black screen in HDMI output when typing in terminal
2,106件の閲覧回数
jojorong
     The screen is black suddenly when typing in the terminal in small probability, i use the yocto project to create image with stable brach dylan,
     it is black almost if you use the application called "virt-viewer" or "spice-gtk" with FSL driver.
     This is not happen without any FSL driver with image "core-image-sato" or "core-image-sato-sdk",
     anyone have any advices ? thanks so much
ラベル(4)
1,915件の閲覧回数
jojorong
This issue is fixed in yocto dora branch looks like :smileyhappy:
1,915件の閲覧回数
OtavioSalvador
Senior Contributor II
Sorry but I didn't get the problem you have. Can you describe it a little bit more descriptive?
1,916件の閲覧回数
jojorong
