Hi all,
I am trying to compile Arm Ne10 lib, but come up with an "arm_neon.h not found" error.
Does the toolchain version I got not support NEON compilation?
Does any one have idea how to fix this problem?
My current toolchain is yocto for iMX8.
Hi @YihMin
It means the toolchain you are using don't contain arm_neon.h, also the official bsp don't contain this file.
You can try to add a yocto bb layer to build this lib.
Hi nxf65025,
Thanks for your response. I will check and try it.
So this recipe will add the NEON support to the official bsp?
