best upgrade path to quad core from mcimx6y2dvm09ab
1,187件の閲覧回数
jautry
What would be the closest match for upgrading to quad core for the mcimx6y2dvm single core with close to the same peripherals.
3 返答(返信)
1,153件の閲覧回数
joanxie
you can refer to the imx6q, but I don't know what peripherals do you need?
"https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces..."
1,126件の閲覧回数
jautry
We needed two LAN controllers.  It appears that to upgrade, we will have to add an external MAC.
1,027件の閲覧回数
joanxie
for LAN controller, they are not same, imx6q is more powerful, you can refer to the data sheet to compare
"https://www.nxp.com.cn/docs/en/data-sheet/IMX6DQCEC.pdf"
