 d408d848 d45f2f3c d45f2f3c d45f2058 d45f2058
2060  00004000 40004800 00004800 00004020 00000002 00000002 00000000 00000000
R5: 0xc06a0360:
0360  00000000 00000000 00000000 c0360658 00000000 00000000 00000000 00000000
0380  00000000 00000000 00000000 00000000 00000000 00000000 00000000 c0360574
03a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
03c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
03e0  00000000 00000000 c036151c c0361488 c03611c8 00000000 00000000 00000000
0400  c03623c0 c0360798 c0513528 c0361164 00000000 c051350c 00000000 c03625c0
0420  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0440  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R7: 0xd45f1fc4:
1fc4  ed1eecf1 c00cfcfa bec969e7 fe1acefd 9d7b3ff6 feedf49f fea6af4d fe8ef83f
1fe4  57bbfb57 f3f5ddce 4fde5bdf d69e9cf7 def44bb2 d2ecb5ad 9ba18bf4 30687465
2004  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
2024  00000000 00000000 d43a66c0 00000000 00000000 00000000 00000000 00000000
2044  00000007 d42f8848 d408d848 d45f2f3c d45f2f3c d45f2058 d45f2058 00004000
2064  40004800 00004800 00004020 00000002 00000002 00000000 00000000 00000000
2084  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
20a4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R9: 0xd414cba0:
cba0  73627573 65747379 f7c6006d 9fbc76de 167ffffe becf5afd ffffba9f 9ffa3faf
cbc0  74656e65 e700302e fabf47ce b77bfcf6 fefffae2 ccbefde9 f6e9efff dedcc7ff
cbe0  74656e65 ef00302e f6cfcee9 8f7fcfff b6cb3698 6b5edd79 ac1cfeff 7ef5ffec
cc00  74656e65 fc00302e 17a7fffd e75fbe9a e7ffdf17 ff9b3afa 47943f37 5575f9b2
cc20  c006c8c0 00000000 00000005 2719ed1e 0000b31a ffffffff 9baf7cd2 d5fffbdf
cc40  ffffffff 00000000 f5bafd7c 0debff77 f9bbfcbe b7ff9613 c7f63e0e bc656bf1
cc60  3a393831 00393231 00000000 00000000 00000000 00000000 d43d0ba4 c00b3fe4
cc80  65776f70 b3af0072 fbeff967 ff937b9f a57fbcf3 f9f2afc7 b3735e57 f3dd3f59
R10: 0xd5f1ff80:
ff80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0000  00000000 00000002 00000000 d4294a00 c0904030 00000000 00000015 d4294a00
0020  c12fa320 d46b3be0 d5f20000 c00441b4 d5f4aa00 00000000 d5f21aa4 d5f219f0
0040  c0664254 00000000 00000000 00000000 00000000 00000000 01000000 00000000
0060  40c57f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Process netd (pid: 3138, stack limit = 0xd5f202f0)
Stack: (0xd5f21df8 to 0xd5f22000)
1de0:                                                       00000000 c0361804
1e00: c0505978 ffffffee 00000000 00000000 d45f2000 0000000d d5f20000 d5f20000
1e20: 00000001 c00b2b04 d45f2000 c06a03e0 d45f2000 c06a03e0 00000000 d45f2044
1e40: 00000000 d5f20000 d5f20000 c04ff20c c04ff16c d45f2000 00001003 00001002
1e60: 00000001 c04ff434 00000000 d45f2000 00001002 40c57474 00008914 c04ff558
1e80: 00000000 d434a20c 40c57474 c057dc80 00008913 c0500120 00000000 c0ae5460
1ea0: 00000014 d434a200 d45f2000 00000000 30687465 00000000 00000000 00000000
1ec0: 00001003 00000000 00000000 00000000 d5f21f08 00008914 40c57474 d407ebe0
1ee0: 0000001d c004ca84 d5f20000 00000000 40033c11 c04e9ddc d234f2e0 40c57474
1f00: d407ebe0 c013ff4c 40c57034 00000001 40033ace 00000010 40c57094 00000018
1f20: d5f21f54 00000003 d5f21f84 c08e6d88 d5f20000 c01321c0 00000000 d234f2c0
1f40: 0000001d d5f21f84 d5f21f88 00000003 40c5703c 00000000 00000003 d5f20000
1f60: d5a00800 d407ebe0 40c57474 00008914 0000001d c004ca84 d5f20000 00000000
1f80: 40033c11 c0140450 00000000 00000001 40033ace 4018b1f4 400fd004 00001003
1fa0: 00000036 c004c900 4018b1f4 400fd004 0000001d 00008914 40c57474 40c57468
1fc0: 4018b1f4 400fd004 00001003 00000036 00000006 00000008 41058668 40033c11
1fe0: 00001002 40c57458 4016bab7 4015b324 200b0010 0000001d 00000000 00000000
[<c004ffec>] (__bug+0x1c/0x28) from [<c0361804>] (fec_enet_open+0x2e8/0x330)
[<c0361804>] (fec_enet_open+0x2e8/0x330) from [<c04ff20c>] (__dev_open+0xa0/0xf0)
[<c04ff20c>] (__dev_open+0xa0/0xf0) from [<c04ff434>] (__dev_change_flags+0x7c/0x134)
[<c04ff434>] (__dev_change_flags+0x7c/0x134) from [<c04ff558>] (dev_change_flags+0x10/0x48)
[<c04ff558>] (dev_change_flags+0x10/0x48) from [<c057dc80>] (devinet_ioctl+0x7bc/0x86c)
[<c057dc80>] (devinet_ioctl+0x7bc/0x86c) from [<c04e9ddc>] (sock_ioctl+0x68/0x260)
[<c04e9ddc>] (sock_ioctl+0x68/0x260) from [<c013ff4c>] (do_vfs_ioctl+0x80/0x54c)
[<c013ff4c>] (do_vfs_ioctl+0x80/0x54c) from [<c0140450>] (sys_ioctl+0x38/0x5c)
[<c0140450>] (sys_ioctl+0x38/0x5c) from [<c004c900>] (ret_fast_syscall+0x0/0x30)
Code: e59f0010 e1a01003 eb183ed9 e3a03000 (e5833000)
---[ end trace 9188df7fe18c2b70 ]---
Kernel panic - not syncing: Fatal exception
[<c0053fc4>] (unwind_backtrace+0x0/0x138) from [<c065fa30>] (panic+0x74/0x194)
[<c065fa30>] (panic+0x74/0x194) from [<c0050454>] (die+0x218/0x284)
[<c0050454>] (die+0x218/0x284) from [<c065eeac>] (__do_kernel_fault.part.3+0x54/0x74)
[<c065eeac>] (__do_kernel_fault.part.3+0x54/0x74) from [<c0057d70>] (do_page_fault+0x2cc/0x334)
[<c0057d70>] (do_page_fault+0x2cc/0x334) from [<c0046410>] (do_DataAbort+0x34/0x9c)
[<c0046410>] (do_DataAbort+0x34/0x9c) from [<c004c2d0>] (__dabt_svc+0x70/0xa0)
Exception stack(0xd5f21db0 to 0xd5f21df8)
1da0:                                     00000033 600b0093 c090413c 00000000
1dc0: d45f2000 c06a03e0 00000000 d45f2044 00000000 d414cc20 d5f20000 00000001
1de0: 00000000 d5f21df8 c004ffe8 c004ffec 600b0013 ffffffff
[<c004c2d0>] (__dabt_svc+0x70/0xa0) from [<c004ffec>] (__bug+0x1c/0x28)
6,281件の閲覧回数
rickchu
No Ethernet on your device right? You can try to disable/remove Ethernet relative configuration in you kernel.
PHY 0:00 not found
Rick
15 返答(返信)
6,281件の閲覧回数
Rita_Wang
Hi 秀超,
Which board and BSP are you using?
Best Regards
Dan
6,281件の閲覧回数
秀超田
Hi,Dan
      The board  is designed by myself,and the platform is imx6dl.but DDR part layout no change according to the original factory.and BSP is android_jb4.3_1.0.0
6,281件の閲覧回数
Rita_Wang
Hi 秀超,
Which freescale board do you refer to? i.MX6DL-SDP?
Best Regards
6,281件の閲覧回数
saurabh206
Senior Contributor III
please refer android_jb4.3_1.1.0-ga_doc Android_User's_Guide.pdf. Page No 17.
U-Boot > setenv fastboot_dev mmc3 [eMMC as fastboot deivce]
U-Boot > setenv bootcmd booti mmc3 [Load the boot.img from eMMC]
U-Boot > setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32
androidboot.console=ttymxc0 androidboot.hardware=freescale #[Optional]
U-Boot > saveenv #[Save the environments]
6,281件の閲覧回数
秀超田
  MX6SDL SABRESD U-Boot > printenv bootargs
  bootargs=console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M      androidboot.console=ttymxc0 androidboot.hardware=freescale
But the board has been restart problems still exist!
6,282件の閲覧回数
rickchu
PHY 0:00 not found
Rick
6,281件の閲覧回数
秀超田
Thank you very much! Problem has been solved
6,281件の閲覧回数
mladenmiljus
I am Linux newbee and I would be very thankful if you could explain how to disable/remove Ethernet configuration in Kernel?
How did you solve your problem?
6,281件の閲覧回数
rickchu
on SABRESD board, you can mark "imx6_init_fec(fec_data);" in board-mx6q_sabresd.c for quick test.
6,281件の閲覧回数
秀超田
## Error: "bootargs" not defined
6,281件の閲覧回数
秀超田
Hi,Dan
  i.MX6DL-SDP
6,281件の閲覧回数
saurabh206
Can you run following command on u-boot promt?
printenv bootargs
6,281件の閲覧回数
秀超田
  The board boot from eMMC
6,281件の閲覧回数
saurabh206
Can you please share your bootargs and logcat detail?
6,281件の閲覧回数
秀超田
bootargs:
bootdelay=3
baudrate=115200
ipaddr=192.168.1.103
serverip=192.168.1.101
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
splashimage=0x30000000
splashpos=m,m
lvds_num=1
stdin=serial
stdout=serial
stderr=serial
fastboot_dev=mmc3
bootcmd=booti mmc3
ethact=FEC0
logcat detail:
--------- beginning of /dev/log/main
D/MagDaemon( 2276): init_sensors
D/MagDaemon( 2276): find sensor name FreescaleAccelerometer
D/MagDaemon( 2276): input device 'FreescaleAccelerometer' opened, fd = 8
I/installd( 2273): installd firing up
I/DEBUG   ( 2268): debuggerd: May 24 2014 19:40:01
--------- beginning of /dev/log/system
I/Vold    ( 2266): Vold 2.1 (the revenge) firing up
D/Vold    ( 2266): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
I/OrionSvc( 2281): Set command is setprop athr.gps.conf /system/etc/gps/Orion.ini
I/Netd    ( 2267): Netd 1.0 starting
W/InterfaceController( 2267): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/OrionSvc( 2281): using prop value
I/OrionSvc( 2281): Get key ANDROID_SOCKET_athrshmsocket on 11
I/OrionSvc( 2281): Enter control_ipc thread
I/SurfaceFlinger( 2269): SurfaceFlinger is starting
I/SurfaceFlinger( 2269): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL  ( 2269): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 2269): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/MagDaemon( 2276): couldn't find 'FreescaleMagnetometer' input device
D/libEGL  ( 2269): loaded /system/lib/egl/libGLESv2_VIVANTE.so
D/MagDaemon( 2276): inital sensor error
W/imx6.gralloc( 2269): 32bpp setting of Framebuffer catched!
W/imx6.gralloc( 2269): using (fd=15)
W/imx6.gralloc( 2269): id           = DISP3 BG - DI1
W/imx6.gralloc( 2269): xres         = 1024 px
W/imx6.gralloc( 2269): yres         = 768 px
W/imx6.gralloc( 2269): xres_virtual = 1024 px
W/imx6.gralloc( 2269): yres_virtual = 2304 px
W/imx6.gralloc( 2269): bpp          = 32
W/imx6.gralloc( 2269): r            =  0:8
W/imx6.gralloc( 2269): g            =  8:8
W/imx6.gralloc( 2269): b            = 16:8
W/imx6.gralloc( 2269): width        = 163 mm (159.568100 dpi)
W/imx6.gralloc( 2269): height       = 122 mm (159.895081 dpi)
W/imx6.gralloc( 2269): refresh rate = 60.00 Hz
I/FslHwcomposer( 2269): fb0 is ldb
I/FslHwcomposer( 2269):  device
I/FslHwcomposer( 2269): fb1 is overlay device
W/FslHwcomposer( 2269): open /sys/class/graphics/fb2 failed
W/FslHwcomposer( 2269): open /sys/class/graphics/fb3 failed
W/FslHwcomposer( 2269): open /sys/class/graphics/fb4 failed
W/FslHwcomposer( 2269): open /sys/class/graphics/fb5 failed
I/FslHwcomposer( 2269): hwcomposer: open framebuffer fb0
W/v_hwc   ( 2269): TODO: HWC integration: display!
I/v_hwc   ( 2269): Default primary display
I/v_hwc   ( 2269): xres         = 1024 px
I/v_hwc   ( 2269): yres         = 768 px
I/v_hwc   ( 2269): xdpi         = 159.6 dpi
I/v_hwc   ( 2269): ydpi         = 159.9 dpi
I/v_hwc   ( 2269): refresh rate = 60.0 Hz
E/v_hwc   ( 2269): open /dev/graphics/fb2 failed
I/v_hwc   ( 2269): Virtual display 0 initialized.
I/v_hwc   ( 2269): Vivante HWComposer v2.4
I/v_hwc   ( 2269): Device:               0x417cea20
I/v_hwc   ( 2269): Separated 2D:         YES
I/v_hwc   ( 2269): 2D PE20:              YES
I/v_hwc   ( 2269): Multi-source blit:    NO
I/v_hwc   ( 2269): Multi-source blit Ex: NO
I/v_hwc   ( 2269): OPF/YUV blit/Tiling : NO
I/v_hwc   ( 2269): Filter stretch      : YES
I/FslHwcomposer( 2269): hwc_device_open,375
I/SurfaceFlinger( 2269): Using composer version 1.1
W/SurfaceFlinger( 2269): no suitable EGLConfig found, trying without EGL_FRAMEBUFFER_TARGET_ANDROID
E/SurfaceFlinger( 2269): HWComposer: framebufferTarget is null
E/libEGL  ( 2269): eglSetSwapRectangleANDROID:1483 error 3008 (EGL_BAD_DISPLAY)
I/SurfaceFlinger( 2269): EGL informations:
I/SurfaceFlinger( 2269): vendor    : Android
I/SurfaceFlinger( 2269): version   : 1.4 Android META-EGL
I/SurfaceFlinger( 2269): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer
I/SurfaceFlinger( 2269): Client API: OpenGL_ES
I/SurfaceFlinger( 2269): EGLSurface: 8-8-8-8, config=0x40846d38
I/SurfaceFlinger( 2269): OpenGL ES informations:
I/SurfaceFlinger( 2269): vendor    : Vivante Corporation
I/SurfaceFlinger( 2269): renderer  : GC880 Graphics Engine
I/SurfaceFlinger( 2269): version   : OpenGL ES-CM 1.1
I/SurfaceFlinger( 2269): extensions: GL_EXT_debug_marker GL_OES_blend_equation_separate GL_OES_blend_func_separate GL_OES_blend_subtract GL_OES_byte_coordinates GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_extended_matrix_palette GL_OES_fixed_point GL_OES_framebuffer_object GL_OES_matrix_get GL_OES_matrix_palette GL_OES_point_size_array GL_OES_point_sprite GL_OES_query_matrix GL_OES_read_format GL_OES_single_precision GL_OES_stencil_wrap GL_OES_texture_cube_map GL_OES_texture_mirrored_repeat GL_OES_EGL_image GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_stencil1 GL_OES_stencil4 GL_OES_stencil8 GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_user_clip_plane GL_APPLE_texture_2D_limited_npot GL_EXT_texture_lod_bias GL_EXT_blend_minmax GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_OES_EGL_sync GL_APPLE_texture_format_BGRA8888 GL_APPLE_te
I/SurfaceFlinger( 2269): GL_MAX_TEXTURE_SIZE = 8192
I/SurfaceFlinger( 2269): GL_MAX_VIEWPORT_DIMS = 8192 x 8192
D/SurfaceFlinger( 2269): Screen acquired, type=0 flinger=0x417bc478
I/mediaserver( 2272): ServiceManager: 0x40be53f0
I/AudioFlinger( 2272): Using default 3000 mSec as standby time.
I/CameraService( 2272): CameraService started (pid=2272)
I/CameraService( 2272): Loaded "Freescale CameraHal Module" camera module
I/FslCameraHAL( 2272): Face Back Camera is ov5640_mipi, orient is 0
I/FslCameraHAL( 2272): Face Front Camera is uvc,ov5642_camera,ov5640_camera, orient is 0
I/FslCameraHAL( 2272): Checking the camera ov5640_mipi
I/FslCameraHAL( 2272): Checking the camera uvc
I/FslCameraHAL( 2272): Checking the camera ov5642_camera
I/FslCameraHAL( 2272): Checking the camera ov5640_camera
I/AudioPolicyManagerBase( 2272): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary( 2272): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary( 2272): out rate 44100
D/libEGL  ( 2379): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 2379): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
W/audio_hw_primary( 2272): in rate 44100, channels 1 format 0
I/AudioFlinger( 2272): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 2272): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary( 2272): opened out stream...1074038680
I/AudioFlinger( 2272): HAL output buffer size 192 frames, normal mix buffer size 768 frames
I/AudioMixer( 2272): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe( 2272): Failed to fetch local time frequency when constructing a MonoPipe (res = -32).  getNextWriteTimestamp calls will be non-functional
D/libEGL  ( 2379): loaded /system/lib/egl/libGLESv2_VIVANTE.so
E/BufferQueue( 2269): [BootAnimation] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
I/v_hwc   ( 2269): Display(0x4006a008) detected: format=306 1024x768
I/v_hwc   ( 2269): Display buffer(0x4014ffb8) detected: physical=0x18100000
D/AndroidRuntime( 2270):
D/AndroidRuntime( 2270): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 2270): CheckJNI is ON
I/AndroidRuntime( 2270): JNI options: '-Xjniopts:warnonly'
I/v_hwc   ( 2269): Display buffer(0x404f10f0) detected: physical=0x17b00000
I/v_hwc   ( 2269): Display buffer(0x404f1118) detected: physical=0x17e00000
D/dalvikvm( 2270): Trying to load lib libjavacore.so 0x0
D/dalvikvm( 2270): Added shared lib libjavacore.so 0x0
D/dalvikvm( 2270): Trying to load lib libnativehelper.so 0x0
D/dalvikvm( 2270): Added shared lib libnativehelper.so 0x0
W/dalvikvm( 2270): PR_SET_NO_NEW_PRIVS failed. Is your kernel compiled correctly?: Invalid argument
I/SamplingProfilerIntegration( 2270): Profiling disabled.
I/Zygote  ( 2270): Preloading classes...
D/dalvikvm( 2270): GC_EXPLICIT freed 37K, 9% free 436K/476K, paused 0ms+0ms, total 2ms
D/dalvikvm( 2270): GC_EXPLICIT freed 4K, 4% free 507K/528K, paused 0ms+0ms, total 3ms
D/dalvikvm( 2270): Note: class Landroid/app/ActivityManagerNative; has 163 unimplemented (abstract) methods
D/dalvikvm( 2270): GC_EXPLICIT freed 22K, 5% free 538K/564K, paused 0ms+1ms, total 5ms
D/dalvikvm( 2270): GC_EXPLICIT freed 13K, 3% free 598K/616K, paused 0ms+1ms, total 3ms
D/dalvikvm( 2270): GC_EXPLICIT freed 26K, 5% free 629K/660K, paused 1ms+0ms, total 3ms
D/dalvikvm( 2270): GC_EXPLICIT freed 28K, 5% free 656K/688K, paused 0ms+1ms, total 3ms
D/dalvikvm( 2270): GC_EXPLICIT freed 81K, 10% free 789K/876K, paused 0ms+0ms, total 3ms
D/dalvikvm( 2270): GC_EXPLICIT freed 28K, 7% free 816K/876K, paused 0ms+1ms, total 4ms
D/TextLayoutCache( 2270): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm( 2270): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI( 2270): register_android_mtp_MtpDevice
D/dalvikvm( 2270): GC_EXPLICIT freed 25K, 4% free 848K/876K, paused 0ms+0ms, total 4ms
D/dalvikvm( 2270): GC_EXPLICIT freed 26K, 4% free 886K/916K, paused 0ms+0ms, total 4ms
D/MDnsDS  ( 2267): MDnsSdListener::Hander starting up
D/MDnsDS  ( 2267): MDnsSdListener starting to monitor
D/MDnsDS  ( 2267): Going to poll with pollCount 1
D/dalvikvm( 2270): GC_FOR_ALLOC freed 218K, 16% free 1180K/1400K, paused 6ms, total 6ms
D/dalvikvm( 2270): GC_EXPLICIT freed 288K, 18% free 1378K/1672K, paused 1ms+1ms, total 9ms
D/dalvikvm( 2270): GC_EXPLICIT freed 26K, 16% free 1406K/1672K, paused 0ms+1ms, total 7ms
D/dalvikvm( 2270): GC_EXPLICIT freed 19K, 14% free 1447K/1672K, paused 1ms+1ms, total 8ms
D/dalvikvm( 2270): GC_EXPLICIT freed 16K, 12% free 1487K/1672K, paused 0ms+1ms, total 8ms
D/dalvikvm( 2270): GC_EXPLICIT freed 24K, 2% free 1792K/1820K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2270): GC_EXPLICIT freed 34K, 2% free 1827K/1864K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2270): GC_EXPLICIT freed 30K, 2% free 1851K/1884K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2270): GC_EXPLICIT freed 30K, 2% free 1877K/1912K, paused 0ms+1ms, total 11ms
I/dalvikvm( 2270): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
D/dalvikvm( 2270): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
D/dalvikvm( 2270): GC_EXPLICIT freed 20K, 2% free 1911K/1936K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 26K, 2% free 1938K/1968K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 27K, 2% free 1964K/1996K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2270): GC_EXPLICIT freed 29K, 2% free 1993K/2024K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2270): GC_EXPLICIT freed 31K, 2% free 2016K/2052K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 32K, 2% free 2039K/2076K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 27K, 2% free 2067K/2100K, paused 1ms+2ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 29K, 2% free 2094K/2128K, paused 1ms+1ms, total 14ms
D/dalvikvm( 2270): GC_EXPLICIT freed 38K, 2% free 2112K/2152K, paused 1ms+2ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 39K, 2% free 2128K/2172K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2270): GC_EXPLICIT freed 37K, 2% free 2146K/2188K, paused 1ms+2ms, total 14ms
I/System  ( 2270): Loaded time zone names for "" in 77ms (71ms in ICU)
I/System  ( 2270): Loaded time zone names for "en_US" in 58ms (51ms in ICU)
D/dalvikvm( 2270): GC_EXPLICIT freed 136K, 6% free 2235K/2376K, paused 1ms+2ms, total 15ms
D/dalvikvm( 2270): GC_EXPLICIT freed 14K, 4% free 2299K/2376K, paused 1ms+1ms, total 17ms
D/dalvikvm( 2270): GC_EXPLICIT freed 58K, 3% free 2336K/2400K, paused 2ms+1ms, total 16ms
D/dalvikvm( 2270): GC_EXPLICIT freed 29K, 2% free 2363K/2400K, paused 1ms+2ms, total 15ms
D/dalvikvm( 2270): GC_EXPLICIT freed 44K, 2% free 2372K/2420K, paused 1ms+2ms, total 16ms
D/dalvikvm( 2270): GC_EXPLICIT freed 29K, 2% free 2397K/2432K, paused 1ms+1ms, total 15ms
D/dalvikvm( 2270): GC_EXPLICIT freed 33K, 2% free 2418K/2456K, paused 1ms+1ms, total 16ms
I/Zygote  ( 2270): ...preloaded 2879 classes in 1873ms.
D/dalvikvm( 2270): WAIT_FOR_CONCURRENT_GC blocked 1ms
D/dalvikvm( 2270): GC_EXPLICIT freed 23K, 2% free 2434K/2460K, paused 1ms+2ms, total 17ms
I/Zygote  ( 2270): Preloading resources...
W/Resources( 2270): Preloaded drawable resource #0x1080606 (android:drawable/toast_frame_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080108 (android:drawable/btn_check_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080107 (android:drawable/btn_check_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080105 (android:drawable/btn_check_on_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080104 (android:drawable/btn_check_on_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080102 (android:drawable/btn_check_on_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 43K, 3% free 2444K/2500K, paused 2ms+2ms, total 18ms
W/Resources( 2270): Preloaded drawable resource #0x1080101 (android:drawable/btn_check_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080100 (android:drawable/btn_check_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800ff (android:drawable/btn_check_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800fe (android:drawable/btn_check_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800fd (android:drawable/btn_check_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800f5 (android:drawable/btn_check_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800f4 (android:drawable/btn_check_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800f0 (android:drawable/btn_check_off_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800ef (android:drawable/btn_check_off_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 50K, 3% free 2447K/2500K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10800ed (android:drawable/btn_check_off_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800ec (android:drawable/btn_check_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800eb (android:drawable/btn_check_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800ea (android:drawable/btn_check_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800e9 (android:drawable/btn_check_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800e8 (android:drawable/btn_check_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800df (android:drawable/btn_check_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 113K, 5% free 2452K/2572K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10800de (android:drawable/btn_check_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 84K, 5% free 2451K/2572K, paused 2ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x1080198 (android:drawable/btn_radio_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080197 (android:drawable/btn_radio_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080195 (android:drawable/btn_radio_on_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080194 (android:drawable/btn_radio_on_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080192 (android:drawable/btn_radio_on_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080191 (android:drawable/btn_radio_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080190 (android:drawable/btn_radio_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108018f (android:drawable/btn_radio_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108018e (android:drawable/btn_radio_on_disabled_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 52K, 5% free 2451K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x108018d (android:drawable/btn_radio_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108018a (android:drawable/btn_radio_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080189 (android:drawable/btn_radio_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080187 (android:drawable/btn_radio_off_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080186 (android:drawable/btn_radio_off_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080184 (android:drawable/btn_radio_off_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080183 (android:drawable/btn_radio_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080182 (android:drawable/btn_radio_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080181 (android:drawable/btn_radio_off_disabled_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 51K, 5% free 2452K/2572K, paused 1ms+2ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x1080180 (android:drawable/btn_radio_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108017f (android:drawable/btn_radio_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108012b (android:drawable/btn_default_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108012a (android:drawable/btn_default_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080127 (android:drawable/btn_default_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080126 (android:drawable/btn_default_normal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108011f (android:drawable/btn_default_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108011e (android:drawable/btn_default_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108011c (android:drawable/btn_default_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108011b (android:drawable/btn_default_disabled_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 52K, 5% free 2453K/2572K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x1080119 (android:drawable/btn_default_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080118 (android:drawable/btn_default_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080120 (android:drawable/btn_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080121 (android:drawable/btn_default_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 84K, 5% free 2455K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10801d4 (android:drawable/btn_star_off_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801de (andwarning: `zygote' uses 32-bit capabilities (legacy support in use)
roid:drawable/btn_star_on_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801da (android:drawable/btn_star_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d0 (android:drawable/btn_star_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801e0 (android:drawable/btn_star_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d6 (android:drawable/btn_star_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801dc (android:drawable/btn_star_on_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d2 (android:drawable/btn_star_off_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d8 (android:drawable/btn_star_on_disabled_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 51K, 5% free 2457K/2572K, paused 2ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10801ce (android:drawable/btn_star_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801de (android:drawable/btn_star_on_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801cb (android:drawable/btn_star_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 86K, 5% free 2460K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10801d3 (android:drawable/btn_star_off_normal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801dd (android:drawable/btn_star_on_normal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d9 (android:drawable/btn_star_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801cf (android:drawable/btn_star_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801df (android:drawable/btn_star_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d5 (android:drawable/btn_star_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801db (android:drawable/btn_star_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d1 (android:drawable/btn_star_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801d7 (android:drawable/btn_star_on_disabled_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 53K, 5% free 2459K/2572K, paused 2ms+1ms, total 18ms
W/Resources( 2270): Preloaded drawable resource #0x10801cd (android:drawable/btn_star_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801ca (android:drawable/btn_star_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 86K, 5% free 2461K/2572K, paused 1ms+2ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10801fa (android:drawable/btn_toggle_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f9 (android:drawable/btn_toggle_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f8 (android:drawable/btn_toggle_on_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f7 (android:drawable/btn_toggle_on_normal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f6 (android:drawable/btn_toggle_on_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f5 (android:drawable/btn_toggle_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f4 (android:drawable/btn_toggle_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f3 (android:drawable/btn_toggle_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f2 (android:drawable/btn_toggle_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801f1 (android:drawable/btn_toggle_on_disabled_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 54K, 5% free 2460K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10801ef (android:drawable/btn_toggle_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801ee (android:drawable/btn_toggle_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801ed (android:drawable/btn_toggle_off_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801ec (android:drawable/btn_toggle_off_normal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801eb (android:drawable/btn_toggle_off_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801ea (android:drawable/btn_toggle_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801e9 (android:drawable/btn_toggle_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801e8 (android:drawable/btn_toggle_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801e7 (android:drawable/btn_toggle_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10801e6 (android:drawable/btn_toggle_off_disabled_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 51K, 5% free 2462K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10801e4 (android:drawable/btn_toggle_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 73K, 5% free 2463K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10801e3 (android:drawable/btn_toggle_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 74K, 5% free 2463K/2572K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10805e6 (android:drawable/textfield_multiline_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805ea (android:drawable/textfield_multiline_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805e4 (android:drawable/textfield_multiline_activated_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805ec (android:drawable/textfield_multiline_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805e8 (android:drawable/textfield_multiline_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805d9 (android:drawable/textfield_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805de (android:drawable/textfield_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805d1 (android:drawable/textfield_activated_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805dc (android:drawable/textfield_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080256 (android:drawable/edit_text_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 69K, 5% free 2464K/2572K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10805e5 (android:drawable/textfield_multiline_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805e9 (android:drawable/textfield_multiline_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805e3 (android:drawable/textfield_multiline_activated_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805eb (android:drawable/textfield_multiline_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805e7 (android:drawable/textfield_multiline_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805d8 (android:drawable/textfield_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805dd (android:drawable/textfield_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805d0 (android:drawable/textfield_activated_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805e0 (android:drawable/textfield_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805db (android:drawable/textfield_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080255 (android:drawable/edit_text_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 73K, 5% free 2466K/2572K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10805cd (android:drawable/text_select_handle_left) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805cf (android:drawable/text_select_handle_right) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805ca (android:drawable/text_edit_paste_window) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108026b (android:drawable/expander_close_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108026c (android:drawable/expander_close_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080272 (android:drawable/expander_open_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108026e (android:drawable/expander_group_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 55K, 4% free 2469K/2572K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x1080273 (android:drawable/expander_open_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108026f (android:drawable/expander_group_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803ef (android:drawable/list_selector_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803d0 (android:drawable/list_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803cf (android:drawable/list_longpressed_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803ec (android:drawable/list_selector_background_transition_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803cb (android:drawable/list_focused_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803f3 (android:drawable/list_selector_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803f0 (android:drawable/list_selector_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803d1 (android:drawable/list_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803ed (android:drawable/list_selector_background_transition_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803f4 (android:drawable/list_selector_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 55K, 4% free 2474K/2572K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10803d3 (android:drawable/list_section_divider_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803d2 (android:drawable/list_section_divider_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080407 (android:drawable/menu_hardkey_panel_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080408 (android:drawable/menu_hardkey_panel_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108040f (android:drawable/menu_submenu_background) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080406 (android:drawable/menu_dropdown_panel_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080405 (android:drawable/menu_dropdown_panel_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 54K, 4% free 2471K/2572K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x108040c (android:drawable/menu_popup_panel_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108040b (android:drawable/menu_popup_panel_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108040a (android:drawable/menu_panel_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080409 (android:drawable/menu_panel_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 62K, 5% free 2473K/2596K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x1080439 (android:drawable/overscroll_edge) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108043a (android:drawable/overscroll_glow) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 304K, 14% free 2472K/2872K, paused 2ms+2ms, total 23ms
W/Resources( 2270): Preloaded drawable resource #0x10804f7 (android:drawable/spinner_16_outer_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804f6 (android:drawable/spinner_16_inner_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804fb (android:drawable/spinner_48_outer_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804fa (android:drawable/spinner_48_inner_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804fd (android:drawable/spinner_76_outer_holo) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 49K, 14% free 2473K/2872K, paused 1ms+2ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10804fc (android:drawable/spinner_76_inner_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108047d (android:drawable/progress_bg_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108047e (android:drawable/prorequest_suspend_state: wakeup (3->0) at 14790209004 (1970-01-02 00:00:02.401055000 UTC)
gress_bg_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawabFIFO_RD_AUX_MSB read fails
le resource #0x108048a (android:drawable/progress_secondary_holo_FIFO_RD_AUX_LSB read fails
W/Resources( 2270): Preloaded drawable resource #0x108048FIFO_RD_AUX_MSB read fails
8 (android:drawable/progress_primary_holo_dark) that varies with configuration!!
W/Resources( 22FIFO_RD_AUX_LSB read fails
70): Preloaded drawable resource #0x108047f (android:drawable/progress_horizontal_holo_dark) thatFIFO_RD_AUX_MSB read fails
W/Resources( 2270): Preloaded drawaFIFO_RD_AUX_LSB read fails
ble resource #0x108047e (android:drawable/progress_bg_holo_light) that varies with configuration!FIFO_RD_AUX_MSB read fails
W/Resources( 2270): Preloaded drawable resource #0x108048b (android:drawable/progress_secondarFIFO_RD_AUX_LSB read fails
y_holo_light) that varies with configuration!!
W/Resources( 2270FIFO_RD_AUX_MSB read fails
): Preloaded drawable resource #0x1080489 (android:drawable/progress_primary_holo_light) that varFIFO_RD_AUX_LSB read fails
W/Resoumma enable setting active
rces( 2270): Preloaded drawable resource #0x1080480 (android:drawFIFO_RD_AUX_MSB read fails
able/progress_horizontal_holo_light) that varies with configuratiFIFO_RD_AUX_LSB read fails
on!!
W/Resources( 2270): Preloaded drawable resource #0x1080493 (android:drawable/progressbar_indeterminate_holo1) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080494 (android:drawable/progressbar_indeterminate_holo2) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080495 (android:drawable/progressbar_indeterminate_holo3) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080496 (android:drawable/progressbar_indeterminate_holo4) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080497 (android:drawable/progressbar_indeterminate_holo5) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080498 (android:drawable/progressbar_indeterminate_holo6) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080499 (android:drawable/progressbar_indeterminate_holo7) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108049a (android:drawable/progressbar_indeterminate_holo8) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080481 (android:drawable/progress_indeterminate_horizontal_holo) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 361K, 15% free 2480K/2912K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x1080483 (android:drawable/progress_large_holo) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 54K, 15% free 2477K/2912K, paused 1ms+1ms, total 18ms
W/Resources( 2270): Preloaded drawable resource #0x1080486 (android:drawable/progress_medium_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080488 (android:drawable/progress_primary_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080489 (android:drawable/progress_primary_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108048a (android:drawable/progress_secondary_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawableeth0: no PHY, assuming direct connection to switch
resource #0x108048b (android:draPHY 0:00 not found
wable/progress_secondary_holo_ligeth0: could not attach to PHY
W/Resources( 2270): Preloaded drawable resource #0x108048d (android:drawable/progress_small_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804e7 (android:drawable/scrubber_track_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804e6 (android:drawable/scrubber_secondary_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804e3 (android:drawable/scrubber_primary_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804e4 (android:drawable/scrubber_progress_horizontal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804e8 (android:drawable/scrubber_track_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804e5 (android:drawable/scrubber_progress_horizontal_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 54K, 15% free 2481K/2912K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10804da (android:drawable/scrollbar_handle_holo_dark) that varies with configuration!!
W/Resoacc_open
urces( 2270): Preloaded drawable acc_release
resource #0x10804db (android:drawable/scrollbar_handle_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080510 (android:drawable/spinner_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080518 (android:drawable/spinner_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080514 (android:drawable/spinner_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108050e (android:drawable/spinner_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080508 (android:drawable/spinner_background_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080511 (android:drawable/spinner_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080519 (android:drawable/spinner_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080515 (android:drawable/spinner_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108050f (android:drawable/spinner_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080509 (android:drawable/spinner_background_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 48K, 15% free 2487K/2912K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10804fe (android:drawable/spinner_ab_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804ff (android:drawable/spinner_ab_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080500 (android:drawable/spinner_ab_disabled_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080501 (android:drawable/spinner_ab_disabled_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080502 (android:drawable/spinner_ab_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080503 (android:drawable/spinner_ab_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080506 (android:drawable/spinner_ab_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080507 (android:drawable/spinner_ab_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080504 (android:drawable/spinner_ab_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 59K, 15% free 2485K/2912K, paused 2ms+1ms, total 18ms
W/Resources( 2270): Preloaded drawable resource #0x1080505 (android:drawable/spinner_ab_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 52K, 15% free 2485K/2912K, paused 2ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x108020b (android:drawable/cab_background_bottom_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108020e (android:drawable/cab_background_top_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108020c (android:drawable/cab_background_bottom_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802b0 (android:drawable/ic_cab_done_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108020d (android:drawable/cab_background_top_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802b1 (android:drawable/ic_cab_done_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800d3 (android:drawable/btn_cab_done_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800d6 (android:drawable/btn_cab_done_focused_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800d4 (android:drawable/btn_cab_done_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800d9 (android:drawable/btn_cab_done_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800d5 (android:drawable/btn_cab_done_focused_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800da (android:drawable/btn_cab_done_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800d8 (android:drawable/btn_cab_done_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 49K, 15% free 2488K/2912K, paused 1ms+2ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x10800d7 (android:drawable/btn_cab_done_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080038 (android:drawable/ic_menu_close_clear_cancel) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080329 (android:drawable/ic_menu_copy_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108032a (android:drawable/ic_menu_copy_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108032c (android:drawable/ic_menu_cut_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108032d (android:drawable/ic_menu_cut_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080045 (android:drawable/ic_menu_more) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080340 (android:drawable/ic_menu_moreoverflow_normal_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108033e (android:drawable/ic_menu_moreoverflow_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080341 (android:drawable/ic_menu_moreoverflow_normal_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108033f (android:drawable/ic_menu_moreoverflow_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 55K, 15% free 2491K/2912K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x1080344 (android:drawable/ic_menu_paste_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080345 (android:drawable/ic_menu_paste_holo_light) that varies with confehci_fsl_bus_resume begins, DR
iguration!!
W/Resources( 2270): Preloaded drawable resource #0x108034b (android:drawable/ic_menu_selectall_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108034a (android:drawable/ic_menu_selectall_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802b4 (android:drawable/ic_clear_disabled) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802b6 (android:drawable/ic_clear_normal) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802b3 (android:drawable/ic_clear) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108035a (android:drawable/ic_search) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 53K, 15% free 2491K/2912K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10802ce (android:drawable/ic_go) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080361 (android:drawable/ic_voice_search) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108021f (android:drawable/dialog_bottom_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080220 (android:drawable/dialog_bottom_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080224 (android:drawable/dialog_full_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080225 (android:drawable/dialog_full_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 66K, 15% free 2490K/2912K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x108022d (android:drawable/dialog_middle_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108022e (android:drawable/dialog_middle_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108022f (android:drawable/dialog_top_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080230 (android:drawable/dialog_top_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802c1 (android:drawable/ic_dialog_alert_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10802c2 (android:drawable/ic_dialog_alert_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 48K, 15% free 2493K/2912K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10803c8 (android:drawable/list_divider_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10803c9 (android:drawable/list_divider_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800bd (android:drawable/ab_transparent_dark_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800bb (android:drawable/ab_stacked_transparent_dark_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800a1 (android:drawable/ab_bottom_transparent_dark_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800b5 (android:drawable/ab_solid_dark_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800b8 (android:drawable/ab_stacked_solid_dark_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108009e (android:drawable/ab_bottom_solid_dark_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800be (android:drawable/ab_transparent_light_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800bc (android:drawable/ab_stacked_transparent_light_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800a2 (android:drawable/ab_bottom_transparent_light_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800b6 (android:drawable/ab_solid_light_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800ba (android:drawable/ab_stacked_solid_light_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10800a0 (android:drawable/ab_bottom_solid_light_holo) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 50K, 15% free 2496K/2912K, paused 1ms+1ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x10800b7 (android:drawable/ab_solid_shadow_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108037a (android:drawable/item_background_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108037b (android:drawable/item_background_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108027a (android:drawable/fastscroll_thumb_pressed_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080278 (android:drawable/fastscroll_thumb_default_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080279 (android:drawable/fastscroll_thumb_holo) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 63K, 15% free 2500K/2912K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x108027f (android:drawable/fastscroll_track_pressed_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108027b (android:drawable/fastscroll_track_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108027d (android:drawable/fastscroll_track_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080274 (android:drawable/fastscroll_label_left_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080276 (android:drawable/fastscroll_label_right_holo_dark) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 74K, 15% free 2497K/2912K, paused 1ms+2ms, total 16ms
W/Resources( 2270): Preloaded drawable resource #0x1080280 (android:drawable/fastscroll_track_pressed_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108027c (android:drawable/fastscroll_track_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x108027e (android:drawable/fastscroll_track_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080275 (android:drawable/fastscroll_label_left_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080277 (android:drawable/fastscroll_label_right_holo_light) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 55K, 15% free 2497K/2912K, paused 1ms+1ms, total 17ms
W/Resources( 2270): Preloaded drawable resource #0x1080259 (android:drawable/editbox_dropdown_background_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805fc (android:drawable/textfield_search_selected_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805f0 (android:drawable/textfield_search_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805fe (android:drawable/textfield_searchview_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805f9 (android:drawable/textfield_search_right_selected_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805f7 (android:drawable/textfield_search_right_default_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080600 (android:drawable/textfield_searchview_right_holo_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805fd (android:drawable/textfield_search_selected_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805f1 (android:drawable/textfield_search_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805ff (android:drawable/textfield_searchview_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805fa (android:drawable/textfield_search_right_selected_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805f8 (android:drawable/textfield_search_right_default_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x1080601 (android:drawable/textfield_searchview_right_holo_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805c5 (android:drawable/tab_unselected_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805c0 (android:drawable/tab_selected_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805c4 (android:drawable/tab_unselected_focused_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805bf (android:drawable/tab_selected_focused_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805c6 (android:drawable/tab_unselected_pressed_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805c1 (android:drawable/tab_selected_pressed_holo) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10805b4 (android:drawable/tab_indicator_holo) that varies with configuration!!
D/dalvikvm( 2270): GC_EXPLICIT freed 55K, 1binder: 2553:2568 transaction failed 29189, size 96-0
4% free 2505K/2912K, paused 2ms+1ms, total 17ms
W/Resources( 227binder: 2553:2567 transaction failed 29189, size 100-0
W/Resources( 2270): Preloaded drawable resource #0x10805c6 (android:drawable/tab_unsebinder: release 2553:2565 transaction 2217 in, still active
lected_pressed_holo) that varies binder: send failed reply for transaction 2217 to 2672:2836
W/Resourcesbinder: release 2553:2712 transaction 2093 in, still active
( 2270): Preloaded drawable resoubinder: send failed reply for transaction 2093 to 2806:2806
rce #0x10805c1 (android:drawable/binder: send failed reply for transaction 2223 to 2672:2672
tab_selected_pressed_holo) that vbinder: send failed reply for transaction 2227 to 2787:2787
W/Resbinder: send failed reply for transaction 2232 to 2756:2756
ources( 2270): Preloaded drawablebinder: send failed reply for transaction 2241 to 2764:2764
resource #0x10804a9 (android:drabinder: release proc 2553, transaction 2235, not freed
wable/quickcontact_badge_overlay_pressed_dark) that varies with configuration!!
W/Resources( 227binder: 2787:2787 transaction failed 29189, size 64-0
0): Preloaded drawable resource #binder: 2672:2672 transaction failed 29189, size 3940-4
0x10804a4 (android:drawable/quickcontact_badge_overlay_focused_dark) that varies with configuration!!
W/Resources( 2270): Preloabinder: 2764:2764 transaction failed 29189, size 96-4
ded drawable resource #0x10804a7 binder: 2806:2806 transaction failed 29189, size 84-0
(android:drawable/quickcontact_babinder: 2756:2756 transaction failed 29189, size 3492-4
dge_overlay_normal_dark) that varbinder: 2764:2844 transaction failed 29189, size 468-4
W/Resoubinder: 2787:2787 transaction failed 29189, size 3092-4
rces( 2270): Preloaded drawable resource #0x10804a3 (android:drawable/quickcontact_badge_overlay_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804a7 (android:drawable/quickcontact_badge_overlay_normal_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804a9 (android:drawable/quickcontact_badge_overlay_pressed_dark) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804aa (android:drawable/quickcontact_badge_overlay_pressed_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804a5 (android:drawable/quickcontact_badge_overlay_focused_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804a8 (android:drawable/quickcontact_badge_overlay_normal_light) that varies with configuration!!
W/Resources( 2270): Preloaded drawable resource #0x10804a6 (android:drawable/quickcontact_badge_overlay_light) that varies with configuration!!
I/Zygote  ( 2270): ...preloaded 274 resources in 1394ms.
D/dalvikvm( 2270): GC_EXPLICIT freed 57K, 15% free 2503K/2912K, paused 1ms+2ms, total 17ms
I/Zygote  ( 2270): ...preloaded 31 resources in 28ms.
D/dalvikvm( 2270): GC_EXPLICIT freed 11K, 14% fralarm_release: clear alarm, pending 0
ee 2518K/2912K, paused 1ms+1ms, talarm_release: clear alarm, pending 0
otal 17ms
D/dalvikvm( 2270): GC_EXPLICIT freed 10K, 14% free 2508K/2912K, paused 2ms+1ms, total 17ms
D/dalvikvm( 2270): GC_EXPLICIT freed <1K, 14% free 2507K/2912K, paused 1ms+1ms, total 17ms
I/dalvikvm( 2270): System server process 2553 has been created
I/Zygote  ( 2270): Accepting command socket connections
D/SystemClock( 2553): Setting time of day to sec=86400
W/SystemServer( 2553): System clock is before 1970; setting to 1970.
I/sysproc ( 2553): Entered system_init()
I/sysproc ( 2553): ServiceManager: 0x4154e4c0
D/SensorService( 2553): nuSensorService starting...
E/        ( 2553): couldn't find 'eCompass' input device
E/        ( 2553): Can`t find the mag sensor!
E/        ( 2553): couldn't find 'mpl3115' input device
E/        ( 2553): Can`t find the press sensor!
D/        ( 2553): AccelSensor enable 0 ,usercount 0, handle 0 ,mEnabled 0
D/        ( 2553): AccelSensor enable 0 ,usercount 0, handle 1 ,mEnabled 0
D/        ( 2553): MagSensor mEnabled 0, OrientaionSensor mEnabled 0
D/        ( 2553): AccelSensor enable 0 ,usercount 0, handle 2 ,mEnabled 0
D/        ( 2553): PressSensor mEnabled 0, Temperature mEnabled 0
I/SensorService( 2553): Freescale 3-axis Accelerometer
I/SensorService( 2553): Freescale 3-axis Magnetic field sensor
I/SensorService( 2553): Freescale Orientation sensor
I/SensorService( 2553): MPL3115 Temperature sensor
I/SensorService( 2553): ISL29023 Light sensor
I/sysproc ( 2553): System server: starting Android runtime.
I/sysproc ( 2553): System server: starting Android services.
D/SensorService( 2553): nuSensorService thread starting...
I/sysproc ( 2553): System server: entering thread pool.
I/installd( 2273): new connection
E/SWITCHPROFILE( 2553): setprop: sys.interactive = active
I/SystemServer( 2553): Entered the Android system server!
I/SystemServer( 2553): Enabled StrictMode logging for UI Looper
I/SystemServer( 2553): Waiting for installd to be ready.
I/Installer( 2553): connecting...
I/SystemServer( 2553): Power Manager
I/SystemServer( 2553): Enabled StrictMode logging for WM Looper
I/SystemServer( 2553): Activity Manager
I/ActivityManager( 2553): Memory class: 64
W/UsageStats( 2553): Usage stats version changed; dropping
I/AppOps  ( 2553): No existing app ops /data/system/appops.xml; starting empty
I/SystemServer( 2553): Display Manager
I/ActivityManager( 2553): Enabled StrictMode logging for AThread's Looper
I/DisplayManagerService( 2553): Display device added: DisplayDeviceInfo{"Built-in Screen": 1024 x 768, 60.000004 fps, density 160, 213.0 x 213.0 dpi, touch INTERNAL, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, rotation 0, type BUILT_IN, address null}
I/SystemServer( 2553): Telephony Registry
I/SystemServer( 2553): Scheduling Policy
I/SystemServer( 2553): Package Manager
D/dalvikvm( 2553): GC_CONCURRENT freed 218K, 9% free 2784K/3052K, paused 3ms+2ms, total 29ms
D/dalvikvm( 2553): GC_FOR_ALLOC freed 420K, 18% free 2733K/3332K, paused 12ms, total 12ms
D/SELinuxMMAC( 2553): Couldn't find install policy /data/system/mac_permissions.xml
D/SELinuxMMAC( 2553): Using install policy file /system/etc/security/mac_permissions.xml
I/PackageManager( 2553): Need to read from backup stopped packages file
W/PackageManager( 2553): Cleaning up stopped packages file /data/system/users/0/package-restrictions.xml
W/PackageManager( 2553): Running ENG build: no pre-dexopt!
D/dalvikvm( 2553): GC_CONCURRENT freed 306K, 15% free 2864K/3332K, paused 2ms+3ms, total 25ms
W/PackageParser( 2553): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #202
D/dalvikvm( 2553): GC_CONCURRENT freed 118K, 6% free 3156K/3332K, paused 2ms+1ms, total 22ms
W/PackageParser( 2553): No actions in intent filter at /system/app/Contacts.apk Binary XML file line #374
W/PackageParser( 2553): No actions in intent filter at /system/app/Dialer.apk Binary XML file line #138
W/ResourceType( 2553): Failure getting entry for 0x7f040030 (t=3 e=48) in package 0 (error -75)
W/PackageParser( 2553): Unknown element under <application>: permission at /system/app/Gallery2.apk Binary XML file line #225
W/PackageParser( 2553): Unknown element under <application>: permission at /system/app/Gallery2.apk Binary XML file line #228
D/dalvikvm( 2553): GC_CONCURRENT freed 203K, 7% free 3374K/3628K, paused 2ms+5ms, total 32ms
I/AudioFlinger( 2272): Using module 1 has the primary audio interface
I/AudioFlinger( 2272): AudioFlinger's thread 0x40cc2008 ready to run
W/audio_hw_primary( 2272): out_set_parameters routing=2, ret 1, out 1074038680
I/audio_a2dp_hw( 2272): adev_open:  adev_open in A2dp_hw module
I/AudioFlinger( 2272): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/r_submix( 2272): adev_open(name=audio_hw_if)
I/r_submix( 2272): adev_init_check()
I/AudioFlinger( 2272): loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 4
I/AudioFlinger( 2272): loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 5
I/AudioPolicyService( 2272): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/dalvikvm( 2553): GC_CONCURRENT freed 221K, 8% free 3541K/3812K, paused 2ms+2ms, total 23ms
D/PackageManager( 2553): No files in app dir /vendor/app
W/PackageManager( 2553): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager( 2553): Time to scan packages: 1.038 seconds
W/PackageManager( 2553): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
W/PackageManager( 2553): Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 2553): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 2553): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 2553): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.exchange
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 2553): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 2553): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.andrequest_suspend_state: wakeup (0->0) at 18600694337 (1970-01-02 00:00:06.211540000 UTC)
roid.email
W/PackageManager( 2553): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (prinit: untracked pid 2267 exited
otectionLevel=2 flags=0x48be45)
init: untracked pid 2272 exited
D/dalvikvm( 2553): GC_CONCURRENT init: untracked pid 2693 exited
freed 325K, 10% free 3731K/4104K, paused 2ms+3ms, total 23ms
D/dalvikvm( 2553): GC_EXPLICIT freed 247K, 14% free 3601K/4156K, paused 1ms+1ms, total 27ms
I/SystemServer( 2553): Entropy Mixer
I/EntropyMixer( 2553): Writing entropy...
I/SystemServer( 2553): User Service
I/SystemServer( 2553): Account Manager
I/SystemServer( 2553): Content Manager
I/SystemServer( 2553): System Content Providers
I/lights  ( 2553): max backlight file is /sys/class/backlight/pwm-backlight.0/max_brightness
I/lights  ( 2553): backlight brightness file is /sys/class/backlight/pwm-backlight.0/brightness
I/SystemServer( 2553): Lights Service
I/SystemServer( 2553): Battery Service
I/SystemServer( 2553): Vibrator Service
I/libsuspend( 2553): Selected early suspend
I/libsuspend( 2553): Starting early suspend unblocker thread
I/SWITCHPROFILE( 2553): Switchprofile thread init: untracked pid 2764 exited
received GOV_INTERACTIVE from Power HAL
D/PermissionCache( 2269): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (642 us)
D/SurfaceFlinger( 2269): Screen acquired, type=0 flinger=0x417bc478
D/SurfaceFlinger( 2269):  screen was previously acquired
I/SystemServer( 2553): Alarm Manager
I/SystemServer( 2553): Init Watchdog
I/SystemServer( 2553): Input Manager
I/InputManager( 2553): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer( 2553): Window Manager
I/WindowManager( 2553): No existing display settings /data/system/display_settings.xml; starting empty
E/OMXMaster( 2272): A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one.
E/OMXMaster( 2272): A component of name 'OMX.Freescale.std.parser.streaming.sw-based' already exists, ignoring this one.
D/dalvikvm( 2553): GC_CONCURRENT freed 296K, 9% free 3818K/4172K, paused 3ms+2ms, total 48ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 11ms
D/        ( 2553): AccelSensor enable 1 ,usercount 1, handle 0 ,mEnabled 1
I/InputManager( 2553): Starting input manager
I/SystemServer( 2553): Bluetooth Manager Service
D/BluetoothManagerService( 2553): Loading stored name and address
D/BluetoothManagerService( 2553): Stored bluetooth Name=null,Address=null
I/SystemServer( 2553): Input Method Service
W/InputMethodManagerService( 2553): Couldn't create dir.: /data/system/inputmethod
D/EventHub( 2553): No input device configuration file found for device 'FreescaleAccelerometer'.
W/ResourceType( 2553): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/SystemServer( 2553): Accessibility Manager
I/ActivityManager( 2553): Config changes=15f8 {1.0 ?mcc?mnc en_US ldltr sERROR: v4l2 capture: slave not found!
w768dp w1024dp h695dp 160dpi xlrgERROR: v4l2 capture: slave not found!
land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
I/SystemServer( 2553): Mount Service
D/MountService( 2553): got storage path: null description: Internal storage primary: true removable: false emulated: true mtpReserve: 10ERROR: v4l2 capture: slave not found!
0 allowMassStorage: false maxFileERROR: v4l2 capture: slave not found!
D/MountService( 2553): aERROR: v4l2 capture: slave not found!
ddVolumeLocked() StorageVolume [mERROR: v4l2 capture: slave not found!
StorageId=65537 mPath=/storage/emERROR: v4l2 capture: slave not found!
ulated/0 mDescriptionId=17040655 ERROR: v4l2 capture: slave not found!
mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100 mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0}]
D/MountService( 2553): got storage path: /mnt/extsd description: SD card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 2553): addVolumeLocked() StorageVolume [mStorageId=0 mPath=/mnt/extsd mDescriptionId=17040656 mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false mMaxFileSize=0 mOwner=null]
D/MountService( 2553): got storage path: /mnt/udisk description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 2553): addVolumeLocked() StorageVolume [mStorageId=0 mPath=/mnt/udisk mDescriptionId=17040657 mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false mMaxFileSize=0 mOwner=null]
I/SystemServer( 2553): LockSettingsService
I/SystemServer( 2553): Device Policy
I/SystemServer( 2553): Status Bar
I/SystemServer( 2553): Clipboard Service
E/EventHub( 2553): could not get driver version for /dev/input/mice, Not a typewriter
I/SystemServer( 2553): NetworkManagement Service
I/SystemServer( 2553): Text Service Manager Service
I/SystemServer( 2553): NetworkStats Service
I/SystemServer( 2553): NetworkPolicy Service
D/dalvikvm( 2553): GREF has increased to 201
I/SystemServer( 2553): Wi-Fi P2pService
D/MountService( 2553): volume state changed for /mnt/extsd (null -> removed)
D/MountService( 2553): volume state changed for /mnt/udisk (null -> removed)
I/SystemServer( 2553): Wi-Fi Service
I/PackageManager( 2553): No secure containers on sdcard
W/PackageManager( 2553): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x89be45)
W/PackageManager( 2553): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.email
D/EventHub( 2553): No input device configuration file found for device 'wm8962-audio Headphone Jack'.
I/EventHub( 2553): New device: id=2, fd=121, path='/dev/input/event4', name='wm8962-audio Headphone Jack', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
D/EventHub( 2553): No input device configuration file found for device 'wm8962-audio DMIC'.
I/EventHub( 2553): New device: id=3, fd=122, path='/dev/input/event3', name='wm8962-audio DMIC', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
D/EventHub( 2553): No input device configuration file found for device 'gpio-keys'.
W/PackageManager( 2553): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0xc8be45)
W/EventHub( 2553): Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
I/EventHub( 2553): New device: id=4, fd=123, path='/dev/input/event0', name='gpio-keys', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
D/EventHub( 2553): No input device configuration file found for device 'WM8962 Beep Generator'.
D/dalvikvm( 2553): GC_CONCURRENT freed 337K, 10% free 3964K/4360K, paused 3ms+2ms, total 25ms
I/InputReader( 2553): Device added: id=-1, name='Virtual', sources=0x00000301
I/InputReader( 2553): Device added: id=4, name='gpio-keys', sources=0x00000101
I/InputReader( 2553): Device added: id=3, name='wm8962-audio DMIC', sources=0x80000000
I/InputReader( 2553): Device added: id=2, name='wm8962-audio Headphone Jack', sources=0x80000000
I/InputReader( 2553): Reconfiguring input devices.  changes=0x00000004
I/ActivityManager( 2553): Config changes=1400 {1.0 ?mcc?mnc en_US ldltr sw768dp w1024dp h695dp 160dpi xlrg land ?uimode ?night -touch -keyb/v/h -nav/h s.3}
I/SystemServer( 2553): Connectivity Service
D/ConnectivityService( 2553): ConnectivityService starting up
D/ConnectivityService( 2553): wifiOnly=false
D/CommandListener( 2267): Setting iface cfg
D/CommandListener( 2267): Trying to bring up eth0
E/CommandListener( 2267): Error upping interface
F/SystemServer( 2553): BOOT FAILURE starting Connectivity Service
F/SystemServer( 2553): java.lang.IllegalStateException: command '3 interface setcfg eth0 0.0.0.0 0 multicast up broadcast' failed with '400 3 Failed to up interface (No such device)'
F/SystemServer( 2553):  at com.android.server.NetworkManagementService.setInterfaceConfig(NetworkManagementService.java:549)
F/SystemServer( 2553):  at com.android.server.NetworkManagementService.setInterfaceUp(NetworkManagementService.java:566)
F/SystemServer( 2553):  at android.net.EthernetDataTracker.startMonitoring(EthernetDataTracker.java:245)
F/SystemServer( 2553):  at com.android.server.ConnectivityService.<init>(ConnectivityService.java:586)
F/SystemServer( 2553):  at com.android.server.ConnectivityService.<init>(ConnectivityService.java:395)
F/SystemServer( 2553):  at com.android.server.ServerThread.run(SystemServer.java:498)
F/SystemServer( 2553): Caused by: com.android.server.NativeDaemonConnector$NativeDaemonFailureException: command '3 interface setcfg eth0 0.0.0.0 0 multicast up broadcast' failed with '400 3 Failed to up interface (No such device)'
F/SystemServer( 2553):  at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:382)
F/SystemServer( 2553):  at com.android.server.NativeDaemonConnector.executeForList(NativeDaemonConnector.java:318)
F/SystemServer( 2553):  at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:283)
F/SystemServer( 2553):  at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:268)
F/SystemServer( 2553):  at com.android.server.NetworkManagementService.setInterfaceConfig(NetworkManagementService.java:547)
F/SystemServer( 2553):  ... 5 more
W/SystemServer( 2553): ***********************************************
I/SystemServer( 2553): Network Service Discovery Service
D/NsdService( 2553): Network service discovery enabled true
I/SystemServer( 2553): UpdateLock Service
I/SystemServer( 2553): Notification Manager
I/SystemServer( 2553): Device Storage Monitor
I/SystemServer( 2553): Location Manager
I/SystemServer( 2553): Country Detector
I/SystemServer( 2553): Search Service
I/SystemServer( 2553): DropBox Service
I/SystemServer( 2553): Wallpaper Service
W/WallpaperService( 2553): no current wallpaper -- first boot?
I/SystemServer( 2553): Audio Service
D/dalvikvm( 2553): GC_CONCURRENT freed 308K, 9% free 4088K/4456K, paused 3ms+3ms, total 27ms
I/SystemServer( 2553): Dock Observer
W/DockObserver( 2553): This kernel does not have dock station support
I/SystemServer( 2553): Wired Accessory Manager
I/SystemServer( 2553): USB Service
D/WifiHW  ( 2553): Unable to unload driver module "8723as": No such file or directory
I/SystemServer( 2553): Serial Service
I/SystemServer( 2553): Twilight Service
I/SystemServer( 2553): UI Mode Manager Service
I/SystemServer( 2553): Backup Service
V/BackupManagerService( 2553): Initializing package tracking
V/BackupManagerService( 2553): No ancestral data
V/BackupManagerService( 2553): addPackageParticipantsLocked: all
I/BackupManagerService( 2553): Scheduling backup for new app com.android.calendar
D/BackupManagerService( 2553): Now staging backup of com.android.calendar
I/BackupManagerService( 2553): Scheduling backup for new app com.android.browser
D/BackupManagerService( 2553): Now staging backup of com.android.browser
I/BackupManagerService( 2553): Scheduling backup for new app com.android.providers.userdictionary
D/BackupManagerService( 2553): Now staging backup of com.android.providers.userdictionary
I/BackupManagerService( 2553): Scheduling backup for new app com.android.sharedstoragebackup
D/BackupManagerService( 2553): Now staging backup of com.android.sharedstoragebackup
I/BackupManagerService( 2553): Scheduling backup for new app android
D/BackupManagerService( 2553): Now staging backup of android
I/BackupManagerService( 2553): Scheduling backup for new app com.android.gallery3d
D/BackupManagerService( 2553): Now staging backup of com.android.gallery3d
I/BackupManagerService( 2553): Scheduling backup for new app com.android.providers.settings
D/BackupManagerService( 2553): Now staging backup of com.android.providers.settings
V/BackupManagerService( 2553): Registering transport android/com.android.internal.backup.LocalTransport = com.android.inFIFO_RD_AUX_MSB read fails
ternal.backup.LocalTransport@41c55e98
V/BackupManagerService( 2553): Starting with transport android/com.android.internal.backupFIFO_RD_AUX_LSB read fails
.LocalTransport
V/BackupManagerService( 2553): Google transport not present
I/BackupManagerServFIFO_RD_AUX_MSB read fails
ice( 2553): Found stale backup journal, scheduling
I/BackupManagerService( 2553):   com.android.calendar
I/BackupManagerService( 2553):   com.android.browser
I/BackupManagerService( 2553):   com.android.providers.userdictionary
I/BackupManagerService( 25FIFO_RD_AUX_MSB read fails
53):   com.android.sharedstoragebackup
I/BackupManagerService( 2553):   android
I/BackupManagerFIFO_RD_AUX_LSB read fails
Service( 2553):   com.android.gallery3d
I/BackupManagerService( 2553):   com.android.providers.settings
I/BackupManagerService( 2553): Backup enabled => false
I/BackupManagerService( 2553): Opting out of backup
I/SystemServer( 2553): AppWidget Service
I/SystemServer( 2553): RecognitiFIFO_RD_AUX_MSB read fails
on Service
I/SystemServer( 2553): DiskStats Service
I/WindowManager( 2553): SAFE MODE not enabled
D/dalvikvm( 2553): JIT startFIFO_RD_AUX_LSB read fails
ed for system_server
I/SystemServer( 2553): SamplingProfiler SerFIFO_RD_AUX_MSB read fails
vice
I/SystemServer( 2553): NetworkTimeUpdateService
I/SystemServer( 2553): CommonTimeManagementService
I/SystemServer( 2553): CertBlacklister
I/SystemServerFIFO_RD_AUX_LSB read fails
( 2553): Dreams Service
I/SystemServer( 2553): IdleMaintenanceService
I/ActivityManager( 2553): System now ready
I/SystemServer( 2553): Making services ready
I/SWITCHPROFILE( 2553): Switchprofile thread received GOV_INTERFIFO_RD_AUX_MSB read fails
I/Zygote  ( 2553): Process: zygote socket opened
D/dalvikvm( 2553): GC_CONCURRENT freed 271K, 7% free 4318K/4FIFO_RD_AUX_LSB read fails
632K, paused 2ms+12ms, total 64ms
I/ActivityManager( 2553): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=2626 uid=10036 gids={50036, 1028, 1015, 3002, 3001}
D/NetworkManagementService( 2553): enabling bandwidth control
W/MountService( 2553): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
D/SystemUIService( 2626): loading: class com.android.systemui.statusbar.phone.PhoneStatusBar
D/SystemUIService( 2626): running: com.android.systemui.statusbar.phone.PhoneStatusBar@41ac2110
I/StatusBarManagerService( 2553): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@41c726f8
D/PhoneStatusBar( 2626): mSettingsPanelGravity = 8388661
D/dalvikvm( 2553): GC_CONCURRENT freed 321K, 8% free 4509K/4888K, paused 3ms+2ms, total 67ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 42ms
D/dalvikvm( 2553): GC_FOR_ALLOC freed 65K, 9% free 4644K/5056K, paused 24ms, total 26ms
D/dalvikvm( 2626): GC_FOR_ALLOC freed 82K, 5% free 2721K/2856K, paused 23ms, total 24ms
D/dalvikvm( 2626): GC_CONCURRENT freed 20K, 4% free 3159K/3272K, paused 2ms+2ms, total 19ms
I/Choreographer( 2553): Skipped 30 frames!  The application may be doing too much work on its main thread.
D/dalvikvm( 2553): GC_CONCURRENT freed 273K, 7% free 4860K/5192K, paused 3ms+14ms, total 78ms
D/AndroidRuntime( 2626): Shutting down VM
W/dalvikvm( 2626): threadid=1: thread exiting with uncaught exception (group=0x41845700)
F/SystemServer( 2553): BOOT FAILURE making Network Stats Service ready
F/SystemServer( 2553): java.lang.NullPointerException
F/SystemServer( 2553):  at com.android.server.net.NetworkStatsService.getNetworkStatsTethering(NetworkStatsService.java:1196)
F/SystemServer( 2553):  at com.android.server.net.NetworkStatsService.getNetworkStatsUidDetail(NetworkStatsService.java:1183)
F/SystemServer( 2553):  at com.android.server.net.NetworkStatsService.bootstrapStatsLocked(NetworkStatsService.java:926)
F/SystemServer( 2553):  at com.android.server.net.NetworkStatsService.systemReady(NetworkStatsService.java:313)
F/SystemServer( 2553):  at com.android.server.ServerThread$3.run(SystemServer.java:892)
F/SystemServer( 2553):  at com.android.server.am.ActivityManagerService.systemReady(ActivityManagerService.java:8148)
F/SystemServer( 2553):  at com.android.server.ServerThread.run(SystemServer.java:866)
I/Process ( 2626): Sending signal. PID: 2626 SIG: 9
E/AndroidRuntime( 2626): FATAL EXCEPTION: main
E/AndroidRuntime( 2626): java.lang.RuntimeException: Unable to create service com.android.systemui.SystemUIService: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2626):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2587)
E/AndroidRuntime( 2626):        at android.app.ActivityThread.access$1600(ActivityThread.java:141)
E/AndroidRuntime( 2626):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
E/AndroidRuntime( 2626):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2626):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2626):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2626):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2626):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2626):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2626):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2626):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2626): Caused by: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2626):        at com.android.internal.util.Preconditions.checkNotNull(Preconditions.java:52)
E/AndroidRuntime( 2626):        at android.net.ConnectivityManager.<init>(ConnectivityManager.java:838)
E/AndroidRuntime( 2626):        at android.app.ContextImpl$10.createStaticService(ContextImpl.java:334)
E/AndroidRuntime( 2626):        at android.app.ContextImpl$StaticServiceFetcher.getService(ContextImpl.java:258)
E/AndroidRuntime( 2626):        at android.app.ContextImpl.getSystemService(ContextImpl.java:1514)
E/AndroidRuntime( 2626):        at android.content.ContextWrapper.getSystemService(ContextWrapper.java:519)
E/AndroidRuntime( 2626):        at com.android.systemui.statusbar.policy.NetworkController.<init>(NetworkController.java:196)
E/AndroidRuntime( 2626):        at com.android.systemui.statusbar.phone.PhoneStatusBar.makeStatusBarView(PhoneStatusBar.java:490)
E/AndroidRuntime( 2626):        at com.android.systemui.statusbar.phone.PhoneStatusBar.addStatusBarWindow(PhoneStatusBar.java:2136)
E/AndroidRuntime( 2626):        at com.android.systemui.statusbar.phone.PhoneStatusBar.createAndAddWindows(PhoneStatusBar.java:2111)
E/AndroidRuntime( 2626):        at com.android.systemui.statusbar.BaseStatusBar.start(BaseStatusBar.java:230)
E/AndroidRuntime( 2626):        at com.android.systemui.statusbar.phone.PhoneStatusBar.start(PhoneStatusBar.java:315)
E/AndroidRuntime( 2626):        at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:100)
E/AndroidRuntime( 2626):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
E/AndroidRuntime( 2626):        ... 10 more
I/ActivityManager( 2553): Process com.android.systemui (pid 2626) has died.
W/ActivityManager( 2553): Scheduling restart of crashed service com.android.systemui/.SystemUIService in 0ms
I/ActivityManager( 2553): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 0
I/ActivityManager( 2553): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=2672 uid=10020 gids={50020, 1028}
I/ActivityManager( 2553): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=2680 uid=10036 gids={50036, 1028, 1015, 3002, 3001}
I/ActivityManager( 2553): Start proc android.process.media for broadcast com.android.providers.media/.MtpReceiver: pid=2693 uid=10014 gids={50014, 1015, 1023, 1024, 1028, 2001, 3003, 3007}
W/ContextImpl( 2553): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1042 com.android.server.usb.UsbSettingsManager.deviceAttached:621 com.android.server.usb.UsbHostManager.usbDeviceAdded:156 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:38
I/ActivityManager( 2553): Config changes=200 {1.0 ?mcc?mnc en_US ldltr sw768dp w1024dp h695dp 160dpi xlrg land -touch -keyb/v/h -nav/h s.4}
D/PermissionCache( 2269): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (295 us)
E/BufferQueue( 2269): [ScreenshotSurface] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/dalvikvm( 2553): GC_CONCURRENT freed 562K, 12% free 4890K/5508K, paused 7ms+3ms, total 99ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 24ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 21ms
V/KeyguardHostView( 2553): music state changed: 0
W/RecognitionManagerService( 2553): no available voice recognition services found for user 0
E/UsbHostManagerJNI( 2553): usb_device_open failed
V/TAG     ( 2553): bug 7643792: fitSystemWindows([0,0][0,0])
W/InputMethodManagerService( 2553): Ignoring setImeWindowStatus of uid 1000 token: null
I/ActivityManager( 2553): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=2717 uid=10019 gids={50019, 1015, 1028}
V/InputMethodManagerService( 2553): Adding window token: android.os.Binder@41c91e10
D/SystemUIService( 2680): loading: class com.android.systemui.statusbar.phone.PhoneStatusBar
D/SystemUIService( 2680): running: com.android.systemui.statusbar.phone.PhoneStatusBar@41ac4458
D/PhoneStatusBar( 2680): mSettingsPanelGravity = 8388661
I/StatusBarManagerService( 2553): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@41c17648
F/SystemServer( 2553): BOOT FAILURE making Location Service ready
F/SystemServer( 2553): java.lang.NullPointerException: missing IConnectivityManager
F/SystemServer( 2553):  at com.android.internal.util.Preconditions.checkNotNull(Preconditions.java:52)
F/SystemServer( 2553):  at android.net.ConnectivityManager.<init>(ConnectivityManager.java:838)
F/SystemServer( 2553):  at android.app.ContextImpl$10.createStaticService(ContextImpl.java:334)
F/SystemServer( 2553):  at android.app.ContextImpl$StaticServiceFetcher.getService(ContextImpl.java:258)
F/SystemServer( 2553):  at android.app.ContextImpl.getSystemService(ContextImpl.java:1514)
F/SystemServer( 2553):  at com.android.server.location.GpsLocationProvider.<init>(GpsLocationProvider.java:452)
F/SystemServer( 2553):  at com.android.server.LocationManagerService.loadProvidersLocked(LocationManagerService.java:346)
F/SystemServer( 2553):  at com.android.server.LocationManagerService.systemReady(LocationManagerService.java:236)
F/SystemServer( 2553):  at com.android.server.ServerThread$3.run(SystemServer.java:952)
D/dalvikvm( 2553): GC_FOR_ALLOC freed 300K, 9% free 5051K/5508K, paused 37ms, total 38ms
I/CommonTimeManagementService( 2553): No common time service detected on this platform.  Common time services will be unavailable.
I/InputReader( 2553): Reconfiguring input devices.  changes=0x00000020
I/InputReader( 2553): Reconfiguring input devices.  changes=0x00000010
I/ActivityManager( 2553): Start proc com.android.phone for added application com.android.phone: pid=2737 uid=1001 gids={41001, 3002, 3001, 3003, 1015, 1028}
I/SystemServer( 2553): Enabled StrictMode for system server main thread.
D/dalvikvm( 2553): GREF has increased to 301
D/BluetoothManagerService( 2553): Message: 300
D/BluetoothManagerService( 2553): MESSAGE_USER_SWITCHED
I/LatinIME( 2717): Hardware accelerated drawing: true
D/dalvikvm( 2553): GC_CONCURRENT freed 339K, 7% free 5348K/5744K, paused 11ms+3ms, total 140ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 40ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 38ms
D/dalvikvm( 2553): WAIT_FOR_CONCURRENT_GC blocked 29ms
D/libEGL  ( 2553): loaded /system/lib/egl/libEGL_VIVANTE.so
D/AndroidRuntime( 2717): Shutting down VM
W/dalvikvm( 2717): threadid=1: thread exiting with uncaught exception (group=0x41845700)
D/dalvikvm( 2680): GC_FOR_ALLOC freed 90K, 5% free 2723K/2864K, paused 53ms, total 53ms
E/AndroidRuntime( 2717): FATAL EXCEPTION: main
E/AndroidRuntime( 2717): java.lang.RuntimeException: Unable to create service com.android.inputmethod.latin.LatinIME: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2717):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2587)
E/AndroidRuntime( 2717):        at android.app.ActivityThread.access$1600(ActivityThread.java:141)
E/AndroidRuntime( 2717):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
E/AndroidRuntime( 2717):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2717):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2717):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2717):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2717):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2717):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2717):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2717):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2717): Caused by: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2717):        at com.android.internal.util.Preconditions.checkNotNull(Preconditions.java:52)
E/AndroidRuntime( 2717):        at android.net.ConnectivityManager.<init>(ConnectivityManager.java:838)
E/AndroidRuntime( 2717):        at android.app.ContextImpl$10.createStaticService(ContextImpl.java:334)
E/AndroidRuntime( 2717):        at android.app.ContextImpl$StaticServiceFetcher.getService(ContextImpl.java:258)
E/AndroidRuntime( 2717):        at android.app.ContextImpl.getSystemService(ContextImpl.java:1514)
E/AndroidRuntime( 2717):        at android.content.ContextWrapper.getSystemService(ContextWrapper.java:519)
E/AndroidRuntime( 2717):        at com.android.inputmethod.latin.SubtypeSwitcher.initialize(SubtypeSwitcher.java:97)
E/AndroidRuntime( 2717):        at com.android.inputmethod.latin.SubtypeSwitcher.init(SubtypeSwitcher.java:84)
E/AndroidRuntime( 2717):        at com.android.inputmethod.latin.LatinIME.onCreate(LatinIME.java:435)
E/AndroidRuntime( 2717):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
E/AndroidRuntime( 2717):        ... 10 more
D/libEGL  ( 2553): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
W/TelephonyProvider( 2737): onCreate: confFile=/system/etc/apns-conf.xml oldCheckSum=-1
I/Process ( 2717): Sending signal. PID: 2717 SIG: 9
I/ActivityManager( 2553): Process com.android.inputmethod.latin (pid 2717) has died.
W/ActivityManager( 2553): Scheduling restart of crashed service com.android.inputmethod.latin/.LatinIME in 5000ms
D/dalvikvm( 2680): GC_CONCURRENT freed 21K, 4% free 3163K/3280K, paused 2ms+2ms, total 27ms
D/dalvikvm( 2680): WAIT_FOR_CONCURRENT_GC blocked 15ms
I/ActivityManager( 2553): Start proc com.android.music for broadcast com.android.music/.MediaButtonIntentReceiver: pid=2756 uid=10025 gids={50025, 3003, 1015, 1028}
D/BluetoothManagerService( 2553): Retrieving Bluetooth Adapter name and address...
D/BluetoothManagerService( 2553): getNameAndAddress(): mBluetooth = null mBinding = false
D/BluetoothManagerService( 2553): Message: 200
D/BluetoothManagerService( 2553): MESSAGE_GET_NAME_AND_ADDRESS
D/BluetoothManagerService( 2553): Binding to service to get name and address
D/dalvikvm( 2553): GC_CONCURRENT freed 546K, 10% free 5469K/6060K, paused 31ms+20ms, total 151ms
I/ActivityManager( 2553): Start proc com.android.bluetooth for service com.android.bluetooth/.btservice.AdapterService: pid=2764 uid=1002 gids={41002, 3003, 3002, 3001, 1015, 3005, 1016, 3008, 1028}
D/dalvikvm( 2672): GC_CONCURRENT freed 170K, 8% free 2775K/2996K, paused 2ms+26ms, total 70ms
D/BluetoothManagerService( 2553): Added callback: android.bluetooth.BluetoothAdapter$1@41c186b8:true
D/AndroidRuntime( 2680): Shutting down VM
W/dalvikvm( 2680): threadid=1: thread exiting with uncaught exception (group=0x41845700)
E/AndroidRuntime( 2680): FATAL EXCEPTION: main
E/AndroidRuntime( 2680): java.lang.RuntimeException: Unable to create service com.android.systemui.SystemUIService: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2680):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2587)
E/AndroidRuntime( 2680):        at android.app.ActivityThread.access$1600(ActivityThread.java:141)
E/AndroidRuntime( 2680):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
E/AndroidRuntime( 2680):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2680):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2680):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2680):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2680):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2680):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2680):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2680):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2680): Caused by: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2680):        at com.android.internal.util.Preconditions.checkNotNull(Preconditions.java:52)
E/AndroidRuntime( 2680):        at android.net.ConnectivityManager.<init>(ConnectivityManager.java:838)
E/AndroidRuntime( 2680):        at android.app.ContextImpl$10.createStaticService(ContextImpl.java:334)
E/AndroidRuntime( 2680):        at android.app.ContextImpl$StaticServiceFetcher.getService(ContextImpl.java:258)
E/AndroidRuntime( 2680):        at android.app.ContextImpl.getSystemService(ContextImpl.java:1514)
E/AndroidRuntime( 2680):        at android.content.ContextWrapper.getSystemService(ContextWrapper.java:519)
E/AndroidRuntime( 2680):        at com.android.systemui.statusbar.policy.NetworkController.<init>(NetworkController.java:196)
E/AndroidRuntime( 2680):        at com.android.systemui.statusbar.phone.PhoneStatusBar.makeStatusBarView(PhoneStatusBar.java:490)
E/AndroidRuntime( 2680):        at com.android.systemui.statusbar.phone.PhoneStatusBar.addStatusBarWindow(PhoneStatusBar.java:2136)
E/AndroidRuntime( 2680):        at com.android.systemui.statusbar.phone.PhoneStatusBar.createAndAddWindows(PhoneStatusBar.java:2111)
E/AndroidRuntime( 2680):        at com.android.systemui.statusbar.BaseStatusBar.start(BaseStatusBar.java:230)
E/AndroidRuntime( 2680):        at com.android.systemui.statusbar.phone.PhoneStatusBar.start(PhoneStatusBar.java:315)
E/AndroidRuntime( 2680):        at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:100)
E/AndroidRuntime( 2680):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
E/AndroidRuntime( 2680):        ... 10 more
W/ContextImpl( 2553): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1439 android.bluetooth.BluetoothHeadset.<init>:273 android.bluetooth.BluetoothAdapter.getProfileProxy:1162 android.media.AudioService.getBluetoothHeadset:2189 android.media.AudioService.access$2800:109
W/ContextImpl( 2553): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1439 android.bluetooth.BluetoothA2dp.<init>:160 android.bluetooth.BluetoothAdapter.getProfileProxy:1165 android.media.AudioService$AudioServiceBroadcastReceiver.onReceive:4086 android.app.LoadedApk$ReceiverDispatcher$Args.run:763
I/Process ( 2680): Sending signal. PID: 2680 SIG: 9
V/WiredAccessoryManager( 2553): init()
W/WiredAccessoryManager( 2553): /sys/class/switch/usb_audio/state not found while attempting to determine initial switch state
W/dalvikvm( 2553): threadid=43: thread exiting with uncaught exception (group=0x41845700)
I/dalvikvm( 2756): Turning on JNI app bug workarounds for target SDK version 9...
D/AndroidRuntime( 2737): Shutting down VM
W/dalvikvm( 2737): threadid=1: thread exiting with uncaught exception (group=0x41845700)
E/AndroidRuntime( 2553): *** FATAL EXCEPTION IN SYSTEM PROCESS: SyncHandlerThread
E/AndroidRuntime( 2553): java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2553):        at com.android.internal.util.Preconditions.checkNotNull(Preconditions.java:52)
E/AndroidRuntime( 2553):        at android.net.ConnectivityManager.<init>(ConnectivityManager.java:838)
E/AndroidRuntime( 2553):        at android.app.ContextImpl$10.createStaticService(ContextImpl.java:334)
E/AndroidRuntime( 2553):        at android.app.ContextImpl$StaticServiceFetcher.getService(ContextImpl.java:258)
E/AndroidRuntime( 2553):        at android.app.ContextImpl.getSystemService(ContextImpl.java:1514)
E/AndroidRuntime( 2553):        at com.android.server.content.SyncManager.getConnectivityManager(SyncManager.java:356)
E/AndroidRuntime( 2553):        at com.android.server.content.SyncManager.readDataConnectionState(SyncManager.java:319)
E/AndroidRuntime( 2553):        at com.android.server.content.SyncManager.access$500(SyncManager.java:104)
E/AndroidRuntime( 2553):        at com.android.server.content.SyncManager$SyncHandler.handleMessage(SyncManager.java:1823)
E/AndroidRuntime( 2553):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2553):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2553):        at android.os.HandlerThread.run(HandlerThread.java:61)
I/ActivityManager( 2553): Process com.android.systemui (pid 2680) has died.
W/ActivityManager( 2553): Scheduling restart of crashed service com.android.systemui/.ImageWallpaper in 0ms
E/AndroidRuntime( 2737): FATAL EXCEPTION: main
E/AndroidRuntime( 2737): java.lang.RuntimeException: Unable to create application com.android.phone.PhoneApp: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2737):        at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4447)
E/AndroidRuntime( 2737):        at android.app.ActivityThread.access$1300(ActivityThread.java:141)
E/AndroidRuntime( 2737):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1316)
E/AndroidRuntime( 2737):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2737):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2737):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2737):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2737):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2737):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2737):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2737):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2737): Caused by: java.lang.NullPointerException: missing IConnectivityManager
E/AndroidRuntime( 2737):        at com.android.internal.util.Preconditions.checkNotNull(Preconditions.java:52)
E/AndroidRuntime( 2737):        at android.net.ConnectivityManager.<init>(ConnectivityManager.java:838)
E/AndroidRuntime( 2737):        at android.app.ContextImpl$10.createStaticService(ContextImpl.java:334)
E/AndroidRuntime( 2737):        at android.app.ContextImpl$StaticServiceFetcher.getService(ContextImpl.java:258)
E/AndroidRuntime( 2737):        at android.app.ContextImpl.getSystemService(ContextImpl.java:1514)
E/AndroidRuntime( 2737):        at android.content.ContextWrapper.getSystemService(ContextWrapper.java:519)
E/AndroidRuntime( 2737):        at com.android.internal.telephony.RIL.<init>(RIL.java:645)
E/AndroidRuntime( 2737):        at com.android.internal.telephony.PhoneFactory.makeDefaultPhone(PhoneFactory.java:138)
E/AndroidRuntime( 2737):        at com.android.internal.telephony.PhoneFactory.makeDefaultPhones(PhoneFactory.java:57)
E/AndroidRuntime( 2737):        at com.android.phone.PhoneGlobals.onCreate(PhoneGlobals.java:446)
E/AndroidRuntime( 2737):        at com.android.phone.PhoneApp.onCreate(PhoneApp.java:38)
E/AndroidRuntime( 2737):        at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1007)
E/AndroidRuntime( 2737):        at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4444)
E/AndroidRuntime( 2737):        ... 10 more
I/ActivityManager( 2553): Start proc com.android.systemui for restart com.android.systemui: pid=2787 uid=10036 gids={50036, 1028, 1015, 3002, 3001}
D/dalvikvm( 2270): GC_EXPLICIT freed 36K, 4% free 2520K/2608K, paused 2ms+1ms, total 28ms
D/dalvikvm( 2270): GC_EXPLICIT freed <1K, 4% free 2520K/2608K, paused 2ms+1ms, total 25ms
D/dalvikvm( 2270): GC_EXPLICIT freed <1K, 4% free 2520K/2608K, paused 1ms+1ms, total 18ms
I/Process ( 2737): Sending signal. PID: 2737 SIG: 9
I/ActivityManager( 2553): Process com.android.phone (pid 2737) has died.
I/ActivityManager( 2553): Start proc com.android.phone for restart com.android.phone: pid=2806 uid=1001 gids={41001, 3002, 3001, 3003, 1015, 1028}
I/PackageManager( 2553): Running dexopt on: com.android.music
D/libEGL  ( 2553): loaded /system/lib/egl/libGLESv2_VIVANTE.so
D/dalvikvm( 2818): DexOpt: load 53ms, verify+opt 162ms, 735652 bytes
E/BufferQueue( 2269): [Keyguard] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/OpenGLRenderer( 2553): Enabling debug mode 0
D/AdapterServiceConfig( 2764): Adding HeadsetService
D/AdapterServiceConfig( 2764): Adding A2dpService
D/AdapterServiceConfig( 2764): Adding HidService
D/AdapterServiceConfig( 2764): Adding HealthService
D/AdapterServiceConfig( 2764): Adding PanService
D/AdapterServiceConfig( 2764): Adding GattService
I/Process ( 2553): Sending signal. PID: 2553 SIG: 9
D/BluetoothAdapterService( 2764): REFCOUNT: CREATED. INSTANCE_COUNT1
I/ServiceManager( 2265): service 'cpuinfo' died
I/ServiceManager( 2265): service 'dbinfo' died
I/ServiceManager( 2265): service 'meminfo' died
I/ServiceManager( 2265): service 'permission' died
I/ServiceManager( 2265): service 'account' died
I/ServiceManager( 2265): service 'scheduling_policy' died
I/ServiceManager( 2265): service 'telephony.registry' died
I/ServiceManager( 2265): service 'usagestats' died
I/ServiceManager( 2265): service 'sensorservice' died
I/ServiceManager( 2265): service 'gfxinfo' died
I/ServiceManager( 2265): service 'content' died
I/ServiceManager( 2265): service 'batteryinfo' died
I/ServiceManager( 2265): service 'power' died
I/ServiceManager( 2265): service 'display' died
I/ServiceManager( 2265): service 'bluetooth_manager' died
I/ServiceManager( 2265): service 'entropy' died
I/ServiceManager( 2265): service 'user' died
I/ServiceManager( 2265): service 'device_policy' died
I/ServiceManager( 2265): service 'lock_settings' died
I/ServiceManager( 2265): service 'window' died
I/ServiceManager( 2265): service 'hardware' died
I/ServiceManager( 2265): service 'battery' died
I/ServiceManager( 2265): service 'vibrator' died
I/ServiceManager( 2265): service 'alarm' died
I/ServiceManager( 2265): service 'statusbar' died
I/ServiceManager( 2265): service 'clipboard' died
I/ServiceManager( 2265): service 'network_management' died
I/ServiceManager( 2265): service 'textservices' died
I/ServiceManager( 2265): service 'netstats' died
I/ServiceManager( 2265): service 'input' died
I/ServiceManager( 2265): service 'wifi' died
I/ServiceManager( 2265): service 'audio' died
I/ServiceManager( 2265): service 'servicediscovery' died
I/ServiceManager( 2265): service 'updatelock' died
I/ServiceManager( 2265): service 'notification' died
I/ServiceManager( 2265): service 'devicestoragemonitor' died
I/ServiceManager( 2265): service 'location' died
I/ServiceManager( 2265): service 'country_detector' died
I/ServiceManager( 2265): service 'search' died
I/ServiceManager( 2265): service 'dropbox' died
I/ServiceManager( 2265): service 'wallpaper' died
I/ServiceManager( 2265): service 'accessibility' died
I/ServiceManager( 2265): service 'wifip2p' died
I/ServiceManager( 2265): service 'netpolicy' died
I/ServiceManager( 2265): service 'input_method' died
I/ServiceManager( 2265): service 'usb' died
I/ServiceManager( 2265): service 'serial' died
I/ServiceManager( 2265): service 'uimode' died
I/ServiceManager( 2265): service 'backup' died
I/ServiceManager( 2265): service 'appwidget' died
I/ServiceManager( 2265): service 'diskstats' died
I/ServiceManager( 2265): service 'samplingprofiler' died
I/ServiceManager( 2265): service 'commontime_management' died
I/ServiceManager( 2265): service 'dreams' died
I/ServiceManager( 2265): service 'mount' died
I/ServiceManager( 2265): service 'appops' died
I/ServiceManager( 2265): service 'package' died
I/ServiceManager( 2265): service 'activity' died
W/AudioFlinger( 2272): power manager service died !!!
D/AndroidRuntime( 2672): Shutting down VM
W/dalvikvm( 2672): threadid=1: thread exiting with uncaught exception (group=0x41845700)
E/AccessibilityManager( 2787): AccessibilityManagerService is dead
E/AccessibilityManager( 2787): android.os.DeadObjectException
E/AccessibilityManager( 2787):  at android.os.BinderProxy.transact(Native Method)
E/AccessibilityManager( 2787):  at android.view.accessibility.IAccessibilityManager$Stub$Proxy.addClient(IAccessibilityManager.java:204)
E/AccessibilityManager( 2787):  at android.view.accessibility.AccessibilityManager.<init>(AccessibilityManager.java:200)
E/AccessibilityManager( 2787):  at android.view.accessibility.AccessibilityManager.createSingletonInstance(AccessibilityManager.java:182)
E/AccessibilityManager( 2787):  at android.view.accessibility.AccessibilityManager.createAsSharedAcrossUsers(AccessibilityManager.java:153)
E/AccessibilityManager( 2787):  at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:74)
E/AccessibilityManager( 2787):  at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
E/AccessibilityManager( 2787):  at android.app.ActivityThread.access$1600(ActivityThread.java:141)
E/AccessibilityManager( 2787):  at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
E/AccessibilityManager( 2787):  at android.os.Handler.dispatchMessage(Handler.java:99)
E/AccessibilityManager( 2787):  at android.os.Looper.loop(Looper.java:137)
E/AccessibilityManager( 2787):  at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AccessibilityManager( 2787):  at java.lang.reflect.Method.invokeNative(Native Method)
E/AccessibilityManager( 2787):  at java.lang.reflect.Method.invoke(Method.java:525)
E/AccessibilityManager( 2787):  at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AccessibilityManager( 2787):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AccessibilityManager( 2787):  at dalvik.system.NativeStart.main(Native Method)
D/AndroidRuntime( 2756): Shutting down VM
W/dalvikvm( 2756): threadid=1: thread exiting with uncaught exception (group=0x41845700)
E/BluetoothAdapter( 2764):
E/BluetoothAdapter( 2764): android.os.DeadObjectException
E/BluetoothAdapter( 2764):      at android.os.BinderProxy.transact(Native Method)
E/BluetoothAdapter( 2764):      at android.bluetooth.IBluetoothManager$Stub$Proxy.registerAdapter(IBluetoothManager.java:171)
E/BluetoothAdapter( 2764):      at android.bluetooth.BluetoothAdapter.<init>(BluetoothAdapter.java:399)
E/BluetoothAdapter( 2764):      at android.bluetooth.BluetoothAdapter.getDefaultAdapter(BluetoothAdapter.java:382)
E/BluetoothAdapter( 2764):      at com.android.bluetooth.btservice.AdapterProperties.<init>(AdapterProperties.java:68)
E/BluetoothAdapter( 2764):      at com.android.bluetooth.btservice.AdapterService.onCreate(AdapterService.java:253)
E/BluetoothAdapter( 2764):      at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
E/BluetoothAdapter( 2764):      at android.app.ActivityThread.access$1600(ActivityThread.java:141)
E/BluetoothAdapter( 2764):      at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
E/BluetoothAdapter( 2764):      at android.os.Handler.dispatchMessage(Handler.java:99)
E/BluetoothAdapter( 2764):      at android.os.Looper.loop(Looper.java:137)
E/BluetoothAdapter( 2764):      at android.app.ActivityThread.main(ActivityThread.java:5103)
E/BluetoothAdapter( 2764):      at java.lang.reflect.Method.invokeNative(Native Method)
E/BluetoothAdapter( 2764):      at java.lang.reflect.Method.invoke(Method.java:525)
E/BluetoothAdapter( 2764):      at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/BluetoothAdapter( 2764):      at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/BluetoothAdapter( 2764):      at dalvik.system.NativeStart.main(Native Method)
D/BluetoothAdapterState( 2764): make
E/AndroidRuntime( 2672): FATAL EXCEPTION: main
E/AndroidRuntime( 2672): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.launcher/com.android.launcher2.Launcher}: java.lang.RuntimeException: android.os.DeadObjectException
E/AndroidRuntime( 2672):        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2211)
E/AndroidRuntime( 2672):        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2261)
E/AndroidRuntime( 2672):        at android.app.ActivityThread.access$600(ActivityThread.java:141)
E/AndroidRuntime( 2672):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1256)
E/AndroidRuntime( 2672):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2672):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2672):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2672):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2672):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2672):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2672):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2672):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2672): Caused by: java.lang.RuntimeException: android.os.DeadObjectException
E/AndroidRuntime( 2672):        at android.accounts.AccountManager.getAccounts(AccountManager.java:386)
E/AndroidRuntime( 2672):        at com.android.launcher2.Launcher.isClingsEnabled(Launcher.java:3868)
E/AndroidRuntime( 2672):        at com.android.launcher2.Launcher.showFirstRunWorkspaceCling(Launcher.java:3962)
E/AndroidRuntime( 2672):        at com.android.launcher2.Launcher.onCreate(Launcher.java:384)
E/AndroidRuntime( 2672):        at android.app.Activity.performCreate(Activity.java:5133)
E/AndroidRuntime( 2672):        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1087)
E/AndroidRuntime( 2672):        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2175)
E/AndroidRuntime( 2672):        ... 11 more
E/AndroidRuntime( 2672): Caused by: android.os.DeadObjectException
E/AndroidRuntime( 2672):        at android.os.BinderProxy.transact(Native Method)
E/AndroidRuntime( 2672):        at android.accounts.IAccountManager$Stub$Proxy.getAccounts(IAccountManager.java:589)
E/AndroidRuntime( 2672):        at android.accounts.AccountManager.getAccounts(AccountManager.java:383)
E/AndroidRuntime( 2672):        ... 17 more
E/AndroidRuntime( 2756): FATAL EXCEPTION: main
E/AndroidRuntime( 2756): java.lang.RuntimeException: Unable to instantiate application android.app.Application: java.lang.IllegalStateException: Unable to get package info for com.android.music; is system dying?
E/AndroidRuntime( 2756):        at android.app.LoadedApk.makeApplication(LoadedApk.java:509)
E/AndroidRuntime( 2756):        at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4417)
E/AndroidRuntime( 2756):        at android.app.ActivityThread.access$1300(ActivityThread.java:141)
E/AndroidRuntime( 2756):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1316)
E/AndroidRuntime( 2756):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2756):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2756):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2756):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2756):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2756):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2756):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2756):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2756): Caused by: java.lang.IllegalStateException: Unable to get package info for com.android.music; is system dying?
E/AndroidRuntime( 2756):        at android.app.LoadedApk.initializeJavaContextClassLoader(LoadedApk.java:365)
E/AndroidRuntime( 2756):        at android.app.LoadedApk.getClassLoader(LoadedApk.java:322)
E/AndroidRuntime( 2756):        at android.app.LoadedApk.makeApplication(LoadedApk.java:501)
E/AndroidRuntime( 2756):        ... 11 more
E/AndroidRuntime( 2756): Caused by: android.os.DeadObjectException
E/AndroidRuntime( 2756):        at android.os.BinderProxy.transact(Native Method)
E/AndroidRuntime( 2756):        at android.content.pm.IPackageManager$Stub$Proxy.getPackageInfo(IPackageManager.java:1393)
E/AndroidRuntime( 2756):        at android.app.LoadedApk.initializeJavaContextClassLoader(LoadedApk.java:363)
E/AndroidRuntime( 2756):        ... 13 more
E/installd( 2273): eof
E/installd( 2273): failed to read size
I/installd( 2273): closing connection
I/Process ( 2672): Sending signal. PID: 2672 SIG: 9
E/AndroidRuntime( 2672): Error reporting crash
E/AndroidRuntime( 2672): android.os.DeadObjectException
E/AndroidRuntime( 2672):        at android.app.ActivityManagerProxy.handleApplicationCrash(ActivityManagerNative.java:3409)
E/AndroidRuntime( 2672):        at com.android.internal.os.RuntimeInit$UncaughtHandler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 2672):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:693)
E/AndroidRuntime( 2672):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:690)
I/BluetoothAdapterState( 2764): Entering OffState
I/bluedroid( 2764): init
I/bte_conf( 2764): Attempt to load stack conf from /etc/bluetooth/bt_stack.conf
I/bluedroid( 2764): get_profile_interface socket
I/GKI_LINUX( 2764): gki_task_entry: gki_task_entry task_id=1 [BTIF] starting
I/BluetoothAdapterProperties( 2764): adapterPropertyChangedCallback with type:2 len:6
D/BluetoothAdapterProperties( 2764): Address is:22:22:65:F8:0D:21
I/BluetoothAdapterProperties( 2764): adapterPropertyChangedCallback with type:1 len:4
W/ResourceType( 2787): No package identifier when getting value for resource number 0x00000000
D/AndroidRuntime( 2787): Shutting down VM
W/dalvikvm( 2787): threadid=1: thread exiting with uncaught exception (group=0x41845700)
W/SystemUIService( 2787): Failing checking whether status bar can hide
W/SystemUIService( 2787): android.os.DeadObjectException
W/SystemUIService( 2787):       at android.os.BinderProxy.transact(Native Method)
W/SystemUIService( 2787):       at android.view.IWindowManager$Stub$Proxy.hasSystemNavBar(IWindowManager.java:1220)
W/SystemUIService( 2787):       at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:79)
W/SystemUIService( 2787):       at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
W/SystemUIService( 2787):       at android.app.ActivityThread.access$1600(ActivityThread.java:141)
W/SystemUIService( 2787):       at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
W/SystemUIService( 2787):       at android.os.Handler.dispatchMessage(Handler.java:99)
W/SystemUIService( 2787):       at android.os.Looper.loop(Looper.java:137)
W/SystemUIService( 2787):       at android.app.ActivityThread.main(ActivityThread.java:5103)
W/SystemUIService( 2787):       at java.lang.reflect.Method.invokeNative(Native Method)
W/SystemUIService( 2787):       at java.lang.reflect.Method.invoke(Method.java:525)
W/SystemUIService( 2787):       at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
W/SystemUIService( 2787):       at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
W/SystemUIService( 2787):       at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2787): FATAL EXCEPTION: main
E/AndroidRuntime( 2787): java.lang.RuntimeException: Unable to create service com.android.systemui.SystemUIService: android.content.res.Resources$NotFoundException: String resource ID #0x0
E/AndroidRuntime( 2787):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2587)
E/AndroidRuntime( 2787):        at android.app.ActivityThread.access$1600(ActivityThread.java:141)
E/AndroidRuntime( 2787):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1338)
E/AndroidRuntime( 2787):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2787):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2787):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2787):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2787):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2787):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2787):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2787):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2787): Caused by: android.content.res.Resources$NotFoundException: String resource ID #0x0
E/AndroidRuntime( 2787):        at android.content.res.Resources.getText(Resources.java:239)
E/AndroidRuntime( 2787):        at android.content.res.Resources.getString(Resources.java:325)
E/AndroidRuntime( 2787):        at android.content.Context.getString(Context.java:334)
E/AndroidRuntime( 2787):        at com.android.systemui.SystemUIService.chooseClass(SystemUIService.java:57)
E/AndroidRuntime( 2787):        at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:89)
E/AndroidRuntime( 2787):        at android.app.ActivityThread.handleCreateService(ActivityThread.java:2577)
E/AndroidRuntime( 2787):        ... 10 more
D/BluetoothAdmma enable setting inactive
apterProperties( 2764): Name is: iMX6
I/Process ( 2756): Sending signal. PID: 2756 SIG: 9
E/AndroidRuntime( 2756): Error reporting crash
E/AndroidRuntime( 2756): android.os.DeadObjectException
E/AndroidRuntime( 2756):        at android.app.ActivityManagerProxy.handleApplicationCrash(ActivityManagerNative.java:3409)
E/AndroidRuntime( 2756):        at com.android.internal.os.RuntimeInit$UncaughtHandler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 2756):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:693)
E/AndroidRuntime( 2756):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:690)
I/Process ( 2787): Sending signal. PID: 2787 SIG: 9
D/AndroidRuntime( 2806): Shutting down VM
W/dalvikvm( 2806): threadid=1: thread exiting with uncaught exception (group=0x41845700)
E/AndroidRuntime( 2787): Error reporting crash
E/AndroidRuntime( 2787): android.os.DeadObjectException
E/AndroidRuntime( 2787):        at android.os.BinderProxy.transact(Native Method)
E/AndroidRuntime( 2787):        at android.app.ActivityManagerProxy.handleApplicationCrash(ActivityManagerNative.java:3409)
E/AndroidRuntime( 2787):        at com.android.internal.os.RuntimeInit$UncaughtHandler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 2787):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:693)
E/AndroidRuntime( 2787):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:690)
I/Process ( 2806): Sending signal. PID: 2806 SIG: 9
E/AndroidRuntime( 2806): FATAL EXCEPTION: main
E/AndroidRuntime( 2806): java.lang.RuntimeException: Unable to instantiate application com.android.phone.PhoneApp: java.lang.IllegalStateException: Unable to get package info for com.android.phone; is system dying?
E/AndroidRuntime( 2806):        at android.app.LoadedApk.makeApplication(LoadedApk.java:509)
E/AndroidRuntime( 2806):        at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4417)
E/AndroidRuntime( 2806):        at android.app.ActivityThread.access$1300(ActivityThread.java:141)
E/AndroidRuntime( 2806):        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1316)
E/AndroidRuntime( 2806):        at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2806):        at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2806):        at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 2806):        at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2806):        at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 2806):        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 2806):        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 2806):        at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2806): Caused by: java.lang.IllegalStateException: Unable to get package info for com.android.phone; is system dying?
E/AndroidRuntime( 2806):        at android.app.LoadedApk.initializeJavaContextClassLoader(LoadedApk.java:365)
E/AndroidRuntime( 2806):        at android.app.LoadedApk.getClassLoader(LoadedApk.java:322)
E/AndroidRuntime( 2806):        at android.app.LoadedApk.makeApplication(LoadedApk.java:501)
E/AndroidRuntime( 2806):        ... 11 more
E/AndroidRuntime( 2806): Caused by: android.os.DeadObjectException
E/AndroidRuntime( 2806):        at android.os.BinderProxy.transact(Native Method)
E/AndroidRuntime( 2806):        at android.content.pm.IPackageManager$Stub$Proxy.getPackageInfo(IPackageManager.java:1393)
E/AndroidRuntime( 2806):        at android.app.LoadedApk.initializeJavaContextClassLoader(LoadedApk.java:363)
E/AndroidRuntime( 2806):        ... 13 more
E/AndroidRuntime( 2806): Error reporting crash
E/AndroidRuntime( 2806): android.os.DeadObjectException
E/AndroidRuntime( 2806):        at android.app.ActivityManagerProxy.handleApplicationCrash(ActivityManagerNative.java:3409)
E/AndroidRuntime( 2806):        at com.android.internal.os.RuntimeInit$UncaughtHandler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 2806):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:693)
E/AndroidRuntime( 2806):        at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:690)
I/v_hwc   ( 2269): vsync thread exit: callback procs not registered.
I/Zygote  ( 2270): Exit zygote because system server (2553) has terminated
I/ServiceManager( 2265): service 'media.audio_flinger' died
I/ServiceManager( 2265): service 'media.player' died
I/ServiceManager( 2265): service 'media.camera' died
I/ServiceManager( 2265): service 'media.audio_policy' died
I/Netd    ( 2846): Netd 1.0 starting
W/InterfaceController( 2846): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver( 2845): ServiceManager: 0x40aea4a8
I/AudioFlinger( 2845): Using default 3000 mSec as standby time.
I/CameraService( 2845): CameraService started (pid=2845)
I/CameraService( 2845): Loaded "Freescale CameraHal Module" camera module
I/FslCameraHAL( 2845): Face Back Camera is ov5640_mipi, orient is 0
I/FslCameraHAL( 2845): Face Front Camera is uvc,ov5642_camera,ov5640_camera, orient is 0
I/FslCameraHAL( 2845): Checking the camera ov5640_mipi
I/FslCameraHAL( 2845): Checking the camera uvc
I/FslCameraHAL( 2845): Checking the camera ov5642_camera
I/FslCameraHAL( 2845): Checking the camera ov5640_camera
I/AudioPolicyManagerBase( 2845): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary( 2845): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary( 2845): out rate 44100
W/audio_hw_primary( 2845): in rate 44100, channels 1 format 0
I/AudioFlinger( 2845): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 2845): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary( 2845): opened out stream...1073844992
I/AudioFlinger( 2845): HAL output buffer size 192 frames, normal mix buffer size 768 frames
I/AudioMixer( 2845): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe( 2845): Failed to fetch local time frequency when constructing a MonoPipe (res = -32).  getNextWriteTimestamp calls will be non-functional
D/AndroidRuntime( 2847):
D/AndroidRuntime( 2847): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 2847): CheckJNI is ON
I/AndroidRuntime( 2847): JNI options: '-Xjniopts:warnonly'
D/dalvikvm( 2847): Trying to load lib libjavacore.so 0x0
D/dalvikvm( 2847): Added shared lib libjavacore.so 0x0
D/dalvikvm( 2847): Trying to load lib libnativehelper.so 0x0
D/dalvikvm( 2847): Added shared lib libnativehelper.so 0x0
W/dalvikvm( 2847): PR_SET_NO_NEW_PRIVS failed. Is your kernel compiled correctly?: Invalid argument
I/SamplingProfilerIntegration( 2847): Profiling disabled.
I/Zygote  ( 2847): Preloading classes...
D/dalvikvm( 2847): GC_EXPLICIT freed 37K, 9% free 436K/476K, paused 1ms+1ms, total 3ms
D/dalvikvm( 2847): GC_EXPLICIT freed 4K, 4% free 507K/528K, paused 1ms+0ms, total 8ms
D/dalvikvm( 2847): Note: class Landroid/app/ActivityManagerNative; has 163 unimplemented (abstract) methods
D/dalvikvm( 2847): GC_EXPLICIT freed 22K, 5% free 538K/564K, paused 0ms+1ms, total 3ms
D/dalvikvm( 2847): GC_EXPLICIT freed 13K, 3% free 598K/616K, paused 1ms+0ms, total 3ms
D/dalvikvm( 2847): GC_EXPLICIT freed 26K, 5% free 629K/660K, paused 1ms+0ms, total 4ms
D/dalvikvm( 2847): GC_EXPLICIT freed 28K, 5% free 656K/688K, paused 1ms+0ms, total 4ms
D/dalvikvm( 2847): GC_EXPLICIT freed 81K, 10% free 789K/876K, paused 1ms+0ms, total 5ms
D/dalvikvm( 2847): GC_EXPLICIT freed 28K, 7% free 816K/876K, paused 0ms+0ms, total 5ms
D/TextLayoutCache( 2847): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm( 2847): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI( 2847): register_android_mtp_MtpDevice
D/dalvikvm( 2847): GC_EXPLICIT freed 25K, 4% free 848K/876K, paused 1ms+0ms, total 5ms
D/dalvikvm( 2847): GC_EXPLICIT freed 26K, 4% free 886K/916K, paused 0ms+1ms, total 4ms
D/dalvikvm( 2847): GC_FOR_ALLOC freed 218K, 16% free 1180K/1400K, paused 8ms, total 8ms
D/dalvikvm( 2847): GC_EXPLICIT freed 288K, 18% free 1378K/1672K, paused 1ms+1ms, total 9ms
D/dalvikvm( 2847): GC_EXPLICIT freed 26K, 16% free 1406K/1672K, paused 0ms+0ms, total 8ms
D/dalvikvm( 2847): GC_EXPLICIT freed 19K, 14% free 1447K/1672K, paused 0ms+0ms, total 9ms
D/dalvikvm( 2847): GC_EXPLICIT freed 16K, 12% free 1487K/1672K, paused 0ms+0ms, total 13ms
D/dalvikvm( 2847): GC_EXPLICIT freed 24K, 2% free 1792K/1820K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2847): GC_EXPLICIT freed 34K, 2% free 1827K/1864K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2847): GC_EXPLICIT freed 30K, 2% free 1851K/1884K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2847): GC_EXPLICIT freed 29K, 2% free 1877K/1912K, paused 1ms+1ms, total 12ms
I/dalvikvm( 2847): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
D/dalvikvm( 2847): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
D/dalvikvm( 2847): GC_EXPLICIT freed 20K, 2% free 1911K/1936K, paused 1ms+1ms, total 12ms
D/dalvikvm( 2847): GC_EXPLICIT freed 26K, 2% free 1938K/1968K, paused 1ms+1ms, total 18ms
D/dalvikvm( 2847): GC_EXPLICIT freed 27K, 2% free 1964K/1996K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2847): GC_EXPLICIT freed 29K, 2% free 1993K/2024K, paused 1ms+1ms, total 14ms
D/dalvikvm( 2847): GC_EXPLICIT freed 31K, 2% free 2016K/2052K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2847): GC_EXPLICIT freed 32K, 2% free 2039K/2076K, paused 1ms+1ms, total 14ms
D/dalvikvm( 2847): GC_EXPLICIT freed 27K, 2% free 2067K/2100K, paused 1ms+1ms, total 14ms
D/dalvikvm( 2847): GC_EXPLICIT freed 29K, 2% free 2094K/2128K, paused 1ms+1ms, total 13ms
D/dalvikvm( 2847): GC_EXPLICIT freed 38K, 2% free 2112K/2152K, paused 1ms+1ms, total 15ms
D/dalvikvm( 2847): GC_EXPLICIT freed 39K, 2% free 2128K/2172K, paused 1ms+1ms, total 15ms
D/dalvikvm( 2847): GC_EXPLICIT freed 37K, 2% free 2146K/2188K, paused 1ms+2ms, total 14ms
I/System  ( 2847): Loaded time zone names for "" in 75ms (70ms in ICU)
I/System  ( 2847): Loaded time zone names for "en_US" in 59ms (53ms in ICU)
D/dalvikvm( 2847): GC_EXPLICIT freed 135K, 6% free 2235K/2376K, paused 1ms+1ms, total 15ms
D/dalvikvm( 2847): GC_EXPLICIT freed 14K, 4% free 2299K/2376K, paused 1ms+2ms, total 16ms
request_suspend_state: wakeup (0->0) at 24764982670 (1970-01-02 00:00:12.375828667 UTC)ms
D/dalvikvm( 2847): GC_EXPLICIT freed 29K, 2% free 2363K/2396K, paused 1ms+2ms, total 16ms
D/dalvikvm( 2847): GC_EXPLICIT freed 44K, 2% free 2372K/2420K, paused 1ms+2ms, total 17ms
D/dalvikvm( 2847): GC_EXPLICIT freed 29K, 2% free 2397K/2432K, paused 1ms+1ms, total 16ms
D/dalvikvm( 2847): GC_EXPLICIT freed 33K, 2% free 2417K/2456K, paused 1ms+1ms, total 16ms
I/Zygote  ( 2847): ...preloaded 2879 classes in 1430ms.
D/dalvikvm( 2847): GC_EXPLICIT freed 22K, 2% free 2434K/2460K, paused 1ms+1ms, total 18ms
I/Zygote  ( 2847): Preloading resources...
W/Resources( 2847): Preloaded drawable resource #0x1080606 (android:drawable/toast_frame_holo) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x1080108 (android:drawable/btn_chmma enable setting active
eck_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x1080107 (android:drawable/btn_check_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x1080105 (android:drawable/btn_check_on_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x1080104 (android:drawable/btn_check_on_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x1080102 (android:drawable/btn_check_on_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2847): GC_EXPLICIT freed 43K, 3% free 2444K/2500K, paused 1ms+1ms, total 17ms
W/Resources( 2847): Preloaded drawable resource #0x1080101 (android:drawable/btn_check_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x1080100 (android:drawable/btn_check_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800ff (android:drawable/btn_check_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800fe (android:drawable/btn_check_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800fd (android:drawable/btn_check_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800f5 (android:drawable/btn_check_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800f4 (android:drawable/btn_check_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800f0 (android:drawable/btn_check_off_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800ef (android:drawable/btn_check_off_holo_dark) that varies with configuration!!
D/dalvikvm( 2847): GC_EXPLICIT freed 50K, 3% free 2446K/2500K, paused 1ms+1ms, total 16ms
W/Resources( 2847): Preloaded drawable resource #0x10800ed (android:drawable/btn_check_off_focused_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800ec (android:drawable/btn_check_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800eb (android:drawable/btn_check_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2847): Preloaded drawable resource #0x10800ea (android:drawable/btn_check_offkernel BUG at include/linux/netdevice.h:520!
_disabled_holo_dark) that varies Unable to handle kernel NULL pointer dereference at virtual address 00000000
W/Resourcespgd = d5acc000
( 2847): Preloaded drawable resou[00000000] *pgd=00000000rce #0x10800e9 (android:drawable/
btn_check_off_disabled_focused_hoInternal error: Oops: 805 [#1] PREEMPT SMP
Modules linked in:
CPU: 0    Not tainted  (3.0.35 #2)
PC is at __bug+0x1c/0x28
LR is at __bug+0x18/0x28
pc : [<c004ffec>]    lr : [<c004ffe8>]    psr: 600b0013
sp : d5dbddf8  ip : 00000000  fp : 00000001
r10: d5dbc000  r9 : d414cc20  r8 : 00000000
r7 : d45f2044  r6 : 00000000  r5 : c06a03e0  r4 : d45f2000
r3 : 00000000  r2 : c090413c  r1 : 600b0093  r0 : 00000033
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 25acc04a  DAC: 00000015
PC: 0xc004ff6c:
ff6c  e1a04000 e24dd010 e590003c eb01caa4 e3500000 0594003c 0a00000d e2841034
ff8c  e594002c e891000e e88d000f ea000003 e59d000c eb01ca9a e3500000 0a000006
ffac  e1a0000d eb000eac e3500000 aafffff7 e3a00000 e28dd010 e8bd8010 e59d000c
