apt-get not found
apt-get not found
1,616 次查看
kvk0422
I'm using SBC IMX6 Pico ITX, Linux 3.10 with yocto distribution. But I'm unable to install any package,as the apt-get command is not working in my  SBC IMX6.
How do I install apt-get in my SBC IMX6 Pico ITX to get packages?
标签 (5)
1,460 次查看
gusarambula
Hello Varun K,
The SBC IMX6 Pico ITX is not supported on the NXP BSP Release so I would recommend looking at this board BSP.
If this board BSP is based on Yocto you can add package management to the image and the apt function by adding the following commands to the conf/local.conf file. You would then need to configure the repository list for apt.
IMAGE_FEATURES += "package-management"
CORE_IMAGE_EXTRA_INSTALL += "apt"
I hope this helps!
