Hi All,
I have the following configuration for port 4 and port 5, gsm_port is port 4 (gsm module as master) and dai_port is port 5 (Audio codec as slave).
dai_ptcr |= AUDMUX_PTCR_SYN;
gsm_ptcr |= AUDMUX_PTCR_SYN;
gsm_pdcr |= AUDMUX_PDCR_RXDSEL(dai_port);
dai_pdcr |= AUDMUX_PDCR_RXDSEL(gsm_port);
/* set Tx frame direction and source gsm_port--> dai_port output */
dai_ptcr |= AUDMUX_PTCR_TFSDIR;
dai_ptcr |= AUDMUX_PTCR_TFSSEL(AUDMUX_FROM_TXFS, gsm_port);
/* set Tx Clock direction and source gsm_port--> dai_port output */
dai_ptcr |= AUDMUX_PTCR_TCLKDIR;
dai_ptcr |= AUDMUX_PTCR_TCSEL(AUDMUX_FROM_TXFS, gsm_port);
My problem is that I can see the clock and data routed properly to audio codec but I cannot see the frame sync routed to the audio codec
Thanks in advance for any help with this issue
M . Nadeem
