/bin/sh: can't access tty
1,513 次查看
banuprakash
devtmpfs:error mountinf -2
freeing unused kernel memory 324k(806ee000 - 8073f000)
//bin/sh: can't access tty; job control turned off
i cant able to assecc tty ports ofter adding binary files in recipes.
1,287 次查看
Rita_Wang
Which version BSP and wihch board are you using?
Rita
1,287 次查看
banuprakash
Kernel 3.14.38 and we are using imx6ulevk custom board.
1,287 次查看
Rita_Wang
Do you have the correct images running on your customer board? If they have portting success the BSP to they board? This maybe caused by the kernel problem, They need to confim.
